First Paint Correction
by RayCJ. 09/23/18 08:33 PM
2011 Dodge Caliber
by dogememe. 09/23/18 07:48 PM
Mixing transmission fluids - partial change
by spk2000. 09/23/18 07:31 PM
Counterfeit MANN filter???
by IllinoisSparky. 09/23/18 06:54 PM
The smell of an oil: VME adds?
by fdcg27. 09/23/18 06:48 PM
Classic road brake pads
by buck91. 09/23/18 06:18 PM
Air up your vehicle's tires
by Papa Bear. 09/23/18 06:07 PM
A cool litttle Fall foliage site
by Papa Bear. 09/23/18 06:02 PM
Suggestion: "Likes"
by SnowDrifter. 09/23/18 05:36 PM
Condensation in headlights?
by irv. 09/23/18 05:06 PM
Nissan VQ V-6 Engines
by Al. 09/23/18 04:57 PM
List of dexos licensed oils?
by k1xv. 09/23/18 04:24 PM
High flow oil pump? Thinner oil?
by SnowDrifter. 09/23/18 04:06 PM
Is Tiger back?
by gman2304. 09/23/18 03:51 PM
Castrol Edge Pro OE LLIV FE 0W20 for VW508
by BrandonT. 09/23/18 03:33 PM
Value of 90's stereo equipment
by wrcsixeight. 09/23/18 03:28 PM
Wisdom of BITOG'ers wanted- 19 Avalon Hybrid oil
by scion_xb. 09/23/18 02:36 PM
Lilshady, SevenDu, sigpro, RayCJ, yellow97tt6spd
66055 Registered Users
107 registered members (92saturnsl2, Ablebody, antonmnster, 93cruiser, 1.8Tango, alcyon, 11 invisible), 1,657 guests, and 35 spiders.
Topics290,914
Posts4,852,397
Members66,055
Most Online3,590
Jan 24th, 2017
Bunn VP-17 coffee maker problem #4605556
12/16/17 04:59 PM
12/16/17 04:59 PM
Lakeside CA
another Todd Offline OP
Lakeside CA
I volunteer for a 501(c)(3) that raises money for the kids in our community. We have about a half dozen Bunn coffee makers. On our newest one, a VP17-3,3LSST model) the water boils out of the top (it's overheating) spewing steam and hot water from where the top cover meets the body. What will I have to adjust or replace to correct this. I suspect the heater never shuts off, but I am not sure what controls it.
2015 Ford F250 Diesel Crew Cab FX4
2017 Ford Escape 2.0
2002 GMC Yukon
2015 Hyundai Accent
2008 Yamaha Rhino 700 FI
Re: Bunn VP-17 coffee maker problem [Re: another Todd] #4605564
12/16/17 05:05 PM
12/16/17 05:05 PM
Illinois
SHOZ Offline
SHOZ  Offline
Illinois
Sounds more like the output for the water into the filter is clogged. Generally they draw water around the bottom heater plate, that boils and is pushed up a hose and into the filter basket.
The heat should be on or off and not adjustable, probably a timer that turns it off after a while.
I have see the hose melt at the heater end over time, but I suspect that your hose is kinked or something.
You will have to take it apart and see. The hose is probably a 1/4" OD opaque silicone hose.
2008 Hyundai Accent 1.6L 5 sp manual hatchback
2010 Hyundai Genesis Coupe Track 2L Turbo 6sp manual
Re: Bunn VP-17 coffee maker problem [Re: another Todd] #4605601
12/16/17 05:42 PM
12/16/17 05:42 PM
USA
mk378 Offline
mk378  Offline
USA
It is a restaurant style unit. These have a large tank in the back of the machine with a heater inside the tank. The tank is supposed to stay full of very hot, but not boiling, water. When fresh water is poured into the top of the machine, it displaces some hot water out of the tank to a pipe that sends it into the funnel through the coffee grounds, the finished coffee dripping into an empty pot. There is a keep-warm heater under the pot, but unlike a typical home unit, it is not involved in percolating the hot water.
The tank temperature is controlled by a thermostat behind the middle panel facing the front of the machine, behind where the funnel and pot to receive the coffee go. If water is boiling inside the tank, the control thermostat is faulty or set too high. Remove 4 screws to access the thermostat.
If water is coming out where it is not supposed to, remove the top cover and look for a blown seal or broken pipe. It does not look like a complicated machine.
For safety purposes there is an "kilxon" type limit thermostat and fusible wiring on top of the tank. These should never act in normal operation. The brewing temperature is controlled by the more sophisticated thermostat behind the front panel.
www.bunn.com has pdfs of the operating, service, and parts manuals. Click commercial products and manuals.
