2015 MB GLA250: OEM oil vs Mobil1 Formula M
by SlavaB. 12/17/18 12:39 AM
Shotgun Ammo
by user52165. 12/16/18 10:24 PM
Bought a Model 3 for wifey
by JeffKeryk. 12/16/18 09:01 PM
Maybe I'm crazy.
by TRDPRO85. 12/16/18 07:50 PM
Pacer EON E-11 Synthetic Motor Fluid
by Brandon9797. 12/16/18 07:46 PM
Reuse transmission fluid??
by FFeng7. 12/16/18 07:35 PM
Amsoil SS color change
by BigShug681. 12/16/18 07:21 PM
Why don't owner's manuals specify the oil type
by OilUzer. 12/16/18 07:13 PM
belt tensioner problems
by mobilaltima. 12/16/18 06:57 PM
How bout them Patriots
by 53' Stude. 12/16/18 06:36 PM
Hand held Ham radio suggestions
by littleant. 12/16/18 05:20 PM
Ford 2.3 EB's using 87 vs 91/93 octane
by Whimsey. 12/16/18 04:48 PM
Oil analysis pump tube?
by maximum6. 12/16/18 03:56 PM
Mahle charcoal lined filter..the best!
by TiGeo. 12/16/18 03:45 PM
Diesel engines and emissions
by spasm3. 12/16/18 03:31 PM
Experiment time
by 53' Stude. 12/16/18 02:52 PM
stantaur, Brandon9797, Landngroove, DanielH, Cpcz9382
66700 Registered Users
32 registered members (bbhero, 1345, Ag76, billt460, andyd, 4 invisible), 1,111 guests, and 45 spiders.
Topics295,170
Posts4,929,097
Members66,700
Most Online2,553
Oct 27th, 2018
Page 1 of 4 1 2 3 4
The highly debated ATF engine flush... #4604786
12/15/17 06:27 PM
12/15/17 06:27 PM
in the shop
sw99 Offline OP
sw99  Offline OP
in the shop
On the highly debated topic of the AFT engine flush here are my primitive recent results...
Anyhow, I am a big fan of these if one knows the maintenance history of the vehicle they are flushing. Here is my example; Our 2012 Honda Civic with 147k miles on it. We have owned this since new and I have been fairly religious about the maintenance. I usually use the maintenance minder on the car which comes in at around 8k at the 15% notice. I have done 2 or 3 10-12k runs on quality full synthetic oils that were sent off for UOA's. 90% of the OCI's were full synthetic 0w20 or 5w20. I have run maybe two or three conventional 5w30 runs at shorter 5-7k intervals.
So this brings me to the flush. The ATF flush I use had evolved a bit over the years. I like the ATF since it has lubrication properties unlike kerosene. My most recent flush consisted of;
-2.5 quarts of ATF (1.5 quarts of ST ATF and 1 quart of ST ATF+4)
-1 quart Motor Medic engine flush
-Approximately 4-6 ounces of ST engine stabilizer (Walmart's version of Lucas)
Here is my primitive theory... 1) Motor medic for the cleaning portion. 2) ATF to lubricate and show the color change from the bright red. 3) The oil stabilizer to thicken it all up a little bit.
The car was driven about 50 miles and the old oil was drained and filter removed. Everything drained for 30-40 minutes. A new sacrificial filter was installed and the cocktail added. The engine was run at idle for 20 minutes and then drained.
I am actually very surprised at how dirty the fluid was that came out considering that the engine looks spotless through the fill hole on the top end. In my opinion, this flush works. Just my .02 on the age old topic.
2016 Nissan Versa S 1.6L
2018 Subaru Outback 2.5i
2019 Ford F250 6.7L CCSB
Re: The highly debated ATF engine flush... [Re: sw99] #4604813
12/15/17 06:53 PM
12/15/17 06:53 PM
Richmond VA, Washington DC
johnchui1984 Offline
Hello again! Do you feel the car being smoother after doing the flush?
2016 Nissan Versa S-Plus CVT
Castrol Magnatec + Fram Ultra
Re: The highly debated ATF engine flush... [Re: sw99] #4604819
12/15/17 06:58 PM
12/15/17 06:58 PM
in the shop
sw99 Offline OP
sw99  Offline OP
in the shop
Not really but this engine has been super smooth since day one.
Re: The highly debated ATF engine flush... [Re: sw99] #4604821
12/15/17 07:03 PM
12/15/17 07:03 PM
Specific Ocean
Kibitoshin Offline
Kibitoshin  Offline
Specific Ocean
Can you do a blotter test to show the difference between the clean and dirty flushes?
Shin Gekiretsu Shin'ou'hou
01 Toyota Tundra 2WD V8 4.7L
02 Chevy Silverado C1500 V8 5.3L
Re: The highly debated ATF engine flush... [Re: sw99] #4604825
12/15/17 07:08 PM
12/15/17 07:08 PM
in the shop
sw99 Offline OP
sw99  Offline OP
in the shop
I already disposed of it, sorry. I did drain that through a few layers of a white cotton t-shirt and there was a fair amount of small debris that I could see.
