Interior "quick detailer"
by Redright9. 03/25/19 08:21 AM
Seafoam For Last 100 Miles Before Oil Change ?
by ChrisD46. 03/25/19 07:56 AM
WIX 57151XP factory filled with synthetic oil
by Donald. 03/25/19 06:58 AM
BMW Buying Guide: Every Model, Explained
by wemay. 03/25/19 05:43 AM
Double Din Android Auto Advice
by JeffKeryk. 03/24/19 11:25 PM
VW mk5 a/c intermittently works
by ram_man. 03/24/19 11:01 PM
DIY alignment done right?
by tookien. 03/24/19 10:03 PM
Cell phone privacy question
by loneryder. 03/24/19 10:00 PM
Ride quality between 45 and 35 sidewall
by bowlofturtle. 03/24/19 09:23 PM
FRAM TG 7317 - 12K miles opened
by crazy_raccoon. 03/24/19 09:01 PM
2014-2017 Toyota Corolla CVT Quiet Recall
by StevieC. 03/24/19 08:11 PM
Finally Found Factory Ammo my 308 Bolt Gun Likes
by Fastzntn. 03/24/19 08:10 PM
Umarex Glock 19 Co2
by Sonic. 03/24/19 07:57 PM
I put in 2 1/2 qts, damage?
by JLawrence08648. 03/24/19 07:21 PM
How to dispose / recycle Li-Ion batteries?
by 92saturnsl2. 03/24/19 06:16 PM
New member of the (automotive) family!
by addyguy. 03/24/19 06:04 PM
sonusfaber, Rollo, Drifted, Jcar516, gregjr7
67614 Registered Users
80 registered members (avi1777, ARCOgraphite, Bailes1992, BeerCan, Blkstanger, Berny, 8 invisible), 1,622 guests, and 59 spiders.
Topics286,387
Posts4,907,333
Members67,614
Most Online2,967
Mar 10th, 2019
Plating moly in engine oil. a desireable trait? #4605185
12/16/17 10:18 AM
12/16/17 10:18 AM
MT
Dieselfume1 Offline OP
MT
Watched a demo last night on Schaeffer 15w-40 w/ moly. It would plate up on the roller when others would not, just like a moly grease. My question is, is having a moly that plates up a desirable trait to have on the inside of an internal combustion engine? I kinda figure if there's no oil long enough the the moly to plate up, you've got other problems.... I also know that Molybdenum disulfide is a type of clay..... Again, doesn't bother me in a grease, but in an engine?
Opinions?
Re: Plating moly in engine oil. a desireable trait? [Re: Dieselfume1] #4605190
12/16/17 10:24 AM
12/16/17 10:24 AM
Upper Midwest
kschachn Offline
kschachn  Offline
Upper Midwest
Opinions?
If you search around on this site a bit, there are hundreds if not thousands of posts on moly in motor oil. Take a look, you will get opinions there.
And just to start you off, molybdenum disulfide is a different compound than what is used in most motor oils. Look up the difference.
1994 BMW 530i, 241K
1996 Honda Accord, 267K
1999 Toyota Sienna, 409K
2000 Toyota ECHO, 280K
Re: Plating moly in engine oil. a desireable trait? [Re: Dieselfume1] #4605249
12/16/17 11:01 AM
12/16/17 11:01 AM
PimTac Offline
PimTac  Offline
Most oils have moly in them for anti-friction purposes. The exception would be Valvoline which uses a secret sauce so to speak. Moly is just one of several options for motor oil. Which oil are you running now in your vehicles? You can then search the uoa and voa sub forums here to get a general idea.
Cannot see signatures any longer so it doesn’t matter.
Re: Plating moly in engine oil. a desireable trait? [Re: Dieselfume1] #4605269
12/16/17 11:35 AM
12/16/17 11:35 AM
Upper midwest
Mainia Offline
Mainia  Offline
Upper midwest
Yea "load up my rings" not the best I would think.
Re: Plating moly in engine oil. a desireable trait? [Re: Dieselfume1] #4605360
12/16/17 01:49 PM
12/16/17 01:49 PM
MT
MT
I've run many oils. Mobil 1 is one of the long time ones I've used. Recently been switching farm equipment as well as autos over to TRC's Moly XL Pro-Spec 3
I know they run a type of non plating micro-moly, but I'm not familiar with this type that Schaeffers is running.
Makes me wonder about what a plating moly could do to those tight fitting tolerances like crnak/rod bearings, valve guides, valve last, piston skirt/ring gaps? The fact that the schaeffer guy proved that it plated up like a moly grease on the load test machine tells me that their moly is different than others, and maybe not in a good way?
