Synthetic motor oil in a gun
by Yuk. 03/26/19 01:07 AM
air suspension on a towed trailer?
by columnshift. 03/25/19 11:57 PM
AeroShell W100 SAE50 in Motorcycles?
by CCI. 03/25/19 11:02 PM
Spark plug torque when using anti-seize
by Reddy45. 03/25/19 10:58 PM
My kid is 8 now - use the front seat?
by y_p_w. 03/25/19 10:53 PM
2005 Pontiac GTO | 44,750 miles | 6-Speed
by Georgiey22. 03/25/19 10:39 PM
GWR Silencer Spray
by agpatel. 03/25/19 10:30 PM
Fuel line insulation to remedy vapor lock?
by motor_oil_madman. 03/25/19 10:22 PM
Running a fan to reduce humidity
by motor_oil_madman. 03/25/19 10:15 PM
stuck grease zerk on my JD tractor
by PaulH. 03/25/19 09:33 PM
S&W M&P 2.0 9MM Range Time
by 2015_PSD. 03/25/19 09:26 PM
Poor quality Ford wheel finish...
by gregk24. 03/25/19 09:12 PM
2013 GMC SIERRA PICKUPS
by Honda2003. 03/25/19 09:10 PM
Fighting HOA - anyone have any luck?
by pezzy669. 03/25/19 09:05 PM
Here's an oldie "Riding a film of oil"
by dbias. 03/25/19 08:47 PM
'14 Mopar 62TE transmission service?'s
by sloinker. 03/25/19 08:25 PM
Dodge Transmissions (Humor)
by StevieC. 03/25/19 07:57 PM
DCDMan, silverbullet21, gentzel, ksu90, SMA2020
67622 Registered Users
27 registered members (Bailes1992, billt460, 4WD, 2015Corolla, alcyon, 3 invisible), 500 guests, and 57 spiders.
Topics286,442
Posts4,908,271
Members67,622
Most Online2,967
Mar 10th, 2019
2007 Corolla; Battery light fading away? #4606546
12/17/17 07:49 PM
12/17/17 07:49 PM
MTL, CANADA
Rolla07 Offline OP
Rolla07  Offline OP
MTL, CANADA
Hey all, recently noticed after starting my car that once started and I turn my lights on, I notice the battery light lights up somewhat and then fades away..just the battery light, the dash lights and all else do not dim and no driveability issues..no trouble starting and after it does it from a cold start (even if car was plugged to blockheater for 4hrs it still occurs. After it happens on first start of day I no longer see it occur unless parked for some time. Previous vehicles I know itd be the alternator because the lights would dim when accel or braking and it would just go...my battery was replaced about 8 months ago but alternator is original so I am thinking alternator most likely..i also hear a bit of sound like from a belt, not exactly a whining sound more like a dragging sound hard to explain. The belt is a gatorback that seems firm and appears to move normally when running. I realize I should just test batt and alt with a multimeter but I dont have a garage and its cold out. I certainly will test it in the next couple days but am curious if it could be something minor besides the alt? Is it just an early warning sign that its going out? Obviously this occured now when money is tight, but just wondering if I have much time before I end up stranded...just looking for other possibilities or easy things I can check, if not thats fine, like I said, I know I need to test the alt and battery first with a multimeter. Thanks in advance!
2007 Corolla Red Pearl 155k miles
PP 0w20 & ST 4967
Re: 2007 Corolla; Battery light fading away? [Re: Rolla07] #4606561
12/17/17 08:02 PM
12/17/17 08:02 PM
Upstate NY
Donald Offline
Donald  Offline
Upstate NY
Test the battery with a Midtronics tester or carbon pile load tester. A multimeter is not a great test meter.
If original then test the alternator and replace the battery.
