1984 fury 318.
by red7404. 01/20/19 10:48 PM
Dual Wrench (Humor)
by StevieC. 01/20/19 10:33 PM
Got A Tip For Everyone
by NYEngineer. 01/20/19 10:30 PM
Ford Truck (Humor)
by StevieC. 01/20/19 10:10 PM
Lucas and fresh oil
by Ls1z. 01/20/19 09:42 PM
NewEngland vs KC what a 4th quarter/ and OT
by JimPghPA. 01/20/19 09:19 PM
Albuquerque
by pkunk. 01/20/19 09:11 PM
Adding negative camber for trailer towing
by motor_oil_madman. 01/20/19 08:21 PM
Non-working snowblower
by 97prizm. 01/20/19 08:17 PM
Yellow color valvoline ?? Help needed with oil leak....
by seekingbuddha. 01/20/19 08:10 PM
Recommend me a 225/50R17
by redhat. 01/20/19 08:09 PM
Which 5W40 do you like best?
by 21Rouge. 01/20/19 07:50 PM
bike freewheel disabled by the cold
by Number_35. 01/20/19 07:49 PM
Genuine Toyota filter vs PREMIUM GUARD PG5608
by brianw. 01/20/19 07:37 PM
Miles Lubricants
by mobilaltima. 01/20/19 07:27 PM
Cent. Fl oil stash swap?
by RichardS. 01/20/19 06:02 PM
New remote dual system for 5.4 Ford
by JimmyM. 01/20/19 03:34 PM
"I've been everywhere, man..."
by A_Harman. 01/20/19 03:33 PM
Damo5422, Ls1z, Mark963, tommost, Gew
66997 Registered Users
30 registered members (citationxeleven, billt460, anndel, DirtyOilGuy, Cornershop, 3 invisible), 928 guests, and 31 spiders.
Topics296,903
Posts4,961,304
Members66,997
Most Online2,688
Jan 19th, 2019
2 stroke with no power? #4605894
12/16/17 11:10 PM
12/16/17 11:10 PM
Houston, Texas
motor_oil_madman Offline OP
Houston, Texas
I was trying to get my old echo srm210 string trimmer running.This trimmer has two issues. One is it will run great for about 15 minutes, but once it gets good and warm it won't want to restart. The other is that it doesn't make any power. I bought a new trimmer and stopped using it. So far I've replaced the carburetor and fuel lines/fuel filter and cleaned the clogged spark arrestor clean. If I remember right, I couldn't get the muffler off to check the exhaust port on the engine block. That was a while back. I want to say the no restart when hot started after it sat unused for about 2 years.
2007.5 dodge cummins 6.7 liter. Chevron Delo400 15w40. 7000 mile or 250-300hr intervals.
Re: 2 stroke with no power? [Re: motor_oil_madman] #4605897
12/16/17 11:17 PM
12/16/17 11:17 PM
Reunion Island
Superflan Offline
Superflan  Offline
Reunion Island
Do compression test?
Peugeot Partner 1.9 D, 5W40 C3, 245000 Km, running on WVO
Wife's Mitsubishi Outlander PHEV, dealerís overfilled, 16000 Km
Re: 2 stroke with no power? [Re: motor_oil_madman] #4605899
12/16/17 11:19 PM
12/16/17 11:19 PM
out there
spasm3 Offline
spasm3  Offline
out there
Check for spark when its hot. If no spark ignition module/coil unit.
Double check the part number below.
https://www.amazon.com/SHINDAIWA-GENUINE...ords=A411000140
13 elantra 72k 5w30 QSUD
03 chevy avalanche 80k synpwr 5w30
17 mazda cx-5 7300 miles m1 0w30
Re: 2 stroke with no power? [Re: motor_oil_madman] #4605944
12/17/17 02:59 AM
12/17/17 02:59 AM
Slovenia EU
Kamele0N Offline
Kamele0N  Offline
Slovenia EU
+1 for coil test when warm...
For "no power" issue check exaust port...if piston has scratches than carburetor was set too lean in the past...
2008 Toyota Yaris 1ND-TV 1.4 D4-D Elf FullTech FE 5w30
1997 Toyota Landcruiser KZJ95 3.0 TD Shell Rimula R6M 10w40
Re: 2 stroke with no power? [Re: motor_oil_madman] #4605945
12/17/17 03:00 AM
12/17/17 03:00 AM
Reno, Nevada
Langanobob Offline
Langanobob  Offline
Reno, Nevada
When having problems the first step with a two stroke or any small engine is a new NGK spark plug and fresh fuel mix.