Re: Plating moly in engine oil. a desireable trait? [Re: Dieselfume1] #4605469
12/16/17 03:47 PM
12/16/17 03:47 PM
Michigan
ZZman Offline
ZZman  Offline
Michigan
I thought the advantage of moly is the plates rub against each other saving metal contact?
2003 Mercury Grand Marquis. PP HM 5w-30 and Fram TG
2008 Sebring Hardtop convertible. PP HM 5w-30 and Fram Ultra
2006 Kawasaki Vulcan 900 LT. Motul 7100 10w-40 and K&N
Re: Plating moly in engine oil. a desireable trait? [Re: Dieselfume1] #4605683
12/16/17 07:12 PM
12/16/17 07:12 PM
MT
MT
That is the way I understand it. But in areas where there's thousandths of an inch of tolerance between turning free and binding, I'm not how sure I am that I want anything plating up in those areas.
Most engine oils with moly are a micro/liquid non settling moly. It appears that this Schaeffers stuff has both.
Re: Plating moly in engine oil. a desireable trait? [Re: ZZman] #4605820
12/16/17 09:41 PM
12/16/17 09:41 PM
Canyon County Idaho
CT8 Offline
CT8  Offline
Canyon County Idaho
I would think plating is actally the wrong definition of Molys actions in motor oils.
2015 Ford F150 2.7
2018 Ford F350 6.2
Re: Plating moly in engine oil. a desireable trait? [Re: CT8] #4605845
12/16/17 10:26 PM
12/16/17 10:26 PM
Malaysia
zeng Offline
zeng  Offline
Malaysia
+1
Re: Plating moly in engine oil. a desireable trait? [Re: Dieselfume1] #4605849
12/16/17 10:39 PM
12/16/17 10:39 PM
MT
MT
How else would you put it when the Schaeffer salesman puts their moly 15w-40 on the roller, turns it on, lets it squeal, and then when it quiets down he says it's because the moly has "plated up" ?
Re: Plating moly in engine oil. a desireable trait? [Re: Dieselfume1] #4605879
12/16/17 11:45 PM
12/16/17 11:45 PM
'Stralia
Shannow Offline
Shannow  Offline
'Stralia
Engine surfaces on engine surfaces is bad.
The additives (Zinc, and Mo, and other stuff) for tribofilms on wearing surfaces...Zinc forms zinc phosphate iron oxide "glassy" like structures, which are on top of the wearing metal surfaces.
So yes, in time, with heat, temperature and rubbing contact, something "plates" the surfaces (*).
The moly creates a tribofilm with little pockets of MoS2...teflon additives can end up in there too.
So Schaeffers aren't in any way unique...
I take it you had a demonstration of the Timken test machine, aka "the one armed bandit".
It's a sales tool, and it's sold a LOT of oil (I know, I've been fooled before, and people still are with RAT540 and his blog).
(*) When their oil performance like nothing else did, replay what was happening at the time. Salesman would have tested a bunch of oils, put them in, loaded them up, and they failed.
While telling you about how great Schaeffers was, the machine was running. the surfaces there there together. A couple of "pulses" on the handle while fluffing on about the superiority of the oil, it's had 35-40 seconds of friction to build some heat in the rubbing surfaces, and start the surface activity for the tribofilms.
Then he leans on it, not in a jerky fashion, but a slow and steady load-up, and miraculously the oil does amazingly compared to it's peers.
Re: Plating moly in engine oil. a desireable trait? [Re: Dieselfume1] #4605889
12/17/17 12:02 AM
12/17/17 12:02 AM
'Stralia
Shannow Offline
Shannow  Offline
'Stralia
Here, look at this one, and see how it's treated differently...
And the process discussed here...
Re: Plating moly in engine oil. a desireable trait? [Re: Shannow] #4605991
12/17/17 08:19 AM
12/17/17 08:19 AM
Upper Midwest
kschachn Offline
kschachn  Offline
Upper Midwest
Wow what a joke. And I’d trust that other manufacturer why?
That Amsoil video perfectly shows the utter deception of that test and of that one website.
1994 BMW 530i, 241K
Re: Plating moly in engine oil. a desireable trait? [Re: Dieselfume1] #4606028
12/17/17 09:23 AM
12/17/17 09:23 AM
MT
MT
thanks for sharing, very informative!
Re: Plating moly in engine oil. a desireable trait? [Re: Shannow] #4606211
12/17/17 01:43 PM
12/17/17 01:43 PM
Rio Rancho, NM
Pajero Offline
Pajero  Offline
Rio Rancho, NM
Informative. Thanks Shannow
Respectfully,
Pajero!
Always remember "Planned obsolescence."
1994 Montero SR 3.5 DOHC, 133,xxx
Fram Ultra/ Snorkel with Pre-filter
K-9-Co-pilot
