M1 0W20 EP Good To At Least 10K Miles ?
by ChrisD46. 12/16/18 03:29 AM
Gift for young Army Cadet
by Snagglefoot. 12/16/18 12:33 AM
Instacart Grocery Delivery
by dogememe. 12/16/18 12:26 AM
My brother bought this...
by miden851. 12/15/18 09:12 PM
Watch out for scammers
by Chris142. 12/15/18 08:45 PM
15K OCI R53 2006 Mini Cooper S 144k
by dx92beater. 12/15/18 08:32 PM
Beneficial clean fuel.injectors in Ultrasonic Cleaner
by JLawrence08648. 12/15/18 06:54 PM
Back to Basics III
by MolaKule. 12/15/18 05:30 PM
Castrol Edge 0W40 vs. 5W40...Liqui Moly?
by TiGeo. 12/15/18 04:56 PM
Schumacher XCS15 voltage
by sweezy722. 12/15/18 04:19 PM
Solar battery tenders?
by slybunda. 12/15/18 04:10 PM
Bad Fuel Pressure Regulator.
by NICAT. 12/15/18 04:07 PM
Misfire = clogged cat
by Eric Smith. 12/15/18 04:00 PM
Cellphone Reliability
by Warstud. 12/15/18 03:29 PM
MikeMTL, AJ11, bandito, Spkrdctr, torchredone12
66691 Registered Users
31 registered members (08z06, Dave9, BigRich954, Char Baby, bfleeman, 5 invisible), 953 guests, and 42 spiders.
Topics295,136
Posts4,928,385
Members66,691
Most Online2,553
Oct 27th, 2018
Installation of Wear Indicator Spring? #4603351
12/14/17 10:20 AM
12/14/17 10:20 AM
VA
Gebo Offline OP
Gebo  Offline OP
VA
I'm doing the front pad replacement on my 2005 LS430. Problem is I started last week and am just now going back to finish. Problem is I don't know how to properly replace the spring that holds the wear indicator in place. Well, the problem is I didn't take a picture as I was disassembling LAST Thursday because I knew I could remember what I had done overnight. Problem is there have been too many "overnights".
Any ideas? The bottom piece is just sort of dangling and not touching anything. The pic is deceiving. The top bar seems secure. I can find no holes any where.
'98 LEX LS400 280K
'00 LEX GS300 195K
'02 4Runner 225K
'05 Lex LS430 85K
'06 Toyota Highlander 145K
'09 Lex IS350 85K
'07 Lex GX470 60K
Amsoil in all engines, transmissions and differentials
Re: Installation of Wear Indicator Spring? [Re: Gebo] #4603363
12/14/17 10:24 AM
12/14/17 10:24 AM
VA
Gebo Offline OP
Gebo  Offline OP
VA
'98 LEX LS400 280K
'00 LEX GS300 195K
'02 4Runner 225K
'05 Lex LS430 85K
'09 Lex IS350 85K
'07 Lex GX470 60K
Re: Installation of Wear Indicator Spring? [Re: Gebo] #4603366
12/14/17 10:25 AM
12/14/17 10:25 AM
VA
Gebo Offline OP
Gebo  Offline OP
VA
Maybe it is right? I tried to see how the other side was set up but this wear indicator is only on passenger side front and rear. And rear is a different set up.
'98 LEX LS400 280K
'00 LEX GS300 195K
'02 4Runner 225K
'05 Lex LS430 85K
'09 Lex IS350 85K
'07 Lex GX470 60K
Re: Installation of Wear Indicator Spring? [Re: Gebo] #4603438
12/14/17 11:29 AM
12/14/17 11:29 AM
Cincinnati
quint Offline
quint  Offline
Cincinnati
I just looked at Youtube and they showed the LS430 brakes and they were doing the driver side and it definitely had the anti-rattle spring (I believe thats what it is technically called) in place, so whoever did your brakes last probably messed up....? I have worked on Toyotas that had a similar setup and it was identical on both sides as well.
I worked on one where I had to bend the center of the "spring" up about a quarter inch (relative to the ends), so that when installed it provided tension to the brake pad. Might be what you need to do here.
I haven't actually worked on an LS430 so I cant get too specific.
1993 240sx convertible
2001 Sequoia
2012 Mazda 2
2012 Mazda 3 Totaled 3/16/18, R.I.P
2017 Mazda 3
2017 Kia Rio
Re: Installation of Wear Indicator Spring? [Re: Gebo] #4603556
12/14/17 02:17 PM
12/14/17 02:17 PM
California
nthach Offline
nthach  Offline
California
I haven't pulled the wheels off my parent's LS430 - but it uses an electronic wear indicator - those two wires you see are for the wear sensor - the small spring keeps the wiring from rubbing against the wheel or caliper. That spring looks right to me - the center retaining pin looks like its guided by the big clip.
Re: Installation of Wear Indicator Spring? [Re: Gebo] #4603599
12/14/17 03:25 PM
12/14/17 03:25 PM
VA
Gebo Offline OP
Gebo  Offline OP
VA
That dangling lower wire part of the spring bothers me. Itís just out there in the air.
'98 LEX LS400 280K
'00 LEX GS300 195K
'02 4Runner 225K
'05 Lex LS430 85K
'09 Lex IS350 85K
'07 Lex GX470 60K
Re: Installation of Wear Indicator Spring? [Re: Gebo] #4603602
12/14/17 03:34 PM
12/14/17 03:34 PM
VA
Gebo Offline OP
Gebo  Offline OP
VA
The pads and clips and pin wear indicator are all installed correctly. My question is only concerning that spring with the 2 loops in it that support the wera indicator tube.
'98 LEX LS400 280K
'00 LEX GS300 195K
'02 4Runner 225K
'05 Lex LS430 85K
'09 Lex IS350 85K
'07 Lex GX470 60K
Re: Installation of Wear Indicator Spring? [Re: Gebo] #4603618
12/14/17 03:57 PM
12/14/17 03:57 PM
Modesto,CA
mehullica Offline
mehullica  Offline
Modesto,CA
Itís correctly installed
Re: Installation of Wear Indicator Spring? [Re: mehullica] #4603802
12/14/17 07:09 PM
12/14/17 07:09 PM
VA
Gebo Offline OP
Gebo  Offline OP
VA
Thank you! You are correct! I just got a confirmation from Lexus in NC. I sent pics to Parts Mgr and he confirmed with one of their mechanics.
Case Closed.
'98 LEX LS400 280K
'00 LEX GS300 195K
'02 4Runner 225K
'05 Lex LS430 85K
'09 Lex IS350 85K
'07 Lex GX470 60K
