VW Passat R36 504 00/ 507 00 oil
by antik. 03/23/19 04:43 AM
Oil for 2015 Ford Explorer
by oilnut12. 03/23/19 12:48 AM
Blains farm and fleet citgo syn
by BTLew81. 03/22/19 10:48 PM
2003 Duramax 208, XXX miles Rotella T4
by TurboJW. 03/22/19 08:11 PM
Turn signals on the freeway?
by das_peikko. 03/22/19 08:05 PM
Running Boards Restored
by kstanf150. 03/22/19 07:38 PM
QSUD at Canadian Tire
by Snagglefoot. 03/22/19 07:29 PM
Camry vs Accord vs ???
by Joe1. 03/22/19 07:26 PM
Fire up
by Matagonka. 03/22/19 07:16 PM
Mobil-1 AFE Discounted at Sam's Club
by ekpolk. 03/22/19 06:20 PM
Test drove a Tesla Model 3
by y_p_w. 03/22/19 05:54 PM
Did i make a mistake? Hilux 3.0 d4dhello
by Anton93. 03/22/19 05:52 PM
WM Valvoline Full Syn Modern Eng Clearance
by Spartanfool. 03/22/19 04:22 PM
Need Moly basic training
by Bill_W. 03/22/19 04:03 PM
P0420 code goes away in warmer weather
by 2010Civic. 03/22/19 03:54 PM
Customer declined new belt
by Chris142. 03/22/19 03:13 PM
How to deep clean back of wheels?
by qdeezie. 03/22/19 02:51 PM
RK oil sale T4 15w40
by 1978elcamino. 03/22/19 01:57 PM
Zahndkile, duradick, Harold1031, Skendread, NGK
67590 Registered Users
44 registered members (4WD, billt460, BobFout, AurionX2, 97K15004WD, BlakeB, 6 invisible), 656 guests, and 55 spiders.
Topics286,268
Posts4,905,538
Members67,589
Most Online2,967
Mar 10th, 2019
What solution for ultrasonic carb cleaning? #4604591
12/15/17 03:45 PM
12/15/17 03:45 PM
Cleveland, OH
lancerplayer Offline OP
Cleveland, OH
I'm going to use an ultrasonic cleaner to clean my snowblower carb. What do you suggest I use to let it soak in?
I have read some people like Simple Green Pro HD as it will not damage any type of metal.
Re: What solution for ultrasonic carb cleaning? [Re: lancerplayer] #4604598
12/15/17 03:51 PM
12/15/17 03:51 PM
ROCHESTER, NY
Char Baby Offline
Char Baby  Offline
ROCHESTER, NY
Hmmm, I always thought that clean non ethanol gasoline would be sufficient.
"Retired"
'15 Nissan Altima 2.5 SV
'15 Honda Civic LX
Re: What solution for ultrasonic carb cleaning? [Re: lancerplayer] #4604629
12/15/17 04:22 PM
12/15/17 04:22 PM
Staten Island, NY
michaelluscher Offline
Staten Island, NY
I've heard of raving success with Pine Sol
It'll clean good, not be as caustic as Chem-Dip, and it doesn't harm finishes/coatings
'06 Toyota Camry SE V6 3MZ-FE 100k
'01 Mercury Villager Estate VG33E 52k
'06 Ford Taurus SE Vulcan 60k
'13 Chrysler 300 3.6 Pentastar 230k
Re: What solution for ultrasonic carb cleaning? [Re: Char Baby] #4604630
12/15/17 04:24 PM
12/15/17 04:24 PM
MA, Mittelfranken.de
Trav Offline
Trav  Offline
No, it wont touch varnish. Simple green (the regular one) 50/50 with water will do the trick. I use this overnight for carbs then a quick 10 min cycle with the ultrasonic.
For injectors depending on the type I use everything from mild acids to chemicals that will eat aluminum away. Whatever you use try it on a piece of tin foil first to get an idea of how long if at all it is safe to immerse the part.
