Duckham's 15w50 Oil 12 one liter bottles
by Lolvoguy
06/24/18 12:00 AM
Ruger LCP .380
by PW01
06/23/18 11:24 PM
Launching boat with stick shift
by troutfisher
06/23/18 11:22 PM
Free oil
by Spitter
06/23/18 10:53 PM
Porsche Panamera buying advice
by CharlieBauer
06/23/18 10:04 PM
RC cars
by red7404
06/23/18 09:36 PM
Any Good 4K Movies ?
by Warstud
06/23/18 09:06 PM
Gray on Oil Dipstick?
by chinee
06/23/18 08:41 PM
Clear plastic scratch remover?
by Quattro Pete
06/23/18 08:15 PM
Parking wars show.
by Chris142
06/23/18 08:15 PM
set for years
by 93cruiser
06/23/18 08:07 PM
Looking to replace 2005 Sienna with SUV
by i6pwr
06/23/18 07:26 PM
Trying to fix chainsaw
by turtlevette
06/23/18 06:48 PM
tire rotation
by marine65
06/23/18 06:48 PM
Reese hitch $30 Walmart YMMV
by pda1122
06/23/18 06:14 PM
Managing Anger During Unexpected Tire Change
by TheLawnRanger
06/23/18 06:14 PM
2016 Honda Pilot appears to be consuming oil
by pilot1226
06/23/18 06:00 PM
New belt squeal cause damage to belt?
by pda1122
06/23/18 05:33 PM
Food Safety - If You Have Children
by Zee09
06/23/18 05:15 PM
Reduce TORQUE to COMPENSATE for lubed threads?
by SumpChump
06/23/18 05:02 PM
bwechols, bowupid, pod423, lemaitrix, azzid0906
65303 Registered Users
52 registered (bbhero, alphadog, 4WD, cb4017, boulderdentist, 3 invisible), 1060 Guests and 33 Spiders online.
65303 Members
67 Forums
285886 Topics
#4605311 - 12/16/17 11:28 AM Brake Fluid Testers
FlyPenFly Offline
Loc: San Diego
How accurate and effective are tools like this?
https://www.amazon.com/gp/product/B06Y42GSDW/ref=oh_aui_search_detailpage?ie=UTF8&psc=1
If you're just testing the fluid reservoir, is that accurate enough?
I have 2 vehicles, both with fluid factory 3.5 years old and they pass fine. Curious if that's accurate or what.
2014 Mercedes GLK350 3.5L DFI
2014 Mercedes E350 Coupe 3.5L DFI
2007 Suzuki Grand Vitara 2.7L V6
#4605316 - 12/16/17 11:39 AM Re: Brake Fluid Testers [Re: FlyPenFly]
69GTX Offline
Loc: Connecticut
I had my car's 13 year old brake fluid tested with strips at a Quick Lube place...and they told me it was still "good." In any event, I ended up changing it myself a few months later. I don't know how test strips can tell how much water or oxidation is present in the brake fluid.
2001 Lincoln Cont 4.6L DOHC/ 39K mi / QS HM 5w30 / FUG XG2
1969 Ply GTX/RRs
#4605318 - 12/16/17 11:42 AM Re: Brake Fluid Testers [Re: FlyPenFly]
DBMaster Offline
Loc: DFW
I'm curious about this, too. I have a similar tester that indicates my fluid is still good after 5.5 years and 83,000 miles. The fluid in the MC still looks straw colored. The tester measures moisture content in the fluid through conductivity.
#4605328 - 12/16/17 11:55 AM Re: Brake Fluid Testers [Re: FlyPenFly]
Superflan Offline
Loc: Reunion Island
Ok hereís what I think. Since thereís no cycling of fluid in the reservoir, the quality of fluid in the lines, abs actuators and calipers are undetermined.
Yet, on modern cars, pistons calipers are designed to not conduct heat generated when braking to the fluid, therefore claiming that no replacement is necessary during the normal life of the vehicle.
I had results confirming this on some cars, but on a car where I got brake vapor lock the test clearly showed a lowered boiling point of 120 degrees centigrade
Yaris 1.0 201mkm 5W40 ACEA A3/B4
Kangoo 1.5 DCi 15W40 ACEA E7
Wife's Koleos 2.0 dCi DPF 6AT eco-map 162mkm 5W40 C3
#4605330 - 12/16/17 11:57 AM Re: Brake Fluid Testers [Re: FlyPenFly]
FlyPenFly Offline
Loc: San Diego
I guess there's an underlying assumptions here then: Moisture is the only reason to change brake fluid, is that true?
