JHZR2
Staff member
Originally Posted By: 2015_PSD
There are plenty of oils today to go well past 10,000 miles with no issues whatsoever.
Can you promise me that they will go 10,000 miles without causing the faintest indication of varnish staining for every engine on the planet? And before you answer that, keep in mind that if you're wrong, lightning will strike you.
You can't promise that with whatever interval youre touting... Way too many variables to that.
3/3k or whatever was found with old tech materials, controls and oils, and was an extension on whatever the prior recommendation was (recall the Kendall "V"?).
Extensions from there based upon best practices, new controls and materials is viable - and vendors are extending them as they see fit and as they align to the fluids they spec.
Ill venture to guess that many of the situations where people experience issues are due to using the incorrect fluids. Sort of like the dex cool debacle - If green never touched your system, it was OK, but mix a little in by accident once and sludge city.
