New R1250GS and R1250RT
by 02SE. 09/21/18 12:55 AM
Inside Break Booster & Master Cylinder
by StevieC. 09/20/18 11:22 PM
Inside an Alternator
by StevieC. 09/20/18 11:18 PM
What vehicles are you using Maxlife ATF in?
by BlakeB. 09/20/18 11:10 PM
How a Power Steering Rack Works (Electronic)
by StevieC. 09/20/18 11:00 PM
How a Power Steering Rack Works (Hydraulic)
by StevieC. 09/20/18 10:58 PM
silly wiper problem
by bowlofturtle. 09/20/18 10:33 PM
Canadian Tire Shell Rotella T-6 in Pails
by Snagglefoot. 09/20/18 10:04 PM
Best diesel fuel for cold weather?
by Dickm. 09/20/18 10:03 PM
Type 1 Diabetics - New Research
by StevieC. 09/20/18 10:00 PM
Tire Sizing and Options
by NewEnglander. 09/20/18 09:59 PM
2013 Scion FR-S | Transmission Fluid Questions
by nicknak. 09/20/18 09:47 PM
Meguiar's Liquid Cleaner Wax $5 WalMart, Amazon
by The_Cams. 09/20/18 08:42 PM
Winter oil recommendation
by Neptune. 09/20/18 08:27 PM
M1 0W-40
by CT8. 09/20/18 07:37 PM
What controls timing on my 08 Honda?
by Roland. 09/20/18 07:23 PM
The real culprit about 18k
by Ablebody. 09/20/18 06:04 PM
How not to drain a pool.
by StevieC. 09/20/18 05:50 PM
Direct_Rejection, donatom, Sylent_Snyper, Ajizzle, nicknak
66033 Registered Users
27 registered members (Ablebody, Bjornviken, BlakeB, Brad_C, 4 invisible), 813 guests, and 41 spiders.
Topics290,744
Posts4,849,446
Members66,033
Most Online3,590
Jan 24th, 2017
Page 1 of 6 1 2 6
Silverado cold start lifter tick #4606011
12/17/17 09:04 AM
12/17/17 09:04 AM
Nashville, TN, United States
Mossyoakglock Offline OP
What could causes be for a cold start lifter tick? This is a 2008 Silverado with 5.3?
Could it be the oil? Something with better cold pumping properties? I'm currently running PP 5W-30. What about adding seafoam or something to the oil? Is that advised?
I noticed that PP HM has better MRV than the PP (10500 vs 9500). Is that not enough of a separation to make a difference?
Are Castrol Edge and QSUD good choices?
Side note: I did notice that after only maybe 500 I am almost a quart low (more interstate driving than normal) so I want to switch to see if there is another oil that burns less.
2008 Chevrolet Silverado
5.3L / 4L60E
Re: Silverado cold start lifter tick [Re: Mossyoakglock] #4606022
12/17/17 09:21 AM
12/17/17 09:21 AM
NY
demarpaint Offline
demarpaint  Offline
NY
PP is a fine oil. I see you live in TN, you don't have a cold flow problem with that oil. How many miles are on the vehicle, and what kind of oil filter are you using? Burning a quart of oil in 500 miles indicates to me a leak, or a very bad PCV valve, or mechanical issues [sticking rings, or bad valve seals or guides, or all three]. You can do a compression check, and/or a cylinder leak down test, or take the easy route skipping those tests and try Kreen.
Edge and QSUD are good oils, but I don't think they are going to help much. A HM oil might help a little with consumption. I'd check what I mentioned above and consider a Kreen treatment if the PCV checks OK and there are no leaks before I did a compression test or leak down test. I'm lazy. If the rings are sticking Kreen might help.
God Bless Our Troops
Re: Silverado cold start lifter tick [Re: Mossyoakglock] #4606029
12/17/17 09:23 AM
12/17/17 09:23 AM
It won't let me edit my post but I found some numbers for other oils.
PP Platinum PP High Mileage QSUD Castrol
CCS 4000 4100 4930 6000
MRV 10500 9900 12400 35000/40000
Why such a huge different in the numbers for Castrol vs the others?
5.3L / 4L60E
Re: Silverado cold start lifter tick [Re: demarpaint] #4606033
12/17/17 09:27 AM
12/17/17 09:27 AM
I have ~130,000 miles on the truck. It has AFM so it's part of the batch of notorious oil burners due to AFM. I'm using a Wix filter as well. I don't have any other issues, etc. Just the random cold start tick when it's really cold (around 20 degrees). My truck sits in the garage and it doesn't do it when it's been in the garage. It only does it if it's been sitting outside overnight when we are hunting.
Edit: The 08 5.3 does not have a PCV valve either.
5.3L / 4L60E
Re: Silverado cold start lifter tick [Re: Mossyoakglock] #4606037
12/17/17 09:30 AM
12/17/17 09:30 AM
PV Az
AZjeff Offline
AZjeff  Offline
PV Az
Oops. OP knows about AFM issues.
86 Samurai 1.3 leftovers
14 RAV4 2.5 5W-20 PP
16 Silverado 1500 4.3, DI, AFM 5W-30 PP
The most important thing to do in your life is to not interfere with someone else's life. - Frank Zappa
Re: Silverado cold start lifter tick [Re: Mossyoakglock] #4606042
12/17/17 09:38 AM
12/17/17 09:38 AM
NY
demarpaint Offline
demarpaint  Offline
NY
OK so we can safely rule out the PCV valve. I was giving the order I use to check for high consumption, and PCV is high on the list, and used in many applications. I'd probably give Kreen a shot, and see if it helps with the tick and consumption. A HM oil might help, and I'd consider trying a OE oil filter, you could have an issue with the filter causing the tick, it's worth a shot.
