Opinion needed....
by Duffyjr. 09/21/18 02:56 PM
2017 nissan sentra
by jahwarrior1423. 09/21/18 02:47 PM
I Need A Safe Space- lol
by Zee09. 09/21/18 02:29 PM
Liqui Moly
by dawgn86. 09/21/18 02:10 PM
Valve issues
by kawie_guy. 09/21/18 01:54 PM
2018 Elantra SE
by wolf_06. 09/21/18 01:36 PM
Nasty looking oil filter
by atikovi. 09/21/18 12:43 PM
Laughing hard.
by StevieC. 09/21/18 12:26 PM
Apologies
by Drew99GT. 09/21/18 12:15 PM
Would Like the Manual Transmission to Make a Comeback?
by Speak2Mountain. 09/21/18 11:39 AM
Leaf Mulcher
by kwijibo. 09/21/18 11:32 AM
Pizza dough too crusty
by zorobabel. 09/21/18 11:26 AM
Lubegard Red or Platinum
by diyjake. 09/21/18 11:01 AM
Storing Car Outside
by Delta. 09/21/18 10:47 AM
Looking at a cheap commuter!
by ryan2022. 09/21/18 09:46 AM
Does Your 3.5EB Make Oil
by Gene K. 09/21/18 09:07 AM
F150 Front Differential
by hatt. 09/21/18 08:45 AM
EU version of Subaru 2.5 FB engine
by IMPALA08. 09/21/18 08:40 AM
ScottRousell, Direct_Rejection, donatom, Sylent_Snyper, Ajizzle
66034 Registered Users
102 registered members (Astro14, Astro_Guy, 94astro, 2010Civic, aquariuscsm, Atesz792, 9 invisible), 1,754 guests, and 46 spiders.
Topics290,771
Posts4,850,074
Members66,034
Most Online3,590
Jan 24th, 2017
Repairing Aluminum Oil Pans Threads #4604738
12/15/17 06:25 PM
12/15/17 06:25 PM
Cajun Country, La.
BlueOvalFitter Offline OP
Cajun Country, La.
I was looking around on one of my Ford truck websites and came across this quick fix. I don't know how to react to it because I have never seen the outcome of the process. If it actually works and NEVER leaks, than this IS the best thing to come along since sliced bread! Opinions?
https://youtu.be/hfaCI3jmdCM
Re: Repairing Aluminum Oil Pans Threads [Re: BlueOvalFitter] #4604750
12/15/17 06:48 PM
12/15/17 06:48 PM
Phoenix, AZ
Nick1994 Online content
Nick1994  Online Content
Phoenix, AZ
I thought to myself “maybe” until I saw the plug is magnetic at the end.
Nope, no way, not gonna happen.
As a buddy of mine once told me “a cross thread is a tight thread” laugh
2015 Hyundai Sonata 2.4L 84k Mobil 1 AFE 0w30 & OEM
2000 Toyota Camry 2.2L 230k Valvoline 5w30 & Fram Ultra
1996 Jeep Cherokee 4.0L 147k Mobil 1 HM 10w40 & Fram Ultra
Re: Repairing Aluminum Oil Pans Threads [Re: BlueOvalFitter] #4604757
12/15/17 06:55 PM
12/15/17 06:55 PM
WI
HoosierJeeper Offline
WI
Cross threading is the poor man's Loctite!
15 Jeep KL Limited V6: Formula Shell 5W20
07 LR3 SE V8: Maxlife 5W30
05 Jeep KJ Limited: PHM 5W30
96 Jeep XJ Country: STP HM 5W30 (winter)
Re: Repairing Aluminum Oil Pans Threads [Re: BlueOvalFitter] #4604773
12/15/17 07:14 PM
12/15/17 07:14 PM
Idaho
CT8 Offline
CT8  Offline
Idaho
Helicoil repair in an aluminum pan
2015 Ford F150 2.7
2018 Ford F350 6.2
Re: Repairing Aluminum Oil Pans Threads [Re: BlueOvalFitter] #4604793
12/15/17 07:36 PM
12/15/17 07:36 PM
Cajun Country, La.
Cajun Country, La.
The person that had the oil pan with the bad threads has an engine the same as mine (His was an 06 4.2 V6, 2 WD). I suggested to him to just pull the oil pan and replace it. When my cousin fixed the oil leak on my pan he had no problems pulling the pan at all. No engine jacking and no cross members to remove.
Re: Repairing Aluminum Oil Pans Threads [Re: BlueOvalFitter] #4604841
12/15/17 08:37 PM
12/15/17 08:37 PM
Clovis, CA
Merkava_4 Offline
Merkava_4  Offline
Clovis, CA
I don't like it. I don't like the looks of that giant behemoth sticking out of the oil pan with the exposed threads and the epoxy goop that looks like plumber's putty showing. This product is obviously marketed to the consumer who is scared to death of traditional thread repair systems. I could've easily repaired that oil pan and you would've never known it was repaired.
Re: Repairing Aluminum Oil Pans Threads [Re: BlueOvalFitter] #4604955
12/15/17 11:10 PM
12/15/17 11:10 PM
Maryland USA
rubberchicken Offline
Maryland USA
If this was me doing my own repair at home, I think it would be fine. Not a fan of a magnetic plug, but if it saves me an oil pan, or even buys me time to plan the job out, I would be ok with it.
Re: Repairing Aluminum Oil Pans Threads [Re: BlueOvalFitter] #4604972
12/15/17 11:27 PM
12/15/17 11:27 PM
USA
Reddy45 Offline
Reddy45  Offline
USA
Don't they sell kits where you can literally drill/tap to the next size? Seems like that would be a cleaner and more straight forward fix.
Re: Repairing Aluminum Oil Pans Threads [Re: Reddy45] #4605027
12/16/17 01:32 AM
12/16/17 01:32 AM
Clovis, CA
Merkava_4 Offline
Merkava_4  Offline
Clovis, CA
They sell oversized drain plugs that cut their own threads; that's one other option.
Re: Repairing Aluminum Oil Pans Threads [Re: BlueOvalFitter] #4605061
12/16/17 03:09 AM
12/16/17 03:09 AM
Taiwan
Ducked Offline
Ducked  Offline
Taiwan
Self-tapping oil-drain port insert? Bit clunky, but I don't see why it wouldn't work.
Looks like the oil won't drain as well after installation.
I'm guessing a lot of y'all would insist on a torque wrench setting for installing it though, and then you'll break it.
I wouldn't ever use bare fingers on anything labelled "epoxy" either. You can get very badly sensitised to that stuff.
Re: Repairing Aluminum Oil Pans Threads [Re: CT8] #4605119
12/16/17 08:21 AM
12/16/17 08:21 AM
MA, Mittelfranken.de
Trav Offline
Trav  Offline
Helicoils don't do well in this environment, they are better suited to static fasteners that are not frequently removed.
For this job a Time Sert is recommended, its permanent, sits flush so the regular size drain bolt washer seals properly and has no tang that needs to be broken off.
The initial investment is more but if its a one time fix you can sell the kit on ebay.