2015 Ford F250 w/Powerstroke
Re: 2007 Corolla; Battery light fading away? [Re: Donald] #4606569
12/17/17 08:08 PM
12/17/17 08:08 PM
MTL, CANADA
Rolla07 Offline OP
Rolla07  Offline OP
MTL, CANADA
Thanks for the advice! Those testers are pricey! The alternator is the original, battery is new. (8 months old)
PP 0w20 & ST 4967
Re: 2007 Corolla; Battery light fading away? [Re: Rolla07] #4606572
12/17/17 08:09 PM
12/17/17 08:09 PM
Toronto
PeterPolyol Offline
PeterPolyol  Offline
Toronto
Belt is slipping when amps are demanded. The fading away is the belt regaining traction on the pulley and driving the alternator more directly. It's a good sign for your battery that it's internal resistance is low enough to cause such demand for said current, but you may need to re-tension or clean the belt/pulley grooves from potential grease contamination. The gatorback has serrated serpentine channels IIRC so perhaps the lower surface area may not be ideal if tension and contamination check out.
There's no replacement...'scosity for natural viscosity
Re: 2007 Corolla; Battery light fading away? [Re: Rolla07] #4606594
12/17/17 08:23 PM
12/17/17 08:23 PM
MIchigan
Warstud Offline
Warstud  Offline
MIchigan
Since the battery light came on when the headlights were turned on I suspect it's the alternator. Have it tested because this may be your only warning to replace it ASAP before you get stranded in the cold.
Re: 2007 Corolla; Battery light fading away? [Re: PeterPolyol] #4606613
12/17/17 08:40 PM
12/17/17 08:40 PM
MTL, CANADA
Rolla07 Offline OP
Rolla07  Offline OP
MTL, CANADA
I wonder if spraying the belt with belt dressing is a good or bad idea...
PP 0w20 & ST 4967
Re: 2007 Corolla; Battery light fading away? [Re: Rolla07] #4606615
12/17/17 08:43 PM
12/17/17 08:43 PM
Upstate NY
Donald Offline
Donald  Offline
Upstate NY
So if belt is slipping maybe a belt tensioner.
Re: 2007 Corolla; Battery light fading away? [Re: Donald] #4606622
12/17/17 08:51 PM
12/17/17 08:51 PM
MTL, CANADA
Rolla07 Offline OP
Rolla07  Offline OP
MTL, CANADA
Yeah, was just thinking that..the belt seems quite firm to me so its odd but this could very well be it..
PP 0w20 & ST 4967
Re: 2007 Corolla; Battery light fading away? [Re: Rolla07] #4606748
12/17/17 11:07 PM
12/17/17 11:07 PM
MTL, CANADA
Rolla07 Offline OP
Rolla07  Offline OP
MTL, CANADA
I checked voltage on the battery and while car running and both normal. 12.78 and 14.26. Checked idler and pulley both were firm and appeared to be solid. Guess thats the extent of my diagnosis skills lol. The belt also appears to be fine.
PP 0w20 & ST 4967
Re: 2007 Corolla; Battery light fading away? [Re: Rolla07] #4606765
12/17/17 11:25 PM
12/17/17 11:25 PM
Ontario Canada
cjcride Offline
cjcride  Offline
Ontario Canada
I'll second the belt tensioner. It is the weak point of that engine.
Re: 2007 Corolla; Battery light fading away? [Re: Rolla07] #4606787
12/17/17 11:43 PM
12/17/17 11:43 PM
Ontario Canada
cjcride Offline
cjcride  Offline
Ontario Canada
Don't spray the belt. I've read it causes problems.
Re: 2007 Corolla; Battery light fading away? [Re: Rolla07] #4606830
12/18/17 12:53 AM
12/18/17 12:53 AM
South Texas
Insertcoolname Offline
South Texas
My original toyota alternator died around 12 years/160,000 miles
Didnt realize the alternator was dying until it was completely gone.
Slow weak start and then Id get going to about
20 mph and die, then the electric starter would kick in, die,
And repeat. I could go about 35 mpH. Just driving like normal except
the car died and turned on then died and turned on lol
This sounds bad, but it worked long enough to get a couple miles to the shop.
Dont be like me lol good luck
04 Camry 2az-fe 209k
M1 5w30
PremiumGuard filter
