Detroit 51 series 2 cycle diesel
by Red91. 03/25/19 01:54 PM
Rust repair cost
by supton. 03/25/19 01:41 PM
MANNOL ATF Multivehicle
by Ether. 03/25/19 01:17 PM
Welcome to Dusseldorf... err... Edinburgh.
by Quattro Pete. 03/25/19 01:07 PM
1NZ-FE Under Valve Cover - 280,000 Miles
by kschachn. 03/25/19 12:44 PM
Coolant Leak '06 300C
by Redright9. 03/25/19 12:40 PM
New truck
by double vanos. 03/25/19 12:26 PM
What pressure washer should I buy?
by wallyuwl. 03/25/19 11:27 AM
Natural Gas from Ohio Valley
by SubLGT. 03/25/19 11:18 AM
CVT Reliability and Durability
by raffy. 03/25/19 11:00 AM
comfortable seats
by redhat. 03/25/19 10:29 AM
walmart evinrude tcw-3 clearance score
by 1978elcamino. 03/25/19 10:15 AM
Mixing SN/d1G1 with SN+/d1G2?
by doyall. 03/25/19 10:14 AM
Best 2nd Phone Number App ?
by LoneRanger. 03/25/19 09:56 AM
Crud! Wix jacking up prices again! :(
by SubieRubyRoo. 03/25/19 09:53 AM
Interior "quick detailer"
by Redright9. 03/25/19 08:21 AM
Seafoam For Last 100 Miles Before Oil Change ?
by ChrisD46. 03/25/19 07:56 AM
WIX 57151XP factory filled with synthetic oil
by Donald. 03/25/19 06:58 AM
BMW Buying Guide: Every Model, Explained
by wemay. 03/25/19 05:43 AM
Double Din Android Auto Advice
by JeffKeryk. 03/24/19 11:25 PM
sonusfaber, Rollo, Drifted, Jcar516, gregjr7
67614 Registered Users
124 registered members (53' Stude, 14Accent, 555, 1nighttrain, 4WD, 928, 13 invisible), 2,290 guests, and 65 spiders.
Topics286,403
Posts4,907,692
Members67,614
Most Online2,967
Mar 10th, 2019
How do I load test a starter? '94 Ranger #4607511
12/18/17 06:45 PM
12/18/17 06:45 PM
Marshfield , MA
andyd Offline OP
andyd  Offline OP
Marshfield , MA
If somebody knows, please school me. It is winter and the Rat is up to its usual tricks. It likes to spend the winter laid up. This time it is the starter. 'Zactly what, I dunno. Turning the key gets me a click. It is coming from the fender mt'd starter relay. The starter mt'd solenoid is quiet.
The starter is an exact copy of the original Ford gear reduction gear starter. I mis diagnosed a dead short as a bad starter and a 38$ new starter looked good. Rebuilding the starter would cost me more than that. The original starter worked but rattled like a maraca. In goes the clone. Both starters test fine. So does the relay and wiring. I put the starter on the fender and hooked it up to its wires. Turned the key and it worked. In the truck. nothin'.
The starter is hand assembled and is a breeze to work on. Even the original came apart easily. I swapped solenoids, no sweat, T25 screws. First casualty was the braid to the brushes parted on the donor. but removing the brush pack was a snap, tweaker screwdriver stuff. the armature and stuff looked OK. But after I pulled out the armature, I saw a ball bearing stuck to a magnet. That explained the rattle. That and a bad nose bushing. My Franken-starter consists of the clone's reduction drive, field magnets, housing and brush pack. I used the original solenoid and armature . The clone's had a whiff of smoke. I'll follow up with my results after I put the starter back in.
Thick oil is better grin2
Re: How do I load test a starter? '94 Ranger [Re: andyd] #4607525
12/18/17 06:56 PM
12/18/17 06:56 PM
N.C.
gman2304 Offline
gman2304  Offline
N.C.
AZ will load test it for free.
Re: How do I load test a starter? '94 Ranger [Re: andyd] #4607526
12/18/17 06:57 PM
12/18/17 06:57 PM
ME
eljefino Offline
eljefino  Offline
ME
If you know the internal resistance of your battery (newfangled testers know this) you can do the math if you catch it at its lowest voltage level during cranking. Could also use an inductive pickup ammeter.
