VW Passat R36 504 00/ 507 00 oil
by antik. 03/23/19 04:43 AM
Oil for 2015 Ford Explorer
by oilnut12. 03/23/19 12:48 AM
Blains farm and fleet citgo syn
by BTLew81. 03/22/19 10:48 PM
2003 Duramax 208, XXX miles Rotella T4
by TurboJW. 03/22/19 08:11 PM
Turn signals on the freeway?
by das_peikko. 03/22/19 08:05 PM
Running Boards Restored
by kstanf150. 03/22/19 07:38 PM
QSUD at Canadian Tire
by Snagglefoot. 03/22/19 07:29 PM
Camry vs Accord vs ???
by Joe1. 03/22/19 07:26 PM
Fire up
by Matagonka. 03/22/19 07:16 PM
Mobil-1 AFE Discounted at Sam's Club
by ekpolk. 03/22/19 06:20 PM
Test drove a Tesla Model 3
by y_p_w. 03/22/19 05:54 PM
Did i make a mistake? Hilux 3.0 d4dhello
by Anton93. 03/22/19 05:52 PM
WM Valvoline Full Syn Modern Eng Clearance
by Spartanfool. 03/22/19 04:22 PM
Need Moly basic training
by Bill_W. 03/22/19 04:03 PM
P0420 code goes away in warmer weather
by 2010Civic. 03/22/19 03:54 PM
Customer declined new belt
by Chris142. 03/22/19 03:13 PM
How to deep clean back of wheels?
by qdeezie. 03/22/19 02:51 PM
RK oil sale T4 15w40
by 1978elcamino. 03/22/19 01:57 PM
duradick, Harold1031, Skendread, NGK, Thomas1
67589 Registered Users
30 registered members (4WD, A1O, antik, billt460, bfleeman, ctechbob, 4 invisible), 497 guests, and 57 spiders.
Topics286,267
Posts4,905,521
Members67,589
Most Online2,967
Mar 10th, 2019
Kubota HHK70-14070 HST trans filter cut open #4604316
12/15/17 11:05 AM
12/15/17 11:05 AM
Ontario Canada
Canadastang Offline OP
Ontario Canada
200 hours on this Kubota HST filter with lots of really cold and really hot weather operation.
Lookin' good, not much to see here. Built like a tank like all the other Kubota filters I've seen, but for $23.00 it better be!
Has the typical kubota glitter from break in. Looks bad, but they all have lots of glitter in their early hours.
Re: Kubota HHK70-14070 HST trans filter cut open [Re: Canadastang] #4604333
12/15/17 11:20 AM
12/15/17 11:20 AM
Fort Lauderdale, FL
DoubleWasp Offline
DoubleWasp  Offline
Fort Lauderdale, FL
Looks like a Parker filter. No wonder it's built like a brick outhouse.
Re: Kubota HHK70-14070 HST trans filter cut open [Re: Canadastang] #4604342
12/15/17 11:26 AM
12/15/17 11:26 AM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
Glitter?
Surprising... bad cleaning during assembly, or bad machining?
Re: Kubota HHK70-14070 HST trans filter cut open [Re: Linctex] #4604362
12/15/17 11:50 AM
12/15/17 11:50 AM
Ontario Canada
Ontario Canada
If you look at Tractorbynet or most other tractor forums pretty much everyone who does their first hydraulic service on a Kubota has lots of glitter and shavings.
They require a break-in service at 50 hours and man oh man do they have lots of shavings in their first 50.
I really don't know where it all comes from, but probably a combo of break in, machining leftovers etc.
Regardless most all kubotas run like champs and run for a very, very long time.
Re: Kubota HHK70-14070 HST trans filter cut open [Re: Canadastang] #4604407
12/15/17 12:44 PM
12/15/17 12:44 PM
Ontario, Canada
IndyIan Offline
IndyIan  Offline
Ontario, Canada
Is this for a tractor or a lawn tractor? My Kioti DK40SE had a fair amount of junk in the hyd/HST/final drive fluid for the first change as well. It seems for tractors they don't clean out all the machining debris for some reason... My HST filter has a cast aluminum can though as it sees ~200psi and was $70 for the last one. I imagine somebody good do well rebuilding HST filters for CUTs.
07 Focus ZXW, 5spd manual, 230km M1 5W30
18 Outback 2.5 CVT 22km 0W20
Re: Kubota HHK70-14070 HST trans filter cut open [Re: IndyIan] #4609747
12/20/17 10:58 PM
12/20/17 10:58 PM
Ontario Canada
Ontario Canada
This is from my Kubota L3200 HST. It's a 32 hp tractor with a front end loader. Fantastic machine.