Re: Bunn VP-17 coffee maker problem [Re: another Todd] #4605632
12/16/17 06:08 PM
12/16/17 06:08 PM
MIchigan
Warstud Offline
Warstud  Offline
MIchigan
I suspect a faulty t-stat. Just unplug it when not in use.
Re: Bunn VP-17 coffee maker problem [Re: another Todd] #4605691
12/16/17 07:15 PM
12/16/17 07:15 PM
Lakeside CA
Lakeside CA
I unplug it after use, but there are 50 other volunteers, and even after being told to unplug it I still find it plugged in.
mk378- it is a restaurant style as you describe. I did find a service manual, but I will attempt to dial down the thermostat first, thanks.
2002 GMC Yukon
2015 Hyundai Accent
Re: Bunn VP-17 coffee maker problem [Re: SHOZ] #4605694
12/16/17 07:16 PM
12/16/17 07:16 PM
Lakeside CA
Lakeside CA
No it works fine, but overheats if you don't brew a pot every 10 minutes or so.
2002 GMC Yukon
2015 Hyundai Accent
Re: Bunn VP-17 coffee maker problem [Re: another Todd] #4605697
12/16/17 07:20 PM
12/16/17 07:20 PM
Ontario, Canada
StevieC Online content
StevieC  Online Content
Ontario, Canada
It's the thermostat in the unit not cutting the power to the heater when it reaches temperature. They usually fail open. I have one of these units at home because I'm a coffee junkie. Took it from my dad's shop when he sold it. (retired)
Coffee2
'18 Highlander - AMSOIL SS 0w20 / ATF / Severe Gear
'06 Santa Fe - 535,000km AMSOIL SS 0w30 / ATF (R.I.P)
Re: Bunn VP-17 coffee maker problem [Re: another Todd] #4605989
12/17/17 08:14 AM
12/17/17 08:14 AM
Glendale, Arizona
billt460 Offline
billt460  Offline
Glendale, Arizona
I've given up on buying these nice "commercial grade" coffee makers. It seems regardless of how much I pay, they never seem to last any longer, and many times not as long as the cheaper units. Another thing I hate is that most all of them have that stupid 2 hour "automatic off" feature. I like to have my coffee hot and available until I decide to shut it off..... Not the unit.
Now I have 2 of the cheapest Mr. Coffee units Wal-Mart sells. ($16.00 each). One for me and one for my wife. We like our coffee differently, and these units allow each of us to have it the way we like.... And plenty of it. And the best part is all they have is an ON / OFF switch. No auto this and that. No clock to set. No automatic programming. Turn it on and it makes coffee, and keeps it hot until you shut it off.
With both of us being retired, we don't need all that garbage. I turn it on when I decide to roll out of the sack. And by the time I brush my teeth, let the dog out, and boot up my computer, it's all brewed and ready to go. And the best part is they are cheap enough to where we keep 2 extra units in stock, ready to go. That way when one takes a dump, all we have to do is unplug it, toss it, and plug in a new one. Pretty hard to beat.
Re: Bunn VP-17 coffee maker problem [Re: another Todd] #4606015
12/17/17 09:11 AM
12/17/17 09:11 AM
Orlando, FL
Mr Nice Offline
Mr Nice  Offline
Orlando, FL
I just need something very basic to make my coffee, no silly expensive coffee maker.
Re: Bunn VP-17 coffee maker problem [Re: another Todd] #4606026
12/17/17 09:22 AM
12/17/17 09:22 AM
USA
mk378 Offline
mk378  Offline
USA
The OP's machine is serving about 50 users. A $16 Mr Coffee is not appropriate for that application.
Re: Bunn VP-17 coffee maker problem [Re: mk378] #4606193
12/17/17 01:15 PM
12/17/17 01:15 PM
Glendale, Arizona
billt460 Offline
billt460  Offline
Glendale, Arizona
Buy 10 of them for $160.00. That's 120+ cups.
Re: Bunn VP-17 coffee maker problem [Re: another Todd] #4608613
12/19/17 07:49 PM
12/19/17 07:49 PM
Nashville, TN via Memphis
john_pifer Offline
john_pifer  Offline
The problem with the cheap Mr. Coffee-type units is that they over-extract the grounds by drizzling the water through too slowly because they heat the water as it flows through. That makes the coffee taste harsh and bitter.
A BUNN, in comparison, has a tank that holds the water hot all the time, at the perfect temp - around 200*.
When you brew the coffee, it floods the water through the grounds quickly, doing a perfect extraction - not over or under-extracting it. And it makes a full pot in under 3 min.
It tastes no different than the coffee you get at a cafe.
16 WRX - PPPP
07 Tacoma V6 - M1 EP 5W-30, Fram Ultra, 10K OCIs, 198K
07 Yamaha R1 - Rotella T6 5W-40, Bosch 3300
07 Yamaha YZ-250, Klotz, Rotella
