Which car to buy?
by jrcowboys. 12/12/18 04:55 PM
New Tire Cracking
by robd. 12/12/18 04:43 PM
SAR B6P - Thoughts?
by 28oz. 12/12/18 03:59 PM
Time to sell the 1-ton Dually
by 02SE. 12/12/18 03:55 PM
Shell Rotella Grease
by WMW0505. 12/12/18 02:27 PM
Need to add attic ladder in stairwell
by Klutch9. 12/12/18 12:51 PM
Mystik JT-8 15w40, 2015 RAM EcoDiesel, 4,995 mi
by SavagePatch. 12/12/18 12:45 PM
Fram Tough Guard Air Filters at Rock Auto
by Snagglefoot. 12/12/18 12:42 PM
Electrical contact cleaner
by CELICA_XX. 12/12/18 12:32 PM
5w-30 in 277k mile chevy 350 tbi
by dogememe. 12/12/18 12:22 PM
voltage test for coolant condition
by NissanMaxima. 12/12/18 12:17 PM
paying Premiun for the name(infiniti/nissan
by 2008wrx. 12/12/18 11:25 AM
POE oil (R-410a)
by WyrTwister. 12/12/18 09:44 AM
Any Volvo Owners, need some help!
by LazyDog. 12/12/18 09:34 AM
NOACK & Sheer
by WyrTwister. 12/12/18 09:34 AM
Rotary help. 2010 series 2 RX8
by TinyVoices. 12/12/18 08:32 AM
Can you mathematically estimate top speed?
by KCJeep. 12/12/18 08:06 AM
2019 GM 6.2 AFM
by XL1200RFan. 12/12/18 07:32 AM
jefe_de_estado, CM613, Geardaddies, 01ws666, ariefnrst
66660 Registered Users
102 registered members (97K15004WD, ad244, 64bawagon, 53' Stude, 28oz, 12 invisible), 1,857 guests, and 35 spiders.
Topics294,990
Posts4,925,550
Members66,660
Most Online2,553
Oct 27th, 2018
2012 Kia Sedona waterpump (w/Hyundai Lambda II V6) #4603565
12/14/17 02:31 PM
12/14/17 02:31 PM
Wisconsin
Short_Bus Offline OP
Wisconsin
I haven't been able to find any repair manual or other instruction online for a water pump replacement for a 2012 Kia Sedona. Since I'm probably not going to do the job myself I wasn't planning on ordering a manual.
There is a very audible howl coming from the engine. I couldn't pinpoint the noise myself so had the little hole-in-the-wall shop next to my work check it out. They pulled the serp belt and found significant play in the water pump pulley and believed that is the source. I like the guy that runs the shop, but it is really pretty sketchy place. He didn't write up a repair quote, he just verbally told me what he thought it was. When I asked him what he would charge to repair it, he pulled up something on his computer and said the book calls for 3.5 hours of labor. Just eyeballing the location of the pump though, I don't see 3.5 hours of labor. It is the top accessory and I don't see any obstructions to access it other than maybe the top engine mount. That mount looks straight forward to remove as well.
Has anyone replaced a water pump on one of these, or even a related Hyundai Lambda II V6? The pump itself cross references to a number of vehicles with the same or similar engine. I did find a reference that says the pump is mounted to the front cover. The only way I can see 3.5 hrs is if the pump is mounted to the back of the cover and the whole front cover has to come off.
Any ideas? I'm hoping the shop referenced an older (2005 and older) Sedona which I think had a more involved process for water pump replacement.
