Sunrise, Sunset
by csandste. 09/24/18 02:39 AM
Adding fuel filter- Generator built with no filter
by rubberchicken. 09/23/18 09:57 PM
Clutch Engaging too low
by Spetz. 09/23/18 09:41 PM
SMA - Krown previously, Fluid Film Application
by StevieC. 09/23/18 09:21 PM
First Paint Correction
by RayCJ. 09/23/18 08:33 PM
2011 Dodge Caliber
by dogememe. 09/23/18 07:48 PM
Mixing transmission fluids - partial change
by spk2000. 09/23/18 07:31 PM
Counterfeit MANN filter???
by IllinoisSparky. 09/23/18 06:54 PM
The smell of an oil: VME adds?
by fdcg27. 09/23/18 06:48 PM
Classic road brake pads
by buck91. 09/23/18 06:18 PM
Air up your vehicle's tires
by Papa Bear. 09/23/18 06:07 PM
A cool litttle Fall foliage site
by Papa Bear. 09/23/18 06:02 PM
Suggestion: "Likes"
by SnowDrifter. 09/23/18 05:36 PM
Condensation in headlights?
by irv. 09/23/18 05:06 PM
Nissan VQ V-6 Engines
by Al. 09/23/18 04:57 PM
List of dexos licensed oils?
by k1xv. 09/23/18 04:24 PM
Lilshady, SevenDu, sigpro, RayCJ, yellow97tt6spd
66055 Registered Users
22 registered members (4WD, biggusblockus, agh13tz, Astro14, Ablebody, 5 invisible), 740 guests, and 41 spiders.
Topics290,921
Posts4,852,538
Members66,055
Most Online3,590
Jan 24th, 2017
Consistency of gear lube in very cold weather #4604099
12/15/17 06:42 AM
12/15/17 06:42 AM
Michigan
ZZman Offline OP
ZZman  Offline OP
Michigan
We all know that a 0 - 5w multi-grade motor oil flows better in cold weather. We have probably watched videos where this oil is made very cold and poured out and it is very thick.
This made we wonder how thick a 75-90w gear lube must get in cold weather. Is it like frozen ice cream or butter? How the
2003 Mercury Grand Marquis. Rotella T6 Multi-Vehicle oil
2008 Sebring Hardtop convertible. Rotella T6 Multi-Vehicle oil
2006 Kawasaki Vulcan 900 LT. Amsoil Metric 10w-40
Re: Consistency of gear lube in very cold weather [Re: ZZman] #4604110
12/15/17 07:12 AM
12/15/17 07:12 AM
North Carolina
rooflessVW Online content
rooflessVW  Online Content
North Carolina
"Zed's dead baby, Zed's dead."
Re: Consistency of gear lube in very cold weather [Re: rooflessVW] #4604114
12/15/17 07:36 AM
12/15/17 07:36 AM
Michigan
ZZman Offline OP
ZZman  Offline OP
Michigan
Originally Posted By: rooflessVW
Like ice cream then?.... smile
Re: Consistency of gear lube in very cold weather [Re: ZZman] #4604177
12/15/17 09:07 AM
12/15/17 09:07 AM
Upper Midwest
kschachn Offline
kschachn  Offline
Upper Midwest
No, read the graph.
Besides, it's not the same environment as a motor oil nor does it have the same viscosity requirements.
1994 BMW 530i, 228K
1996 Honda Accord, 263K
1999 Toyota Sienna, 400K
2000 Toyota ECHO, 271K
Re: Consistency of gear lube in very cold weather [Re: ZZman] #4604187
12/15/17 09:13 AM
12/15/17 09:13 AM
Texas
4WD Online confused
4WD  Online Confused
Texas
Does not get pumped … still requires mobility … some may have noticed the OEM’s went synthetic with gear oil long before getting behind synthetic lubes in the motor …
Re: Consistency of gear lube in very cold weather [Re: ZZman] #4604225
12/15/17 09:42 AM
12/15/17 09:42 AM
N.H, U.S.A.
ARCOgraphite Offline
N.H, U.S.A.
Like a 10w40 to a 15w50 motor oil. Ive only trashed a diff through shock not through cold running. Though back when I had RRWD diffs with SAE90 I had a garage smile
2014 Nissan Rogue S CVT, OC#9 41392mi-QSUD10W30 + M110A CHAMP Filter; 2017 Subaru Crosstrek CVT OC#2 ?? mi-SOA/Idemitsu 0w20 + SOA Filter
Re: Consistency of gear lube in very cold weather [Re: ZZman] #4604239
12/15/17 09:54 AM
12/15/17 09:54 AM
NC
fenixguy Offline
fenixguy  Offline
NC
I'm sure this has been posted here before, but it's still fun to watch.
Gear Oil in Cold
'16 Frontier SV 4x4-PP/Nissan OEM
'08 CR-V EX AWD-Valvoline Syn MaxLife/Fram TG
'01 Civic EX-Valvoline Syn MaxLife/Fram UG
'00 Civic LX-PYB/Fram UG
Re: Consistency of gear lube in very cold weather [Re: fenixguy] #4604286
12/15/17 10:31 AM
12/15/17 10:31 AM
Michigan
ZZman Offline OP
ZZman  Offline OP
Michigan
Gear Oil in Cold
Cool video.... Looks like caramel.... Lol
Re: Consistency of gear lube in very cold weather [Re: ARCOgraphite] #4604313
12/15/17 11:02 AM
12/15/17 11:02 AM
Texas
4WD Online confused
4WD  Online Confused
Texas
Yep … 4 speed big blocks got a few …
Re: Consistency of gear lube in very cold weather [Re: ZZman] #4604471
12/15/17 01:51 PM
12/15/17 01:51 PM
Wisconsin
Black_Thunder Offline
Wisconsin
what's weird is my vehicles i the late 90's came factory filled with either 75w90 or 75w140 synthetic.
and my Parents recently bought a 2015 Ford Escape that is spec'ed for 80w90 in the rear axle......why not 75w90?
I'd buy Callahan autoparts if I could.
Re: Consistency of gear lube in very cold weather [Re: Black_Thunder] #4604530
12/15/17 02:36 PM
12/15/17 02:36 PM
WA (USA)
Y_K Offline
Y_K  Offline
WA (USA)
Because 80W-90 is not a syn oil and perhaps they want you to have a higher viscosity at lower temperature band. Chevron Delo ESI 80W-90 is certified for 500k miles in big trucks with Dana / Meritor rear ends.
"This forum talking about 4wd systems is like when other forums talk about oil." © 2018 FlyPenFly
Re: Consistency of gear lube in very cold weather [Re: ZZman] #4604616
12/15/17 04:13 PM
12/15/17 04:13 PM
Cheshire, England
barryh Offline
barryh  Offline
Cheshire, England
I've never seen gear oil in cold weather but I've certainly felt the difference a thinner oil makes.
My BMW motorcycle has gear oil in the gearbox, shaft drive and final drive. Spinning the rear wheel by hand in neutral demonstrates there is a really substantial amount of oil drag at - 5 deg C which is my lower limit for riding. Switching from the specified mineral 80W90 to synthetic 75W90 subjectively reduced that drag by a large amount. When I graphed the oils it was a reduction from approx. 4000 cSt to 1000 cSt. That reduction in cold viscosity has to be worth having and I won't be going back to the 80W90.
Barry
1979 BMW R45 (Triple QX 5W40)
2009 Mercedes C180K (Shell Helix Ultra 5W40)