Re: The highly debated ATF engine flush... [Re: sw99] #4604840
12/15/17 07:36 PM
12/15/17 07:36 PM
ga
faltic Offline
faltic  Offline
ga
interesting
17 Highlander 3.5 2wd AT 10K+
95 Tacoma 2.4 2wd AT 187k+
07 EX250 21k+
09 EN500 11k+
11 PCX 125 4K+
Re: The highly debated ATF engine flush... [Re: sw99] #4604847
12/15/17 07:43 PM
12/15/17 07:43 PM
Clovis, CA
Merkava_4 Offline
Merkava_4  Offline
Clovis, CA
Engines that are properly maintained never need an engine flush. You guys go 10,000 miles on an OCI and then think you have to do an oil flush. How about keeping the insides of the engine clean in the first place ?
Re: The highly debated ATF engine flush... [Re: sw99] #4604860
12/15/17 07:54 PM
12/15/17 07:54 PM
ON, Canada eh?
StevieC Offline
StevieC  Offline
ON, Canada eh?
Having tested this, the reason that Transmission fluid turns black when in the crankcase is because of the way it reacts to combustion byproducts and the heat all combined together and not having the chemistry to handle it like engine oil would because it's not meant to be in this environment.
It's not because it's cleaning the dirty black stuff from inside your engine. If you want to see proof of this, do the the flush on a brand new engine the same way and there will be the same results.
I have torn apart engines where oil changes were neglected and we tested trans fluid as a flush prior versus true flush products and I can tell you without a doubt transmission fluid does nothing more than using regular engine oil would do in this short period.
The blackness without a doubt is the reaction and nothing more.
'18 Dodge Grand Caravan GT - AMSOIL SS 5w20
'06 Santa Fe - 535,000km AMSOIL SS 0w30 / ATF
Re: The highly debated ATF engine flush... [Re: sw99] #4604867
12/15/17 08:00 PM
12/15/17 08:00 PM
Phoenix
dishdude Online content
dishdude  Online Content
Phoenix
A good running vehicle you've had since new and properly maintained. You think it's a good idea to run this concoction through it? crzy
2018 Challenger SRT 392 PUP 0w-40 Wix 57899XP
2018 GTI
Re: The highly debated ATF engine flush... [Re: StevieC] #4604874
12/15/17 08:05 PM
12/15/17 08:05 PM
Texas & Global
4WD Offline
4WD  Offline
Texas & Global
How about 0w16 with a dose of BG
2018 Chevy 1500 Z71 4WD
2017 Chevy Tahoe LT 4WD
2014 Fusion Hybrid Titanium
2013 Cruze LTZ - RS Turbo
Re: The highly debated ATF engine flush... [Re: 4WD] #4604876
12/15/17 08:07 PM
12/15/17 08:07 PM
ON, Canada eh?
StevieC Offline
StevieC  Offline
ON, Canada eh?
I can't comment on BG. Never used it. wink
Re: The highly debated ATF engine flush... [Re: sw99] #4604895
12/15/17 08:28 PM
12/15/17 08:28 PM
'murica
Ethan1 Offline
Ethan1  Offline
'murica
I thought we established that the ATF flush is an outdated meme from the days when engine oils didn't have very good additive packages...?
Re: The highly debated ATF engine flush... [Re: sw99] #4604911
12/15/17 08:53 PM
12/15/17 08:53 PM
A Highway Near You
PiperOne Offline
PiperOne  Offline
A Highway Near You
ATF turns dark from the heat and combustion products...nothing to do with removing any kind of goo. If I take Dex6 over 250F it gets dark real fast...in the transmission.
HDEO in Diesel Engines. No spark plugs here.
Re: The highly debated ATF engine flush... [Re: sw99] #4604922
12/15/17 09:08 PM
12/15/17 09:08 PM
Northeast
Finz Offline
Finz  Offline
Northeast
Thanks for sharing SW99...
So, even with the new filter, the t-shirt showed some particles in the pour-thru? Wow...
How many times over the 147k miles have you done this?
Afterwards, do you fill with oil and go or do a sacrificial run thru with a cheap conventional to purge?
God Bless America
Re: The highly debated ATF engine flush... [Re: sw99] #4604926
12/15/17 09:17 PM
12/15/17 09:17 PM
Connecticut
69GTX Offline
69GTX  Offline
Connecticut
The add pack from a basic ATF like ST is almost like a "non-detergent" engine oil. I'm not even sure it would meet SA/SB/SC specs. Likely doing much more harm than good. I'd do the flush with a cheap SN engine oil. And I picked up a bunch of those recently (QS) at 25c per quart or less.
2001 Lincoln Cont 4.6L DOHC/ 39K mi / QS HM 5w30 / FUG XG2
1969 Ply GTX/RRs
Page 1 of 4 1 2 3 4