Re: 2012 Kia Sedona waterpump (w/Hyundai Lambda II V6) [Re: Short_Bus] #4603582
12/14/17 02:50 PM
12/14/17 02:50 PM
CA
The Critic Offline
The Critic  Offline
CA
2011 Toyota Prius - 178k - Various 0W-20 (Brew)
2007 Honda Accord 2.4 - 133K - Mobil 1 EP HM 5W-30
Re: 2012 Kia Sedona waterpump (w/Hyundai Lambda II V6) [Re: Short_Bus] #4603591
12/14/17 03:06 PM
12/14/17 03:06 PM
Clovis, CA
Merkava_4 Offline
Merkava_4  Offline
Clovis, CA
The flat rate labor times are listed in the repair service information like AllData or Mitchell. Whoever has a paid subscription to a service information source will be able to tell you what the book time is for your Kia Sedona. You can even get your own subscription at a lower cost as a DIYer, but that will be for one single car. The mechanics get paid a set book time for a specific task even though the actual time may be shorter or longer than book time. The book time will be a set value, but what varies is the shop's hourly rate. So if the shop's hourly rate is $70 per hour, the repair cost will be $70 times book time.
Re: 2012 Kia Sedona waterpump (w/Hyundai Lambda II V6) [Re: The Critic] #4603596
12/14/17 03:22 PM
12/14/17 03:22 PM
Wisconsin
Wisconsin
1.4 hours seems more reasonable.
Re: 2012 Kia Sedona waterpump (w/Hyundai Lambda II V6) [Re: Merkava_4] #4603604
12/14/17 03:40 PM
12/14/17 03:40 PM
CA
The Critic Offline
The Critic  Offline
CA
Not necessarily. A lot of shops use a labor matrix.
Re: 2012 Kia Sedona waterpump (w/Hyundai Lambda II V6) [Re: Short_Bus] #4603605
12/14/17 03:41 PM
12/14/17 03:41 PM
Oshawa, Ontario Canada
JC1 Online content
JC1  Online Content
If you want it done cheaper DIY. The shops go by the book rate plain and simple. Even if the guy could fly through it in 90 mins, the savings don't get passed onto you.
When I was researching doing to the timing belt for my 98 Sienna, a mechanic on the garage journal boards said he could do a Sienna timing belt job in one hour flat. and The stealer gave him a two hour window to complete it.
The pros know all the places fasteners can seize and give them fits and they know all the shortcuts and have all the right wrenches and tools.
There are no videos on YouTube for that motor?
2015 Grand Caravan SXT Plus 5w-20 PPPP/Fram Ultra Filter
1997 Honda Civic CX 5w-30 Shell Conventional/Fram Ultra Filter
Re: 2012 Kia Sedona waterpump (w/Hyundai Lambda II V6) [Re: Merkava_4] #4603607
12/14/17 03:43 PM
12/14/17 03:43 PM
Wisconsin
Wisconsin
I figured he checked something like this, I just didn't really trust that he checked the right thing. He made a quick phone call to someone after checking book rate because he thought it seemed high too. The answer he got on the phone was something about it involving the time belt. Since it doesn't have a belt, it added to my suspicion that something smelled wrong about it.
Re: 2012 Kia Sedona waterpump (w/Hyundai Lambda II V6) [Re: JC1] #4603619
12/14/17 04:02 PM
12/14/17 04:02 PM
Wisconsin
Wisconsin
If I knew if was a straight forward job to unbolt the pump and replace I'd DIY it. If it turns into pulling the entire front of the engine off though, I'm out.
I'm willing to pay the book rate for labor. It's at least a neutral opinion on how long it should take. You win some and you lose some with it. But I'd at least like to be sure the book rate I was quoted is correct.
I came up empty on Youtube. I found older ones, but none with the Lambda based engine.
Re: 2012 Kia Sedona waterpump (w/Hyundai Lambda II V6) [Re: Short_Bus] #4603690
12/14/17 05:15 PM
12/14/17 05:15 PM
CA
The Critic Offline
The Critic  Offline
CA
Do you want instructions?
