Mater Mechanic Motor Oil @ True Value
by CG_BrianM. 03/20/19 01:35 PM
Some cars haven't changed much in 30 years...
by addyguy. 03/20/19 01:16 PM
Super Knock - Engineering Explained
by StevieC. 03/20/19 01:11 PM
Mobil Super Synthetic Clearance at Meijer
by Tjbouwhu. 03/20/19 12:53 PM
FYI: Costco is now stocking the 'good' Techron
by mbz321. 03/20/19 12:32 PM
Auto maintenance advice from a locksmith?
by Variant_S. 03/20/19 12:18 PM
Purolator 12 Pack L25608 $21
by hatt. 03/20/19 12:04 PM
Dealer service and franchise laws.
by BMWTurboDzl. 03/20/19 11:46 AM
Tie rod tapers
by LeakySeals. 03/20/19 11:26 AM
Quality Lug Nuts
by jcartwright99. 03/20/19 10:56 AM
More than one Reality
by beanoil. 03/20/19 10:50 AM
Reusable Oil Storage Container
by BamaE92. 03/20/19 10:37 AM
Bank 1 on an Equinox
by Washoe_Mark. 03/20/19 08:47 AM
How do you pronounce the word Vehicle?
by ZZman. 03/20/19 08:21 AM
Inline Fuel Filter
by CCI. 03/20/19 08:08 AM
Are All Douglas Tires USA Made?
by Miller88. 03/20/19 07:30 AM
Turn signal bulbs for '15 BMW?
by Benzadmiral. 03/20/19 07:02 AM
Saxman657, Maxxforce, Washoe_Mark, CG_BrianM, TBF
67565 Registered Users
119 registered members (2015_PSD, 555, 97f150, 69Torino, 2012AccentSE, 64bawagon, 16 invisible), 2,108 guests, and 59 spiders.
Topics286,156
Posts4,903,136
Members67,565
Most Online2,967
Mar 10th, 2019
100K mile maint plan for 2008 Toyota solara #4605504
12/16/17 04:17 PM
12/16/17 04:17 PM
Colorado
digger327 Offline OP
Colorado
Okay, my son just picked up a 2008 Toyota solara with 4 cylinder azfe engine and U250 transmission (I think)
We changed oil and did transmission drain/fill. Did some reading realized that year transmission uses a felt filter (face palm), Okay will do another drain/fill with filter change at 100K (Valvoline Maxlife).
So at 100k plan to
- Replace water pump (OEM gotta love rockauto)
- Replace coolent and hoses
- Change oil (Pennzoil Platinum 0w20)
- Change filter (Fram Ultra)
- Change Diff fluids
- New PCV valve
Do I need to add anything to list?
Re: 100K mile maint plan for 2008 Toyota solara [Re: digger327] #4605513
12/16/17 04:24 PM
12/16/17 04:24 PM
Richmond, VA
Barkleymut Offline
Barkleymut  Offline
Richmond, VA
Spark plugs and wires
09 Vue(95K) 2.4 4spd AT -PU 5w30 / 09 Flex(52K)3.5L PU / Moms car 04 Pilot(105K) 5w20 PP + Puro
Re: 100K mile maint plan for 2008 Toyota solara [Re: Barkleymut] #4605519
12/16/17 04:27 PM
12/16/17 04:27 PM
Colorado
Colorado
Was planning replacing plugs and wires at 120k with Valve adjustment. The Toyota VVT does need valve adjustment right?
Re: 100K mile maint plan for 2008 Toyota solara [Re: digger327] #4605526
12/16/17 04:31 PM
12/16/17 04:31 PM
Tennessee
OTCW Offline
OTCW  Offline
Tennessee
If you are doing water pump, coolant, and hoses, I'add thermostat as well.
2017 Nissan Sentra 1.8L 11k miles
2004 Nissan Frontier 2.4 L 199k miles
2012 Yard Machines 21 in 140 cc
2001 Weedeater Featherlite Plus 21 cc
Re: 100K mile maint plan for 2008 Toyota solara [Re: digger327] #4605544
12/16/17 04:48 PM
12/16/17 04:48 PM
OH
SatinSilver Offline
SatinSilver  Offline
OH
The oem hoses can last a very long time and shouldn't be replaced unless they are leaking, very soft, etc. Not like the hoses of years ago. The hoses can last the life time of the car. But once you put aftermarket ones on then you'll need to keep changing them out regularly.
Re: 100K mile maint plan for 2008 Toyota solara [Re: SatinSilver] #4605554
12/16/17 04:57 PM
12/16/17 04:57 PM
Central Virginia
Silverado12 Offline
Silverado12  Offline
Central Virginia
Except for the upper radiator hose. From my experience this is the first one to fail. I haven't seen any quality difference between a new premium quality hose and OEM.
