Serpentine Belt - When To Change?
by Propflux01. 03/21/19 03:08 PM
Magnetic Out, ST in at Wally Auto Care Center.
by csandste. 03/21/19 02:26 PM
One license plate in a Two-Plate State
by bunnspecial. 03/21/19 02:07 PM
TPMS Units Honda
by Chester11. 03/21/19 01:58 PM
Another brake question
by supton. 03/21/19 01:54 PM
BOUGHT WRONG OIL FILTER
by IBelieveinlube. 03/21/19 01:47 PM
miscible ester, using is as oil additive ?
by pep808. 03/21/19 01:23 PM
LT Oil Temps
by StillLearning. 03/21/19 12:44 PM
What kind of lug nut is this?
by LeakySeals. 03/21/19 12:38 PM
Need help finding a riding mower with $1,500 budget
by MetalSlug. 03/21/19 11:55 AM
Volvo 2.0 Turbo
by Ddub. 03/21/19 11:43 AM
Got a busted crankshaft!
by Chris142. 03/21/19 11:18 AM
Bad Motorcraft Plug?
by tmorris1. 03/21/19 10:47 AM
SAE 20 non-detergent oil
by fleetwood62. 03/21/19 10:39 AM
PSF3 in older Kia?
by Jetsfan421. 03/21/19 09:48 AM
USB WiFi adapter recommendations?
by Quattro Pete. 03/21/19 09:44 AM
m1,ep and valvoline.
by avi1777. 03/21/19 09:39 AM
Caliper recommendation?
by supton. 03/21/19 09:08 AM
Paperboy, Flinch, AlanGonzales, Jrealstreeter, DarkFrontier
67576 Registered Users
107 registered members (53' Stude, 1WildPig, 380SLbenz, 2003f7, 16HC, 1978elcamino, 13 invisible), 2,036 guests, and 96 spiders.
Topics286,197
Posts4,904,053
Members67,576
Most Online2,967
Mar 10th, 2019
GM Overflow Coolant Tanks Behavior #4604501
12/15/17 02:17 PM
12/15/17 02:17 PM
San Rafael, CA
dogememe Offline OP
dogememe  Offline OP
San Rafael, CA
So if my coolant tank is overfull why is my radiator not full? I don't get it. I know it sounds like such a simple question but if I completely fill my radiator I can watch the fluid go to the overflow tank, but it seems like it doesn't wanna do it the other way around?
2010 Ford Escape 2.5 ~94K Miles: Royal Purple 5W-30 + Wix 51348
2008 Ford Crown Vic P71 4.6 ~167K Miles: AMSOIL SS 0W-30 + Wix 51372
1995 Chevy Silverado 5.7 ~277K Miles: Delo 10W-30 + ACDelco PF52
Re: GM Overflow Coolant Tanks Behavior [Re: dogememe] #4604512
12/15/17 02:24 PM
12/15/17 02:24 PM
Toronto
PeterPolyol Offline
PeterPolyol  Offline
Toronto
This is happening on the Burb?
There's no replacement...'scosity for natural viscosity
Re: GM Overflow Coolant Tanks Behavior [Re: dogememe] #4604535
12/15/17 02:38 PM
12/15/17 02:38 PM
California
Billbert Offline
Billbert  Offline
California
Prolly time for a new radiator cap
If you think you can, or if you think you can't, You are probably right.
Auto Instructor / ASE Master Tech
Re: GM Overflow Coolant Tanks Behavior [Re: dogememe] #4604566
12/15/17 03:13 PM
12/15/17 03:13 PM
Deplorable in apple valley, ca
Chris142 Offline
Chris142  Offline
Bad cap or a leak. If there is a leak it cant vacuum the tank back to the radiator.
02 Wrangler carlube 5w30
87 F250 traveler 15w40
07 fjcruiser Chevron 10w30
Z400 castrol T 10w40
Can am maveric edge 5w40
57 case tractor 15w40
Re: GM Overflow Coolant Tanks Behavior [Re: Chris142] #4604904
12/15/17 09:40 PM
12/15/17 09:40 PM
Fort Lauderdale, FL
DoubleWasp Offline
DoubleWasp  Offline
Fort Lauderdale, FL
Exactly. If there is a leak, it will be enough to let the engine pull air in, but not let coolant out. Air replaces your coolant, and the rest is history.
Re: GM Overflow Coolant Tanks Behavior [Re: dogememe] #4609273
12/20/17 12:54 PM
12/20/17 12:54 PM
San Rafael, CA
dogememe Offline OP
dogememe  Offline OP
San Rafael, CA
Yes.
There is a slow drip from one of the heater hoses so I will fix that and replace the radiator cap and see what happens. If it still does it, I will report back! Thanks all smile
