BMW V8 Oil Consumption Fix
by doc540
06/18/18 11:25 AM
More info on Valvoline Modern Engine Oil
by buster
06/18/18 11:07 AM
Shelf life of synthetic 2 stroke engine oil ?
by ScottMill
06/18/18 10:34 AM
Oil sample extraction
by Tikka
06/18/18 10:30 AM
Re-using building materials esp nails
by andyd
06/18/18 08:57 AM
Central A/C [censored] out
by TOMJ
06/18/18 08:43 AM
08 Scion tC under valve cover pics
by Highboy
06/18/18 08:39 AM
Storing extension ladded in garage?
by maverickfhs
06/18/18 08:27 AM
Do you let your tool batteries go dead in storage
by Snagglefoot
06/18/18 07:20 AM
Any news on what happened to this plane?
by Exhaustgases
06/18/18 02:36 AM
E4OD fluid ?
by Exhaustgases
06/18/18 02:23 AM
Update password ?
by meadows
06/17/18 11:59 PM
Delayed Sleep Phase Disorder
by Reddy45
06/17/18 11:56 PM
Nissan DLR put 0w20 in car that specs 5w30. worry?
by CrAlt
06/17/18 10:40 PM
revive Nicd battery
by Donald
06/17/18 10:27 PM
Need help finding an apartment for friend
by RazorsEdge
06/17/18 10:07 PM
ceratec with redline 5w30?
by 08z06
06/17/18 09:53 PM
does your COMCAST modem have weak wifi??
by edwardh1
06/17/18 09:50 PM
I hate stuck thermostats
by jakewells
06/17/18 09:49 PM
Mag1 75w90
by SavagePatch
06/17/18 09:32 PM
WtsTacoma01, Orion62, Revd, blinky1041, mostdecent
65262 Registered Users
87 registered (AndyB, 4WD, 5AcresAndAFool, aquariuscsm, Artem, 1JZ_E46, 9 invisible), 1638 Guests and 43 Spiders online.
65262 Members
67 Forums
285519 Topics
Page 1 of 2 1 2 >
#4605910 - 12/16/17 11:45 PM Cheated me on the grease? WTH
wuntun Offline
Loc: South GA
So I am dipping marine grease out of can with piece of paint stick, and expose a hole the size of a quarter, and there is a cone shaped void all the way to the shiny bottom of the can!!! ???I have probably used 20 cans or so in my lifetime, and have always had full cans, same size.
It is hard to tell from pic, but there is a huge void under that hole. Have I been duped, or is the can WAY too big for the amount of grease they are selling by the weight?
Wuntun
#4605914 - 12/16/17 11:56 PM Re: Cheated me on the grease? WTH [Re: wuntun]
dlundblad Offline
Loc: Indiana
I would think something such as grease would appear partially filled if they intended to sell it as such.
03 Jeep WJ 4.0 199k Castrol Edge 10w40 HM Fram XG16
02 Volvo S60 2.4T 177k M1 0w40 Mahle OX149D
97 Chevy Blazer 4.3 145k Rotella T5 10w30 Fram TG3980
#4605938 - 12/17/17 01:27 AM Re: Cheated me on the grease? WTH [Re: wuntun]
CR94 Offline
Loc: Western S.C. since 1996
Is it underweight?
2011 Toyota Prius now at 88K
#4605953 - 12/17/17 03:54 AM Re: Cheated me on the grease? WTH [Re: wuntun]
demarpaint Offline
Loc: NY
That does seem odd. It is sold by weight not volume, so the only way to know for sure is to weigh it.
God Bless Our Troops
#4605988 - 12/17/17 07:12 AM Re: Cheated me on the grease? WTH [Re: wuntun]
eljefino Offline
Loc: ME
They sell it by weight.
I've used an air powered grease pump with Termaline and the grease sticks to itself such that it forms voids and then the pump starts chugging air.