12 Chevy Silverado ext. cab LS, 2WD 4.3 auto
18 Mustang GT 5.0 auto
07 Harley Dyna Street Bob 96 c.i. 6 sp.
00 Mustang GT auto
Re: 100K mile maint plan for 2008 Toyota solara [Re: digger327] #4605585
12/16/17 05:31 PM
12/16/17 05:31 PM
CA
The Critic Offline
The Critic  Offline
CA
Brake Fluid, Trans Fluid and Coolant. Oil change if due. It probably needs Drive Belt at that mileage.
Plugs are not due until 120k.
Leave all of the other items alone unless there is a problem.
2011 Toyota Prius 1.8L - 185K - SuperTech Dexos Full Syn 0W-20
2007 Honda Accord 2.4 - 135K - Mobil 1 EP HM 5W-30
Re: 100K mile maint plan for 2008 Toyota solara [Re: digger327] #4605602
12/16/17 05:43 PM
12/16/17 05:43 PM
Jupiter, Florida
Cujet Online content
Cujet  Online Content
Jupiter, Florida
A 10 year old car may need calipers and emergency brake work. By 10 years, corrosion tends to worm it's way in many calipers.
Re: 100K mile maint plan for 2008 Toyota solara [Re: digger327] #4605622
12/16/17 06:02 PM
12/16/17 06:02 PM
Kalifornia Kollective
BrocLuno Offline
BrocLuno  Offline
How's the front end? Joints, boots, etc.
Re: 100K mile maint plan for 2008 Toyota solara [Re: digger327] #4605653
12/16/17 06:35 PM
12/16/17 06:35 PM
WI
HoosierJeeper Offline
WI
If the new hoses are EPDM they'll be OEM quality. I'd leave them if they feel ok. My 07 LR3 is still rocking OE hoses and I'm not worried about it. I did however swap them on my Liberty as I had a crunchy feeling and bulge in the upper.
15 Jeep KL Limited V6: Formula Shell 5W20
07 LR3 SE V8: Maxlife 5W30
05 Jeep KJ Limited: PHM 5W30
96 Jeep XJ Country: STP HM 5W30 (winter)
Re: 100K mile maint plan for 2008 Toyota solara [Re: digger327] #4605726
12/16/17 07:44 PM
12/16/17 07:44 PM
MTL, CANADA
Rolla07 Offline
Rolla07  Offline
MTL, CANADA
Dont bother with a water pump just yet. Replace coolant and keep going. They will start to seep a bit when its time to change it. Im still on my original water pump at 151k. All the rest of ur plan looks good. If you replace it anyways agree with other poster, change t stat at same time.
2007 Corolla Red Pearl 155k miles
PP 0w20 & ST 4967
Re: 100K mile maint plan for 2008 Toyota solara [Re: digger327] #4605756
12/16/17 08:10 PM
12/16/17 08:10 PM
NC
BigD1 Offline
BigD1  Offline
NC
If you can get your hand on the water pump, give it a good tug up and down and side to side to see if it has any play. If it has any play, I would definitely change it.
1992 Toyota Pickup--PYB 10W-30--Fram PH3614
Re: 100K mile maint plan for 2008 Toyota solara [Re: digger327] #4605832
12/16/17 09:58 PM
12/16/17 09:58 PM
Toronto
dgunay Offline
dgunay  Offline
Toronto
No need to change the water pump, just check the pulley by hand and see if there is any play. If not, just drain and fill the coolant.
2009 Acura CSX - PUP 0w20 / Fram XG7317 / Maxlife ATF
2018 Kawasaki Z650 - Motul 4T 5100 10w40 / OEM Oil Filter
Re: 100K mile maint plan for 2008 Toyota solara [Re: digger327] #4605980
12/17/17 07:50 AM
12/17/17 07:50 AM
ROCHESTER, NY
Char Baby Offline
Char Baby  Offline
ROCHESTER, NY
Well, maybe these engines need a valve adjustment but, those folks I know with same engine and/or vehicle, have never done a valve adjustment in 250K-300K miles.
"Retired"
'15 Nissan Altima 2.5 SV
'15 Honda Civic LX
Re: 100K mile maint plan for 2008 Toyota solara [Re: Char Baby] #4606002
12/17/17 08:53 AM
12/17/17 08:53 AM
IL
lukejo Offline
lukejo  Offline
IL
We've had 7 Camry's and Corolla's ranging from 1995 to 2012 model years. Owned all past 200k, three past 300k. Not a single OEM hose was ever replaced nor valve adjustment. Sold or traded all (except two we have now) while still running and driving like new. Ive always stretch TB to 150k. For those without timing belt, never replaced a single water pump. We keep up with all fluid changes religiously...and only use OEM fluids except for motor oil. (Even though I agree with Amsoil in your tran.)
So....sure, follow maintenance plan, but don't waste time on "elective surgery" for things that seem okay (hoses). From our long track record of performance, I just don't see any need on these wonderfully boring Toyotas.
If your son puts on a lot of miles, start saving for struts.
