Mixing oils
by bfleeman. 12/15/18 10:51 AM
Ebay 10% off Tech 15% off everything else*.
by demarpaint. 12/15/18 10:39 AM
Milwaukee Fuel M12 Ratchet 1/4” vs 3/8”
by Snagglefoot. 12/15/18 10:16 AM
Hifly Hf 805
by chrisri. 12/15/18 10:00 AM
Preferred 5.3L L83 Oil Filter
by zfasts03. 12/15/18 09:58 AM
sonata plastic fork starter failed three times.
by JustinH. 12/15/18 09:17 AM
HVAC Problems
by WTJackalope. 12/15/18 09:15 AM
Rough Idle after short trip
by Datarock. 12/15/18 09:07 AM
Homelite 360
by mobilaltima. 12/15/18 09:04 AM
Lovin' the Etec!
by IndyFan. 12/15/18 06:10 AM
Air Impact Wrench
by BenZahel. 12/15/18 05:19 AM
Luber finer 750 bypass oil filter info
by BigRich954. 12/15/18 03:59 AM
Ford Pickup Front Wheel Bearings 2WD
by benjamming. 12/14/18 10:52 PM
GMC oil fill tube
by Redright9. 12/14/18 10:24 PM
Where do I buy Toto toilets? That has them!
by Vern_in_IL. 12/14/18 10:04 PM
Best filter cutter for the price?
by DONWATERS. 12/14/18 09:38 PM
5W-40 vs 10W-30 for a 2018 Audi A4
by jcr1293. 12/14/18 09:25 PM
Gave up on quadrajet electric choke today...
by leroyd92. 12/14/18 08:54 PM
2015 Odyssey - Which synthetic ATF?
by AngryScientist. 12/14/18 07:56 PM
Spkrdctr, torchredone12, JNG, Edmundo, NEKGuy
66688 Registered Users
79 registered members (4WD, Audios, andrewp1998, Artem, amblerman, 12 invisible), 2,119 guests, and 40 spiders.
Topics295,106
Posts4,927,916
Members66,688
Most Online2,553
Oct 27th, 2018
Hole Saw Drilling Tip #4604142
12/15/17 07:30 AM
12/15/17 07:30 AM
iowa
Traction Offline OP
Traction  Offline OP
iowa
After drilling many holes with a hole saw over the years, and messing up more than a few, a huge tip is to not use a drill bit in the hole saw. Especially on thin materials, or aluminum. Drill the pilot hole separately, and use a 1/4 drill rod, or cut the shank off of a long bit installed in the arbor to guide the saw. Otherwise if using a drill bit, your pilot hole keeps getting bigger, and the saw hole keeps getting bigger and uglier too. Yesterday I cut a 4 inch hole in the lower corner of my steel garage door for a dust collector port. Now I can connect up my 3/4 horse dust collector outside to pull welding fumes, dust, etc. right outside, plus I don't have to listen to it. There is a plastic blast gate attached on the outside of the door I got from Menard's for $5.
Certified Tire Service Instructor since 2009
50 Chevy Fire Truck
13 Tahoe Pursuit
97 C5 Corvette
00 BMW M Roadster
02 Camry
12 Camry
81 Camaro
55 Chevy C4
Re: Hole Saw Drilling Tip [Re: Traction] #4604151
12/15/17 07:40 AM
12/15/17 07:40 AM
Champlain/Hudson Valley
Kira Offline
Kira  Offline
Grandpa raccoon can't fit through that! Wadda you, anti-family?
Re: Hole Saw Drilling Tip [Re: Kira] #4604157
12/15/17 07:47 AM
12/15/17 07:47 AM
New England
Virtus_Probi Offline
New England
Chipmunks, squirrels, and weasels will be A-OK!!!
2014 Forester XT, 90000 miles
Last Change;
M1 5W30 d1G2
Tokyo Roki 15208AA170 filter
Re: Hole Saw Drilling Tip [Re: Traction] #4604158
12/15/17 07:48 AM
12/15/17 07:48 AM
Reno, Nevada
Langanobob Offline
Langanobob  Offline
Reno, Nevada
That is an interesting tip and Ill try it next time Im cutting holes in thin material. Thanks!