Re: Silverado cold start lifter tick [Re: Mossyoakglock] #4606063
12/17/17 10:10 AM
12/17/17 10:10 AM
Central Coast California
RedOakRanch Offline
RedOakRanch  Offline
My 2005 truck had the classic piston slap/tick in the morning when starting at 20-35 degrees. Had the sound for about 2 years, when I changed the oil to BC 0w-30, it went away. Not sure if it really was the oil or if I just lucked out.
1994 Ford Crown Vic 207k-Frankenbrew 0w20,30,40!
2005 Chevy 1500 Crewcab 4X4 180k-BC 0w30 $2/qt
2016 Outback 2.5 Limited 60k-shop brand?
Re: Silverado cold start lifter tick [Re: demarpaint] #4606072
12/17/17 10:20 AM
12/17/17 10:20 AM
wv
krismoriah72 Offline
wv
There are 1000s if not 10s of thousands of posts/threads about this on the net...i have read about 500 of them and gave up lol. Basically if you have a 5.3 you just get used to it.
There are claims of running atf, berrymans and lucas that 'fixed' the problem.. I have 230K on my 2003 and have a buddy that has a 2005 with 425K both have same ticking... but it just seems to be a noise to these great engines.
Re: Silverado cold start lifter tick [Re: Mossyoakglock] #4606079
12/17/17 10:28 AM
12/17/17 10:28 AM
Canada
addyguy Offline
addyguy  Offline
Canada
I'd try something thicker that still works in the cold - M1 0W-40; Edge 0W-40; RT6 5W-40..etc...
Sometimes that seems to help these engines.
2010 Kia Soul 2U - 2.0L I-4, auto; 132k miles.
M1 EP 10W-30; OEM Kia filter.
Re: Silverado cold start lifter tick [Re: Mossyoakglock] #4606086
12/17/17 10:39 AM
12/17/17 10:39 AM
MS
jasonal Offline
jasonal  Offline
MS
I have the lifter tick on my 03 gmc and have considered changing out the lifter. You can get a set of ls7 lifters for about $180. Bad part is you have to pull the heads to change the lifters out. So new head gaskets also along with new torque to yield head bolts.
Re: Silverado cold start lifter tick [Re: Mossyoakglock] #4606101
12/17/17 11:03 AM
12/17/17 11:03 AM
South Florida
bubbatime Offline
bubbatime  Offline
South Florida
Piston slap due to hypereutectic pistons. Nothing you can do unless you swap in new pistons. Try a thicker oil perhaps.
17 Chrysler Pacifica Mobil 1 5W30
13 Yamaha XT250 Valv MC 10W40
12 Suzuki S40 Rotella 15W40
10 Acura TSX 2.4 PZL Plat 5W30
06 GMC Sierra Nextgen 10W30
Re: Silverado cold start lifter tick [Re: Mossyoakglock] #4606104
12/17/17 11:05 AM
12/17/17 11:05 AM
USA
oldhp Online content
oldhp  Online Content
USA
My son-in-laws 2010(?) 5.3 w AFM was doing the same thing. Burning oil, ticking, missing (oil fouled plug). The independent shop soaked the piston/piston rings of the AFM involved overnight. Installed new plugs, turned OFF the AFE system and gave it a Italian tune-up. Everything cleaned up and ran great. Two ways to keep it from happening again. Turn AFM off, they did with a program, OR be sure and change oil every 3K miles. It seems the oil gets burnt onto the ring landings from pumping air only which heats up the piston and rings, which sticks the rings, which starts the oil burning. The truck has since gone over 10K miles since being worked on. ZERO problems and it gets the same mileage. GM knows all about this........
Re: Silverado cold start lifter tick [Re: Mossyoakglock] #4606125
12/17/17 11:31 AM
12/17/17 11:31 AM
5600 feet elevation, Arizona
double vanos Offline
GMs AFM: another technology that brings more misery to the table than intended results. How many have turned this feature off and reported about the same mpg? The day I canít buy a vehicle without cylinder shutdown is the day I go electric.
Sabine Schmitz is the Queen of the 'Ring; Svetlana Kapanina is the Queen of the SKIES...
Re: Silverado cold start lifter tick [Re: Mossyoakglock] #4606200
12/17/17 01:30 PM
12/17/17 01:30 PM
Hudson, NH
LeakySeals Offline
LeakySeals  Offline
Hudson, NH
Adding Seafoam can make ticking worse. save that stuff for your lawn mower. I get that similar ticking/piston slap off and on as well. My 6.0 does it more with PP than it does with Mobil 1. Does it more with a Fram Ultra than it does with the Fram tough guard. So right now its real cold here and it's not doing it at all with a Mobil 1 extended/Fram tough guard combo. Your 5.3 may like that as well. Worth a try next change
06 Escalade 6.0L LQ9 AWD 165k M1 5w30
03 Maxima 3.5L POS 152k ST HM 10w30
Re: Silverado cold start lifter tick [Re: Mossyoakglock] #4606202
12/17/17 01:33 PM
12/17/17 01:33 PM
Ontario, Canada
OVERKILL Offline
OVERKILL  Offline
Ontario, Canada
Castrol often posts just the limits for the grade, not the actual value for their product.
2018 RAM 1500 Big Horn EcoDiesel
2016 Grand Cherokee SRT
Page 1 of 6 1 2 6
