WPA 3 Wireless Security Coming
by StevieC. 09/22/18 01:16 AM
Robo Calls/Telemarketers
by Nick1994. 09/22/18 12:47 AM
What oil should be used!
by BigShug681. 09/22/18 12:28 AM
VW Electronic Parking Brake
by StevieC. 09/21/18 11:48 PM
Leak Sealing and Mould Treatments?
by Ducked. 09/21/18 11:44 PM
UPS / FedEx / USPS
by StevieC. 09/21/18 11:21 PM
puncture repair question
by neo3. 09/21/18 10:55 PM
Can I use a 10 amp extension cord for...
by gregk24. 09/21/18 10:48 PM
In the unlikely event of a crash
by StevieC. 09/21/18 10:09 PM
Craigslist time wasters
by Anduril. 09/21/18 09:41 PM
Who runs a 20wt here?
by StevieC. 09/21/18 07:31 PM
Need help on edit profile
by jetmech1. 09/21/18 06:34 PM
Oil thickness on the dipstick
by Idlewild294. 09/21/18 05:40 PM
Chinese WIX Trans filter bad, let me down..
by jetmech1. 09/21/18 04:47 PM
Gen 8 Accord rear brakes-What tool?
by fdcg27. 09/21/18 04:30 PM
Ammeters?
by buck91. 09/21/18 03:55 PM
Need Help with Double D Knock Out Punch
by user52165. 09/21/18 03:41 PM
JRMFt11, Navyretired, aikwae, ScottRousell, Direct_Rejection
66036 Registered Users
49 registered members (02z, Astro14, 53' Stude, bbhero, Bandito440, burla, 3 invisible), 908 guests, and 35 spiders.
Topics290,810
Posts4,850,775
Members66,036
Most Online3,590
Jan 24th, 2017
Car making noises (description) #4604292
12/15/17 10:35 AM
12/15/17 10:35 AM
Utah
dan765 Offline OP
dan765  Offline OP
Utah
Hello, gentlemen, could use your expertise here.
2006 Hyundai Elantra, 122,xxx miles.
Sound #1: In the mornings when I start the car (or anytime when it's cold) there is a loud squealing sound when I turn the wheel. I would imagine it's coming from power steering, but would it be a bad belt of bad pump?
Sound #2: There is a chirping/squealing sound coming from the engine as I drive. It goes up in frequency as the RPMs increase.
Thank you
Re: Car making noises (description) [Re: dan765] #4604310
12/15/17 10:59 AM
12/15/17 10:59 AM
Romania
Andy636 Offline
Andy636  Offline
Romania
Had the exact same car.
#1 Belt is gone or it needs tensioning. You do that by loosening the alternator,(change the belt) prying on it with a lever and re tight it.
#2 Could be the alternator bearing, AC, PS pump or the timing belt tensioner bearing.
Bullet proof engines unless you do something stupid to them like not changing the oil for 30K miles.
Re: Car making noises (description) [Re: dan765] #4604374
12/15/17 12:00 PM
12/15/17 12:00 PM
DFW
JustN89 Offline
JustN89  Offline
DFW
I agree with Andy here. That belt needs replacing and/or tightening. Get that taken care of and you should see those symptoms go away.
Re: Car making noises (description) [Re: dan765] #4604378
12/15/17 12:03 PM
12/15/17 12:03 PM
Campbellsville, KY
Alex_V Offline
Alex_V  Offline
Campbellsville, KY
X3 - both symptoms sound like the serpentine belt system. Replace the belt and/or tensioner and see if it helps.
I like Chevy and Valvoline.
'13 Cruze, 1.4T, 113K
'85 GMC C3500, 454, 130K
'82 Mercedes 300CD, OM617 turbo, 169K
'67 Suburban, 350, 331K
Re: Car making noises (description) [Re: dan765] #4604406
12/15/17 12:43 PM
12/15/17 12:43 PM
Chicago, IL
EdwardC Offline
EdwardC  Offline
Chicago, IL
I agree with the other guys, sounds like a fairly simple, routing belt issue. At that mileage, it's probably a good idea to just replace the belt. You can try tighten the belt if it appears to be in good condition for a short term fix.
Re: Car making noises (description) [Re: dan765] #4604408
12/15/17 12:44 PM
12/15/17 12:44 PM
The Northeast
mclasser Offline
mclasser  Offline
The Northeast
X4 Check/tension both drive belts
2018 Hyundai Elantra VE -- 4K
2013 Honda Pilot EX-L 4WD -- 56K
2002 Honda Accord EX-L -- 211K
Re: Car making noises (description) [Re: dan765] #4604554
12/15/17 02:58 PM
12/15/17 02:58 PM
Florida, Cape Coral
Eddie Offline
Eddie  Offline
Florida, Cape Coral
At 122,000 miles, I'd just change the belt and tension per recommendations. Ed
CX5 Touring 2.5L :-)
Re: Car making noises (description) [Re: Eddie] #4604632
12/15/17 04:30 PM
12/15/17 04:30 PM
MTL, CANADA
Rolla07 Offline
Rolla07  Offline
MTL, CANADA
+1
2007 Corolla Red Pearl 155k miles
PP 0w20 & ST 4967
Re: Car making noises (description) [Re: dan765] #4604636
12/15/17 04:33 PM
12/15/17 04:33 PM
VA
Gebo Offline
Gebo  Offline
VA
You can check the belt by spraying something on it while it is running. If it gets quiet, you know which belt it is or if it is the belt. However, no chemical (belt dressing) is a fix for a loose belt. Please either replace or tighten.
'98 LEX LS400 280K
'00 LEX GS300 195K
'02 4Runner 225K
'05 Lex LS430 85K
'06 Toyota Highlander 145K
'09 Lex IS350 85K
'07 Lex GX470 58K
Amsoil in all engines, transmissions and differentials