Re: 2 stroke with no power? [Re: Kamele0N] #4605990
12/17/17 07:16 AM
12/17/17 07:16 AM
Texas
wag123 Offline
wag123  Offline
Texas
+2
Either a carboned-up exhaust port or low compression will cause your problems. If the exhaust port is open and you see scratches on the side of the piston, you found your problem.
Re: 2 stroke with no power? [Re: wag123] #4606059
12/17/17 09:02 AM
12/17/17 09:02 AM
wv
krismoriah72 Offline
wv
My husqvarna did the same thing to me this past summer.. wouldnt restart after getting warmed up. I ended up dumping the fuel and mixing 32:1 Echo Blend and a few capfuls of stabil marine and run it like i borrowed it.. Japanese Tuneup lol.. Never did it again after that. Mine is 10 years old and has a ton of hours on it i feared i was going to have to buy a new one but that worked for me.
Re: 2 stroke with no power? [Re: krismoriah72] #4606164
12/17/17 11:36 AM
12/17/17 11:36 AM
Texas
wag123 Offline
wag123  Offline
Texas
Since he replaced the carb and other parts, I assumed he was using a FRESH fuel mix (not just fresh from the gas can, fresh from the gas station).
Re: 2 stroke with no power? [Re: motor_oil_madman] #4606574
12/17/17 07:10 PM
12/17/17 07:10 PM
West Central , FL
johnD2 Offline
johnD2  Offline
West Central , FL
did it run fine before you quit using it ?
2000 Silverado Short Wheelbase 4.8 L 4x4
Wix 51522 / Pennzoil HM 10w40
2016 F150 crew cab 5.0 2WD
Wix 57502 / Pennzoil Platinum 5W20
Re: 2 stroke with no power? [Re: motor_oil_madman] #4607002
12/18/17 08:40 AM
12/18/17 08:40 AM
Houston, Texas
Houston, Texas
Yeah it didn't have the hot start problem before.
Re: 2 stroke with no power? [Re: motor_oil_madman] #4607134
12/18/17 11:18 AM
12/18/17 11:18 AM
West Central , FL
johnD2 Offline
johnD2  Offline
West Central , FL
Probably not a spark issue then , but I would put a new NGK in it anyways , they are about $3 at a local shop.
On those older echos , there is a gasket between the carb and the jug , I'd check that to make sure it's not restricting.
Make sure your lines did not get crossed , when you installed the new carb.
Re: 2 stroke with no power? [Re: motor_oil_madman] #4608621
12/19/17 06:55 PM
12/19/17 06:55 PM
Oshawa, Ont. Canada
irv Offline
irv  Offline
Oshawa, Ont. Canada
I'm surprised there is no mention of Sea Foam in this thread? I hate to sound like a nut job talking about this all the time, but the stuff does wonders keeping things clean and enhancing the fuels.
With today's fuels, imo, getting worse due to Ethanol, I find it even more important to use all the time.
https://seafoamsales.com/sea-foam-motor-treatment/
2017 Chevy Impala 3.6 L.
2013 Ram 5.7 L Hemi Bighorn QC 4x4
2008 Chevy Malibu 2.4 L Ecotec
Pennzoil Platinum and/or Pennzoil Ultra Platinum in all 3.
Re: 2 stroke with no power? [Re: irv] #4609053
12/20/17 07:30 AM
12/20/17 07:30 AM
Canada
boraticus Offline
boraticus  Offline
Canada
Keep telling yourself that. One day it might come true.
I drank the elixir Koolaid for a while, Seafoam included. Then I did some actual experiments using Seafoam by soaking carb parts in it. The end results were that it did nothing to remove varnish or clear galleries and jets. Even if left for days. An old toothbrush, a piece of thin wire, Varsol/solvent
and compressed air are far more effective.
Re: 2 stroke with no power? [Re: motor_oil_madman] #4609055
12/20/17 07:36 AM
12/20/17 07:36 AM
out there
spasm3 Offline
spasm3  Offline
out there
So your answer to alcohol in fuel is to add more alcohol?
Seafoam is overpriced alcohol.
Re: 2 stroke with no power? [Re: motor_oil_madman] #4609086
12/20/17 08:15 AM
12/20/17 08:15 AM
Florida
gotnogunk Offline
gotnogunk  Offline
Florida
This may not apply to string trimmers but my echo chainsaw had the same problem and it was a clogged spark arrester screen in the exhaust
system just before the muffler.