Re: 2012 Kia Sedona waterpump (w/Hyundai Lambda II V6) [Re: JC1] #4603697
12/14/17 05:22 PM
12/14/17 05:22 PM
Silicon Valley
PandaBear Online content
PandaBear  Online Content
Silicon Valley
This. Sometimes the pro charging a higher hourly rate ends up cheaper than a low hourly rate amateur.
When I shopped around to have adjustable camber arm installed on my dad's Mazda5, an alignment shop refused to do it because the last time they did they have to remove the charcoal canister to get to it. Another alignment shop said 1 hour flat, and the result is right on the dot.
"You keep asking questions PandaBear and you'll end up a vegetarian like my wife" - Camu Mahubah
Re: 2012 Kia Sedona waterpump (w/Hyundai Lambda II V6) [Re: Short_Bus] #4603729
12/14/17 05:52 PM
12/14/17 05:52 PM
TX, USA
JMJNet Offline
JMJNet  Offline
TX, USA
Service Manual?
Have you checked the Hyundai/Kia forum?
If there is somebody who has done it, they are probably there.
  • 2017 Toyota Sienna
Re: 2012 Kia Sedona waterpump (w/Hyundai Lambda II V6) [Re: Short_Bus] #4603834
12/14/17 07:47 PM
12/14/17 07:47 PM
Deplorable in apple valley, ca
Chris142 Offline
Chris142  Offline
Is this the 3.5L?
02 Wrangler carlube 5w30
87 F250 traveler 15w40
07 fjcruiser Chevron 10w30
Z400 castrol T 10w40
Can am maveric edge 5w40
57 case tractor 15w40
Re: 2012 Kia Sedona waterpump (w/Hyundai Lambda II V6) [Re: Short_Bus] #4603883
12/14/17 08:37 PM
12/14/17 08:37 PM
VA
Thax Offline
Thax  Offline
VA
As Critic stated the standard book time for this job is about 1.4 give or take a tenth. This is not a common problem on the Lambda engine, only have done two myself. It is a pretty easy job for a diy , provided you have the necessary tools. Simply drain coolant from radiator, jack up the engine with a jack and block of wood on the oil pan. Remove the engine upper mount, should be a mix of 17mm and 14mm studs/bolts. Turn belt tensioner counter clockwise to get the belt off(good time to replace it). Unbolt the four bolts holding water pump pulley on ,either 10mm or 12mm bolts. Once the pulley is off you can attack the pump itself, should be about 8-10 10mm bolts holding it on. Make sure to get a new gasket, I spay tack the gasket to the pump. Thats not necessary but I find it works for me. Install is just basically the reverse .I also set the new pump gasket out and put the removed bolts in their corresponding holes , to ease install. To fill the system , turn on the heat full blast and slowly fill the system. Its not a super hard job, a nice saturday afternoon type of project for the diy scene.
2000 Ford Explorer Limited 5.0L AWD
2018 KIA Soul EX 2.0L
ASE P2 Parts Specialist
AIA Import Part Specialist
KIA certified Senior Technician, Hybrid certified.
Re: 2012 Kia Sedona waterpump (w/Hyundai Lambda II V6) [Re: Thax] #4603926
12/14/17 09:19 PM
12/14/17 09:19 PM
Wisconsin
Wisconsin
Thanks! Your description is just how I imagined the job would go by looking at it.
It's 12 degrees here with snow on the driveway now and I only have an unheated, small, one-car garage. For 1.5~ of labor, I'll stay out of the cold and have a (less sketchy) shop do it. I have to put some brake pads on this weekend which is enough cold weather punishment for me.
Re: 2012 Kia Sedona waterpump (w/Hyundai Lambda II V6) [Re: Short_Bus] #4603996
12/14/17 10:59 PM
12/14/17 10:59 PM
VA
Thax Offline
Thax  Offline
VA
If you farm out the work , make sure its a reputable shop/dealer. Insist on a new pump gasket and belt depending on your mileage. Using KIA OE coolant wouldnt hurt either, very few cooling system issues for KIA's using OE coolant.