Re: Hole Saw Drilling Tip [Re: Traction] #4604170
12/15/17 08:01 AM
12/15/17 08:01 AM
Ontario, Canada
IndyIan Offline
IndyIan  Offline
Ontario, Canada
Good idea! I've clamped a sacrificial piece of plywood to thin stuff to act as a guide as well. This way you can cut partial circles or bites.
07 Focus ZXW, 5spd manual, 218km M1 5W30
18 Outback 2.5 CVT 15km 0W20
Re: Hole Saw Drilling Tip [Re: IndyIan] #4604429
12/15/17 12:05 PM
12/15/17 12:05 PM
Chicago, IL
EdwardC Offline
EdwardC  Offline
Chicago, IL
Which is also a great tip for when you need to re-drill for a larger hole!
I think the best hole saw tip I've used (particularly when drilling wood), is to drill a few holes around the edge of the hole to allow chips to fall.
https://www.familyhandyman.com/tools/saws/choose-the-right-hole-saw-for-your-project/view-all/
Re: Hole Saw Drilling Tip [Re: Traction] #4605734
12/16/17 06:48 PM
12/16/17 06:48 PM
Lakeside CA
another Todd Offline
Lakeside CA
Good tip but why would you drill a through hole in a door that goes up and down. Sooner or later you are going to A) get sick of disconnecting hoses to open the door, or B) forget about it and open the door with hoses still attached and pull it apart, with possible damage.
2015 Ford F250 Diesel Crew Cab FX4
2017 Ford Escape 2.0
2002 GMC Yukon
2015 Hyundai Accent
2008 Yamaha Rhino 700 FI
Re: Hole Saw Drilling Tip [Re: another Todd] #4606016
12/17/17 08:12 AM
12/17/17 08:12 AM
iowa
Traction Offline OP
Traction  Offline OP
iowa
It's for occasional use, and the hoses just slip on. I'll use it for welding projects, or painting small parts inside during cold weather. I didn't want to go through the sidewall, but I could have. Other than that just remember to unhook if needing to open the door. I am more worried about opening the door with the rear hatch of my Tahoe open.
50 Chevy Fire Truck
13 Tahoe Pursuit
97 C5 Corvette
00 BMW M Roadster
02 Camry
12 Camry
81 Camaro
55 Chevy C4
Re: Hole Saw Drilling Tip [Re: Traction] #4606053
12/17/17 08:59 AM
12/17/17 08:59 AM
Illinois
SHOZ Offline
SHOZ  Offline
Illinois
I cut a hole where there should have been a factory subframe bushing for the rear of my Genesis Coupe last summer. Installed a factory bushing. The subframe was stamped steel and quite hard. There was already somewhat of a hole there. But I used the plywood backer board and also figured out to get rid of the bit and used a cut off bolt for the guide.
The hole saw wandered a bit but the OE hole was in a recessed area and that kind of contained the run out. It turned out good as it also thinned the steel and in the end pushed it out to for some sort of a flange.
2008 Hyundai Accent 1.6L 5 sp manual hatchback
2010 Hyundai Genesis Coupe Track 2L Turbo 6sp manual
Re: Hole Saw Drilling Tip [Re: Traction] #4606730
12/17/17 09:43 PM
12/17/17 09:43 PM
ME
eljefino Offline
eljefino  Offline
ME
^ That's cool but did Hyundai just forget that step? Hole guy called in sick? LOL
Re: Hole Saw Drilling Tip [Re: eljefino] #4606939
12/18/17 06:52 AM
12/18/17 06:52 AM
Illinois
SHOZ Offline
SHOZ  Offline
Illinois
It's speculated that the motor mounts are so squishy and allow so much movement they had to just use three bushings to hold the rear subframe in it could move with the motor. It sure made a major difference in planting the rear end when cornering.
Re: Hole Saw Drilling Tip [Re: SHOZ] #4607617
12/18/17 07:19 PM
12/18/17 07:19 PM
Central Maryland
HangFire Offline
HangFire  Offline
Central Maryland
Originally Posted By: SHOZ
[It's speculated that the motor mounts are so squishy and allow so much movement they had to just use three bushings to hold the rear subframe in it could move with the motor.
Read 3 times, still can't parse this.
Various musings: http://hangfire.net
