Leather Masters Protection Cream review....
by gregk24. 09/22/18 03:13 PM
Aisin WS
by RodneyM. 09/22/18 03:11 PM
Husqvarna trimmer questions
by BrianF. 09/22/18 02:51 PM
Uber Self-Driv Death: Disabled Pedest Avoidance!!!!
by oil_film_movies. 09/22/18 02:29 PM
Question on Backlight setting on LED tv's
by LoneRanger. 09/22/18 02:16 PM
Are all Dexos 1 Gen 2 Oils the Same?
by Gene K. 09/22/18 01:58 PM
ECOGARD X10479 CUT OPEN
by 53' Stude. 09/22/18 01:38 PM
Rust-Oleum Driveway Sealer review
by SVTCobra. 09/22/18 01:24 PM
Flush OAT/IAT mixture
by OpenClose. 09/22/18 12:20 PM
And They Say Spelling is Not Important.
by PimTac. 09/22/18 12:06 PM
Toyota Genuine oil 10W30
by gordond. 09/22/18 09:27 AM
Good Dealers
by HowAboutThis. 09/22/18 09:12 AM
electric brakes rely on heat to work?
by motor_oil_madman. 09/22/18 09:09 AM
help please 7.25 briggs idle too fast
by edwardh1. 09/22/18 08:49 AM
Java update and Flash not working
by JLTD. 09/22/18 08:47 AM
Bought a Giulia
by RamFan. 09/22/18 08:38 AM
by gordond. 09/22/18 08:37 AM
Sarrge, Big_R, gordond, mrgreggn, JRMFt11
66040 Registered Users
90 registered members (4WD, Anduril, 2oldtommy, avi1777, 55hambone, 12 invisible), 1,862 guests, and 41 spiders.
Topics290,831
Posts4,851,125
Members66,040
Most Online3,590
Jan 24th, 2017
Tranny Makes Clicking noise When Decelerating #4603903
12/14/17 09:55 PM
12/14/17 09:55 PM
Arkansastan
Propflux01 Offline OP
Arkansastan
I have a mystery on my hands... Car is a 2006 KIA Spectra, 103,000 miles. Here's the story:
Daughter comes to me saying car is making a loud clicking noise when she lets off gas or coasts. Says it started after a panic stop when someone pulled out in front of her. No sideways skid or anything like that, just a hard brake for a couple seconds. Drives on, lets off gas, clicky noise. I take the car, drive it, and it does it when coasting, decelerating, rolling with engine off in neutral, wheels turned or straight. I look at it, cannot find anything obvious. CV joint boots are intact, removed the brake calipers and changes brake shoes and rotors. nothing wrong. Take car to mechanic. he says he has never heard anything like this, and to take it to transmission specialist. So today, I do just that. Tranny guy takes it for a drive. comes back, looks underneath, works and shifts great, but says he has never heard anything like this before. So I take it home, jackstand it, and start looking. the only thing I can find at all, is a slight bit of fresh looking whiteish grease coming out of the RHS Half-shaft inner joint. Not very much, but enough to notice it when looking at it. I held the wide part of the joint, where it goes into the tranny, and took my other hand and tried to move the skinny part of the shaft up and down, in and out. I expected in and out, but did not expect to find a slight amount of up and down movement. I'd say about 2-3mm. Made me think maybe the joint on the inside is bad? this shaft, of course, is the longer one, that goes to the RHS wheel. I could not get the same movement out of the shorter LHS one,
So, could this joint movement possibly be causing my issue, or is it pretty much normal to have some up and down play in the longer joint? I am pulling my hair out trying to figure this out, short of replacing the tranny, and hoping that fixes it. I drained fluid from the drain pan, and there is no sign of excess metal, or slot-machine chunks coming out. Fluid looks and smells serviceable. ANY suggestions welcome.
2014 Hyundai Elantra
2014 Hyundai Elantra GT
A 55 Gallon Drum And A Shovel Can Solve A lot of Life's Little "Problems"
Re: Tranny Makes Clicking noise When Decelerating [Re: Propflux01] #4603910
12/14/17 09:59 PM
12/14/17 09:59 PM
Phoenix
dishdude Online content
dishdude  Online Content
Phoenix
I'd say you found it. Joint it coming apart.