The answer is to slam the pail, which rarely works. Then I glove up and massage the goop to burp the air out.
#4606031 - 12/17/17 08:26 AM Re: Cheated me on the grease? WTH [Re: wuntun]
MasterSolenoid Offline
Loc: One Step Beyond
They may sell it by 'weight', but their not weighing every can after the filling machine.
Their Filling Machine must of had an air pocket come up thru the hose.
Justice must be done.
I'd call the Company and explain it to them.
They should send you another can of grease.
#4606045 - 12/17/17 08:42 AM Re: Cheated me on the grease? WTH [Re: MasterSolenoid]
Ethan1 Offline
Loc: 'murica
You're right, they probably don't weigh every can. They probably weigh 100 cans and then investigate if it doesn't weigh 100 lbs. So, they basically weigh every can.
#4606151 - 12/17/17 11:12 AM Re: Cheated me on the grease? WTH [Re: Ethan1]
The correct way would be to weigh every can and if one is rejected,
it goes down the reject shute (to be further investigated).
But no big deal, OP just needs to contact Customer Service.
#4606157 - 12/17/17 11:22 AM Re: Cheated me on the grease? WTH [Re: eljefino]
Claud Offline
Loc: Margate England
Stand the pail near somewhere hot, the grease will pool again.
Claud.
#4606283 - 12/17/17 02:01 PM Re: Cheated me on the grease? WTH [Re: wuntun]
Yah-Tah-Hey Offline
Loc: Columbus,Nebraska
Government conspiracy to cheat you out of two dollars. @*&^%$^& Bah Humbug
#4606810 - 12/17/17 11:05 PM Re: Cheated me on the grease? WTH [Re: Yah-Tah-Hey]
wuntun Offline
Loc: South GA
So much lol here, "Then I glove up and massage the goop to burp the air out." "Government conspiracy to cheat you out of two dollars","Justice must be done.
I'd call the Company and explain it to them."
"They should send you another can of grease."
I am not worried about 2 dollars, or that it is not "full" , I believe what ever one is saying, sold by weight. But why not use a smaller can then? Got one pound of grease in a two pound can. And it will not "settle out" as one mentioned, it has seen august heat of over 100 degrees. But i will weigh it,, just outta curiosity.....
Wuntun
#4606935 - 12/18/17 06:47 AM Re: Cheated me on the grease? WTH [Re: wuntun]
SHOZ Offline
Loc: Illinois
I would guess the cans are filled on an automated line that as it spins around the filler tubes go to the bottom, start to squirt in the grease and pull out as the machine rotates. This is all done with cams. Maybe a sticky filler tube or a void int eh grease going to the filler tube and it injected air? No way do the weigh each can.
Use to watch them fill quarts of Miracle Whip at 450 a minute with the mechanical fillers.
2008 Hyundai Accent 1.6L 5 sp manual hatchback
2010 Hyundai Genesis Coupe Track 2L Turbo 6sp manual
#4607971 - 12/19/17 08:40 AM Re: Cheated me on the grease? WTH [Re: wuntun]
ironman_gq Offline
Loc: MN
They probably do weigh every can, modern line equipment is incredibly fast. Even chips are packaged by weight and every bag gets weighed as it's being filled and sealed.
#4610785 - 12/21/17 11:58 PM Re: Cheated me on the grease? WTH [Re: wuntun]
resist Offline
Loc: left cose, USA
Why are you whining here? Take it back and get your money back.
#4611902 - 12/23/17 07:30 AM Re: Cheated me on the grease? WTH [Re: wuntun]
Lubener Offline
Loc: N.Ohio
Caveat emptor. Small things in large packages. Look at coffee, bacon, you name it. Hard to find a one pound package anymore but the package size remaines the same.Trickory is running rampant.
Edited by Lubener (12/23/17 07:30 AM)
The "thinking" man's friend.
Page 1 of 2 1 2 >
