Which Performance Filter?
by rooflessVW. 09/25/18 03:33 PM
Optimal Compression Ratio for 91 Octane Fuel
by NICAT. 09/25/18 02:01 PM
Anyone used Amsoil DZF 0w40 ?
by ofelas. 09/25/18 01:33 PM
No more Turo - What now?
by dogememe. 09/25/18 01:08 PM
Military small arms ammo
by Camprunner. 09/25/18 12:03 PM
Pennzoil must not be selling , OR ?
by Kjmack. 09/25/18 11:51 AM
New black car, light swirls and water spots
by Redright9. 09/25/18 11:37 AM
Rust Belt vs Sun Belt cars
by ZZman. 09/25/18 11:33 AM
Enginer rebuilder's view of GDI intake issues
by Brigadier. 09/25/18 11:09 AM
Oil for '84 Caddy w/HT-4100
by StillLearning. 09/25/18 10:41 AM
Interesting video of diff with clear cover
by mrdctaylor. 09/25/18 10:15 AM
The death of American footbal
by Brigadier. 09/25/18 10:01 AM
Tire leaking from bead/rim
by Brybo86. 09/25/18 09:39 AM
2000 4Runner 3.4L
by ka9mnx. 09/25/18 08:59 AM
VW 508 Spec 0w20 Updates?
by Zee09. 09/25/18 08:36 AM
Laptop Recommendations
by buster. 09/25/18 08:24 AM
Mac OSX Mojave - vid card requirements
by OVERKILL. 09/25/18 08:05 AM
Peppz, Jfa02, ibsfusion, Fearcat707, Perseo
66069 Registered Users
108 registered members (92saturnsl2, Ablebody, 28oz, 853okg, Al, 7 invisible), 1,585 guests, and 40 spiders.
Topics290,998
Posts4,854,082
Members66,069
Most Online3,590
Jan 24th, 2017
How to bench bleed a master cylinder #4604262
12/15/17 10:14 AM
12/15/17 10:14 AM
The Motor City
Kestas Offline OP
Kestas  Offline OP
The Motor City
I need to replace the brake master cylinder on my 2010 Nissan Murano. I already bought the new unit.
The instructions give a choice of bleeding methods. One is to plug the ports and pump the piston until it can't move. The other is to use bleeder tubes that direct the fluid back to the reservoir. What are the pros and cons of each method? I have the plugs for the ports, but I don't have bleeder tubes.
Re: How to bench bleed a master cylinder [Re: Kestas] #4604321
12/15/17 11:07 AM
12/15/17 11:07 AM
MN
14Accent Offline
14Accent  Offline
MN
Either one works. I usually just do the port plug method, then install on the car and have someone pump the pedal while I crack the lines at the master, just like a bleeder screw. Doing it this way I almost never have to bleed at the wheels.
2013 Chevrolet Volt - Saves enough in fuel to pay for itself!
2003 Cadillac Seville STS - The winter "beater", it uses the Volt's fuel
Re: How to bench bleed a master cylinder [Re: Kestas] #4604341
12/15/17 11:25 AM
12/15/17 11:25 AM
Chicago, IL
tomcat27 Offline
tomcat27  Offline
Chicago, IL
I just finished doing the "port plug" method on the MC for my Cougar. worked well.
2019 Cherokee, 2015 Rogue, 2014 Sentra, 2001 Camry, 2005 Starcraft, 1998 Dodge B1500
1996 Sebring Jx, 1984 F150, 1970 Cougar, 2013 XT250, 2010 Vstar, 2014 CTX1300
Re: How to bench bleed a master cylinder [Re: Kestas] #4604347
12/15/17 11:29 AM
12/15/17 11:29 AM
DFW
DBMaster Offline
DBMaster  Offline
DFW
Never tried the port plug method. May have to if there's a next time. My 89 Accord used to go through MCs every 100K miles like clockwork. I replaced the unit three times on that car using the small tubes directed into the reservoir. It worked fine, too.
Re: How to bench bleed a master cylinder [Re: Kestas] #4604412
12/15/17 12:52 PM
12/15/17 12:52 PM
California
nthach Online content
nthach  Online Content
California
I've done port plug last time I've replaced a MC. Worked fine, not as messy as the tubes.
Re: How to bench bleed a master cylinder [Re: Kestas] #4604421
12/15/17 12:57 PM
12/15/17 12:57 PM
iowa
Traction Offline
Traction  Offline
iowa
Port method is the easiest, and works. You can also mount the MC and use the brake pedal to bench bleed. The problem with either method is when you go to hook up the lines it runs out, and all over. But, if you hold the brake pedal just halfway down or more with a prop rod, or something, then when the pedal is depressed, it blocks the output ports inside the cylinder bore, and then nothing runs out. You can do the same thing when changing calipers, etc. Makes bleeding much easier too, by not letting all the fluid leak out of the master, and lines. It's like holding water in a drinking straw with your finger. You can hold brake fluid for days in the system using that method, but you would probably want to unhook the battery, because your brake lights will be on is all.
Certified Tire Service Instructor since 2009
50 Chevy Fire Truck
13 Tahoe Pursuit
97 C5 Corvette
00 BMW M Roadster
02 Camry
12 Camry
81 Camaro
55 Chevy C4
Re: How to bench bleed a master cylinder [Re: Kestas] #4604476
12/15/17 02:00 PM
12/15/17 02:00 PM
Clovis, CA
Merkava_4 Offline
Merkava_4  Offline
Clovis, CA
All you do is thread in the little plastic adapters where the brake lines normally go. Then you hook the little clear hoses to the adapters and submerge the other end of the hoses below the brake fluid in the master cylinder. Then you take a #3 Phillips screwdriver and push the piston several times. When the bubbles quit coming out of the hoses, you're done.
Re: How to bench bleed a master cylinder [Re: Kestas] #4604643
12/15/17 04:41 PM
12/15/17 04:41 PM
The Motor City
Kestas Offline OP
Kestas  Offline OP
The Motor City
Thanks for the feedback. One bonus with this job is that a brake fluid flush was in the queue. By putting it off I will have only needed to do it once.
Re: How to bench bleed a master cylinder [Re: Kestas] #4606551
12/17/17 07:54 PM
12/17/17 07:54 PM
Toronto, Canada
George7941 Offline
George7941  Offline
Toronto, Canada
I have always used the tubes to direct the flow back into the mc and the method works extremely well. I don't see how all the air can be purged if the ports are plugged since any bubble that gets trapped has nowhere to go. If the mc is mounted in the vise with the front inclined down, I can see most of the bubbles, but perhaps not all, escaping through the compensating ports when the outlet ports are plugged.
2006 GMC Sierra 4.3l, NV3500,G80 , Mobil 1 5W30, Dexcool.
1987 BMW R80 - sold
2015 Honda CBR300R
Staying out of the right lane a lot.
Re: How to bench bleed a master cylinder [Re: Traction] #4606555
12/17/17 07:58 PM
12/17/17 07:58 PM
Toronto, Canada
George7941 Offline
George7941  Offline
Toronto, Canada
Holding the pedal halfway down or more does NOT block the output ports. However, holding the pedal down, even if just a bit, blocks the compensating ports and then vacuum will prevent fluid running out. It works well, I can attest to that from experience.
1987 BMW R80 - sold
2015 Honda CBR300R
