Originally Posted By: Oldtom
I Fluid Filmed an older Toyota Tacoma with the Kellesport pro gun specifically designed for Fluid Film. I paid about $120 for the gun and nozzles and the entire job took only a few hours. The great advantage of the Kellesport gun is the 36 inch flex nozzle. I was able to snake the nozzle into every frame hole, pull the trigger and pull it out slowly. The gun left a super heavy coat of fluid film INSIDE the box frame. This may be less critical in a truck with a C channel frame. Fluid Film can be applied over existing rust with no surface prep, just spray yearly if you live in a road salt area. Quick, easy, cheap ( $45 per gallon ) Sorry if I sound like a salesman for fluid Film, the stuff flat out works.
But wait, there's more!
Once you have the pro spray gun, you can rust proof vehicles for extra cash. One gallon will do 2 vehicles.
You got ripped off big time I sell the same gun kit for $84.00 and gallons for $39.99 Valley truck in Cleveland