2018 Challenger SRT
Re: Tranny Makes Clicking noise When Decelerating [Re: Propflux01] #4603927
12/14/17 10:22 PM
12/14/17 10:22 PM
midwest
JamesBond Offline
JamesBond  Offline
midwest
Can you stand outside the car while someone drives by and reproduces the noise to see which side the noise is? With the up and down movement of the axle I might just throw an axle in it. Advance auto has 30% off right now.
Re: Tranny Makes Clicking noise When Decelerating [Re: Propflux01] #4603941
12/14/17 10:45 PM
12/14/17 10:45 PM
Arkansastan
Arkansastan
On the jacks I started the car, put in gear, and can reproduce it. I can only get a general idea as to where its actually coming from. Sounds like where the joints go into the tranny. of course, when stopped, I can shake either joint and get a noise in roughly the same area.
Re: Tranny Makes Clicking noise When Decelerating [Re: dishdude] #4603945
12/14/17 10:50 PM
12/14/17 10:50 PM
Arkansastan
Arkansastan
If so, I look at parts, and there is a 25-spline and a 27-spline shaft.. Go figure..
Re: Tranny Makes Clicking noise When Decelerating [Re: Propflux01] #4604005
12/15/17 12:24 AM
12/15/17 12:24 AM
WI
HoosierJeeper Offline
WI
I think a little bit of play is normal in that intermediate shaft (inner shaft). I actually might lean towards it being the bearing that shaft rides on.
15 Jeep KL Limited V6: Formula Shell 5W20
07 LR3 SE V8: Maxlife 5W30
05 Jeep KJ Limited: PHM 5W30
96 Jeep XJ Country: STP HM 5W30 (winter)
Re: Tranny Makes Clicking noise When Decelerating [Re: Propflux01] #4604094
12/15/17 06:31 AM
12/15/17 06:31 AM
Arkansastan
Arkansastan
You mean the hub bearing?
Re: Tranny Makes Clicking noise When Decelerating [Re: Propflux01] #4605323
12/16/17 12:47 PM
12/16/17 12:47 PM
Arkansastan
Arkansastan
Re: Tranny Makes Clicking noise When Decelerating [Re: Propflux01] #4605329
12/16/17 12:57 PM
12/16/17 12:57 PM
OH
SatinSilver Offline
SatinSilver  Offline
OH
Does the car have plastic wheel covers on it? Take those off and see if the noise goes away. Sometimes the retention system gets messed up. Happened on the 05 Matrix.
Re: Tranny Makes Clicking noise When Decelerating [Re: Propflux01] #4605338
12/16/17 01:15 PM
12/16/17 01:15 PM
Arkansastan
Arkansastan
those are gone long ago. Just the black steel wheels.
Re: Tranny Makes Clicking noise When Decelerating [Re: Propflux01] #4605339
12/16/17 01:16 PM
12/16/17 01:16 PM
Arkansastan
Arkansastan
Here is CV joint:
http://i6.photobucket.com/albums/y240/pr...pssnjlokni.jpeg
This is the way I found it. Bad or?
Note: Boots are intact and not cut.
Re: Tranny Makes Clicking noise When Decelerating [Re: Propflux01] #4605604
12/16/17 05:44 PM
12/16/17 05:44 PM
Phoenix
Phoenix
Here is CV joint:
Photobucket is the absolute worst, I can't even get the picture to show.
2018 Challenger SRT
Re: Tranny Makes Clicking noise When Decelerating [Re: Propflux01] #4605636
12/16/17 06:11 PM
12/16/17 06:11 PM
Arkansastan
Arkansastan
I wish this site would let me upload normally,like pretty much every other site I frequent
Re: Tranny Makes Clicking noise When Decelerating [Re: Propflux01] #4605648
12/16/17 06:28 PM
12/16/17 06:28 PM
OH
SatinSilver Offline
SatinSilver  Offline
OH
After you click reply, click the box with the blue up arrow on it. About four places over from the smile face. Then you can upload pics directly.
Re: Tranny Makes Clicking noise When Decelerating [Re: SatinSilver] #4606140
12/17/17 11:50 AM
12/17/17 11:50 AM
Arkansastan
Arkansastan
Thank you!! I never knew that was there!! Used to be we had to use a third party server. Anyway, here is the CV joint (the one that has the small amount of ply. I have NO idea where the grease came from.