Flushing the brakes and testing the old fluid that comes out of the calipers also seems to be another data point to verify.
#4605333 - 12/16/17 12:00 PM Re: Brake Fluid Testers [Re: FlyPenFly]
E150GT Offline
Loc: San Antonio, TX
I have one of those cheap pens. I tested new brake fluid and it tested good. I took a small sample and added some water and it tested bad. I tested the reservoir in a 2003 tundra and it showed good. It looked terrible though.
1984 Mercedes-Benz 300SD - 100k
1995 F150 XL 4.9 reg cab 5MT - 250k 5w30
2016 Mazda6 Touring 6MT - 56k 10w30
#4605342 - 12/16/17 12:24 PM Re: Brake Fluid Testers [Re: FlyPenFly]
BHopkins Offline
Loc: Utah
I've also had the same question about the similar brake fluid tester that I own.
My plan is to mix up a test solution - 20 ml of fresh brake fluid with 1 ml of water for a 5% moisture solution, and see what results I get with the tester. Perhaps this might be something I can to this afternoon.
2013 Subaru Outback 2.5i - Royal Purple 0W-20 & NAPA Gold filter
2003 Oldsmobile Alero 3.4 - M1 5W-30 & NAPA Gold filter
#4605362 - 12/16/17 12:50 PM Re: Brake Fluid Testers [Re: FlyPenFly]
Marco620 Offline
Loc: Deplorable Kansan,HK fan!
Dont have a tester but the Honda light will come on telling me brake fluid exchange is necessary.
2015 Civic 162k mi.0w20 Redline/Archoil,HPS SRI,Yokohama/Moog links Borla Exhaust/Vibrant Resonator/Tein Suspension
Go Nashville Predators!
#4605416 - 12/16/17 01:36 PM Re: Brake Fluid Testers [Re: FlyPenFly]
Ethan1 Offline
Loc: 'murica
I'm surprised to hear the mixed reviews of the testers, because I never had reason to doubt the concept of testing resistance as a way to extrapolate H2O content. confused
#4605422 - 12/16/17 01:49 PM Re: Brake Fluid Testers [Re: FlyPenFly]
i_hate_autofraud Offline
Loc: Canada
It's more then H2O content, it's also oxidation and seal material wearing and clouding the brake fluid,
eventually this material precipitates and sticks to cylinder bores and cuts into seals when pistons are
pushed back to allow new pads to fit. Seen it!
Replace on a 2 or 3 year cycle is a safe bet compared to replacing an ABS unit when it malfunctions and stores
a pesky code! At that point you have 'regular' brakes!
For that reason, I don't use a brake fluid tester.
#4605428 - 12/16/17 01:59 PM Re: Brake Fluid Testers [Re: FlyPenFly]
Warstud Offline
Loc: MIchigan
The test strips test for copper because : as your brake lines corrode.... more copper ends up in the fluid.
The test pens test for water.
#4605665 - 12/16/17 05:50 PM Re: Brake Fluid Testers [Re: FlyPenFly]
Hemispheres Offline
Loc: Virginia
Itís a good idea to change it a every few years due to crud more than moisture. Remove 1/3 of the fluid from resivior, fill back up and remove another 1/3 then vacuum bleed. Keeps the pistons and lines in good shape internally.
2009 Buick LaCrosse (3800 Series III) - 137,000 miles.
PZ Plat HM/Mobil 1 HM
Bosch/Purolator/Mobil filters
#4606308 - 12/17/17 02:27 PM Re: Brake Fluid Testers [Re: FlyPenFly]
barryh Offline
Loc: Cheshire, England
As far as water content is concerned I would say a reservoir test is representative. The hydroscopic nature of brake fluid will ensure any moisture diffuses throughout the whole system. As already mentioned there are other reasons to change brake fluid. I would want a test to show when the corrosion inhibitors had been used up but I suspect a reservoir test for that might not be representative of the whole system.
Barry
1979 BMW R45 (Triple QX 5W40)
2009 Mercedes C180K (Shell Helix Ultra 5W40)