As for your diagnosis... if the starter is stuck on something mechanical like a seized engine, the headlights will dim. If it's not even trying to work, your headlights will remain bright when you hit the key.
Re: How do I load test a starter? '94 Ranger [Re: andyd] #4607536
12/18/17 07:06 PM
12/18/17 07:06 PM
USA
mk378 Offline
mk378  Offline
USA
You could have a bad engine ground. Measure voltage from battery negative post to the engine block while someone turns the key trying to start. It should stay much less than a volt.
Also you want to measure that voltage is actually coming out of the fender solenoid. When worn out, they will click but not make contact.
Re: How do I load test a starter? '94 Ranger [Re: andyd] #4607743
12/18/17 11:11 PM
12/18/17 11:11 PM
NY, NY
NYEngineer Offline
NYEngineer  Offline
NY, NY
Put a volt meter across the battery leads and crank the engine. Watch the meter and see what the voltage drops to during cranking.
If you get a click and the voltage takes a nose dive, it's most likely the battery. If you get a click and a very small or no voltage drop, it could be a bad cable or connection.
Check voltage into and out of the fender mounted solenoid, see that you get 12 volts on the pull in wire when the key is turned.
Re: How do I load test a starter? '94 Ranger [Re: andyd] #4607776
12/19/17 12:32 AM
12/19/17 12:32 AM
Marshfield , MA
andyd Offline OP
andyd  Offline OP
Marshfield , MA
I've re-done the circuit twice. I have 12.56 V at the 10awg stud on the relay. When I use a screwdriver to cross to the little stud for the key, nothing. I would be fine with crossing the solenoid if the starter cranked but it doesn't. I was seeing sparks on the battery connection at the starter. I thought it was a loose connection at the starter, it wasn't. It could possibly be a wonky solenoid, grounding when it gets pulled in. Engine is free too, BTW. Holy Moley I just took another look at the clone's shiny armature. Then I saw a burn mark, or at least a really hot spot. 6 segments of the commutator are showing signs of smoke leakage. The franken starter bench tests fine, The battery snaps loudly when I short it. Metal melts. Battery is fine. Its been on a minder and is about 6 months old.
Re: How do I load test a starter? '94 Ranger [Re: andyd] #4607780
12/19/17 12:39 AM
12/19/17 12:39 AM
Phoenix
dishdude Offline
dishdude  Offline
Phoenix
Take another look at that battery.
2018 Challenger SRT 392 PUP 0w-40 Wix 57899XP
2018 GTI
Re: How do I load test a starter? '94 Ranger [Re: andyd] #4607893
12/19/17 07:37 AM
12/19/17 07:37 AM
USA
mk378 Offline
mk378  Offline
USA
Do some of the tests, any of the tests, suggested by people trying to help you here. The test where you turn the headlights on and watch for them to dim when you turn the key is a good one.
If you see sparks, there's a bad connection or a short there. It is not normal.
Does the starter itself also have a solenoid wire, or only the big wire from the fender mounted solenoid?
If it's a single wire starter, measure voltage at the starter from the live wire terminal to starter ground while turning the key. If you don't have voltage, find out where it is being lost.
Some Fords have a fender mounted solenoid in line with a two-wire starter with internal solenoid. This system requires both solenoid wires to go live when the key is turned.
Re: How do I load test a starter? '94 Ranger [Re: andyd] #4608436
12/19/17 04:56 PM
12/19/17 04:56 PM
Marshfield , MA
andyd Offline OP
andyd  Offline OP
Marshfield , MA
I tested the be-jeezus out of stuff. I eliminated the NSS on the clutch and I tested that and found it good.
My Franken starter works! Rat starts like it used to, but hasn't lately. I noticed that the starter was working longer than usual before it stopped working entirely. Looks like I let the smoke of the armature. As for the solenoid. I dunno, but the old one works great.
"Some Fords have a fender mounted solenoid in line with a two-wire starter with internal solenoid This system requires both solenoid wires to go live when the key is turned." This one has a fender mtd "solenoid" just like every Ford I've ever had. For clarity, on the Ranger station forum, we have designated the fender thingy as the "starter relay" Which it is, but was always called a solenoid. As I had stated in my long post, I have no trouble shorting a solenoid, so that wasn't an issue. So of course it works fine. Total cost in parts- 44cents for some toothed washers. And beaucoup time grin2