Re: What solution for ultrasonic carb cleaning? [Re: lancerplayer] #4604634
12/15/17 04:32 PM
12/15/17 04:32 PM
New Zealand
Silk Offline
Silk  Offline
New Zealand
I used to use windscreen washer fluid
1987 BMW R65 - Aegis SAE30
2005 Nissan Expert - 5W-40 Castrol Magnatec diesel.
1996 Volvo T5 - Penrite HPR15 - 15W-60. Ryco syntec filter.
Re: What solution for ultrasonic carb cleaning? [Re: lancerplayer] #4604641
12/15/17 04:37 PM
12/15/17 04:37 PM
The Motor City
Kestas Offline
Global Moderator
Kestas  Offline
Global Moderator
The Motor City
I would avoid using windshield washer fluid, unless you can keep your hands out of it. It contains a lot of methanol, which is a cumulative toxin absorbed through the skin. Instead use isopropyl alcohol or ethanol.
Re: What solution for ultrasonic carb cleaning? [Re: lancerplayer] #4604679
12/15/17 05:17 PM
12/15/17 05:17 PM
New Zealand
Silk Offline
Silk  Offline
New Zealand
You mean....I might be dead ?
Re: What solution for ultrasonic carb cleaning? [Re: lancerplayer] #4604726
12/15/17 06:04 PM
12/15/17 06:04 PM
Upstate NY
Donald Offline
Donald  Offline
Upstate NY
I would just spray it all over with carb cleaner. Its pretty tough stuff and gets everything so clean so you can eat off it. Maybe use an old toothbrush.
I assume you have a rebuild gasket kit?
2015 Ford F250 w/Powerstroke
Re: What solution for ultrasonic carb cleaning? [Re: lancerplayer] #4604833
12/15/17 08:20 PM
12/15/17 08:20 PM
Clovis, CA
Merkava_4 Offline
Merkava_4  Offline
Clovis, CA
When I worked at Miramar Air Station, we used a solvent called Trichloroethylene in the ultrasonic tank for cleaning hydraulic oil cooler filters. The filters were a very fine stainless steel wire mesh. The solvent is often referred to as "Trike" in the military.
Re: What solution for ultrasonic carb cleaning? [Re: Merkava_4] #4604921
12/15/17 10:06 PM
12/15/17 10:06 PM
Trav Offline
Trav  Offline
Before anyone even thinks about using (if you can even get it) read this..
https://en.wikipedia.org/wiki/Trichloroethylene
Re: What solution for ultrasonic carb cleaning? [Re: Trav] #4604986
12/15/17 11:48 PM
12/15/17 11:48 PM
Clovis, CA
Merkava_4 Offline
Merkava_4  Offline
Clovis, CA
That's the same link I posted Trav....
Re: What solution for ultrasonic carb cleaning? [Re: Merkava_4] #4605107
12/16/17 08:05 AM
12/16/17 08:05 AM
Trav Offline
Trav  Offline
I didn't even see a link in your post.
Re: What solution for ultrasonic carb cleaning? [Re: Trav] #4605398
12/16/17 02:23 PM
12/16/17 02:23 PM
Clovis, CA
Merkava_4 Offline
Merkava_4  Offline
Clovis, CA
It's highlighted in blue; how could you have missed it? ???
Re: What solution for ultrasonic carb cleaning? [Re: lancerplayer] #4605475
12/16/17 03:50 PM
12/16/17 03:50 PM
Columbus,Nebraska
Yah-Tah-Hey Offline
Yah-Tah-Hey  Offline
Columbus,Nebraska
I always used lacquer thinner to clean carbs. No ultrasonic needed. Lacquer thinner soak will have a carb looking like new. Be extra careful using it around open flame. Go BOOM. Get out the Rawleigh Salve mom.
Re: What solution for ultrasonic carb cleaning? [Re: Merkava_4] #4606847
12/18/17 01:25 AM
12/18/17 01:25 AM
Trav Offline
Trav  Offline
