Scanning for U codes.
by LeakySeals. 12/13/18 12:23 PM
Food photography trickery
by nthach. 12/13/18 11:29 AM
oil for 2.5 2013 vw passat?
by jstert. 12/13/18 09:47 AM
Scotty Kilmer Parody
by oilpsi2high. 12/13/18 09:41 AM
ID this old tool
by John_Conrad. 12/13/18 09:30 AM
Weak New CR2032/remote start + fob batteries
by redhat. 12/13/18 09:23 AM
Smart charges/time
by Duffyjr. 12/13/18 08:24 AM
7.3 powerstroke water pump
by mobilaltima. 12/13/18 07:10 AM
98 Jeep Cherokee, what oil is spec'd?
by otis24. 12/13/18 06:31 AM
fixing LED Christmas lights
by danez_yoda. 12/13/18 06:30 AM
Things are not as they seem to be..
by CourierDriver. 12/13/18 06:09 AM
Oz Ranger Raptor
by Shannow. 12/13/18 05:22 AM
Shop vac recommendations
by dlundblad. 12/13/18 05:06 AM
Internet Network Issues
by ZeeOSix. 12/13/18 04:13 AM
Looking for Fram Ultra XG30 and XG5 cut open
by rubberchicken. 12/12/18 10:27 PM
92 f150 332 code
by ram_man. 12/12/18 10:05 PM
Mixing brands of brake fluid / gear lube
by SureshR. 12/12/18 09:26 PM
Poles19, HinaMach, Horsehaulin, JLew, bmrk1100
66666 Registered Users
88 registered members (94astro, 4WD, 69GTX, 28oz, 240_Ed, 10 invisible), 1,904 guests, and 40 spiders.
Topics295,019
Posts4,926,198
Members66,666
Most Online2,553
Oct 27th, 2018
Blowing out water from pressure washer pump? #4603029
12/13/17 10:15 PM
12/13/17 10:15 PM
Houston, Texas
motor_oil_madman Offline OP
Houston, Texas
I bought a blow out attachment that you can hook to compressed air. I was surprised by how much water came out of the hose and pump. I left it on for about three minutes and it was still a good mist coming out.
My question is as far as storing in cold temps is concerned is this sufficient or should I still put rv antifreeze in it too?
2007.5 dodge cummins 6.7 liter. Chevron Delo400 15w40. 7000 mile or 250-300hr intervals.
Re: Blowing out water from pressure washer pump? [Re: motor_oil_madman] #4603053
12/13/17 11:20 PM
12/13/17 11:20 PM
NY
demarpaint Offline
demarpaint  Offline
NY
Why knock yourself out? For over about 3 decades, give or take I've pulled the cord, water squirted out of the pump, when the stream stopped I add RV anti-freeze then pull the cord until that comes out and cap it off. I never had a pump freeze doing that. The whole process takes a couple of minutes.
I want a volume of fluid in there that has anti-corrosive properties rather than try and blow it out. That method will most likely cause some form of corrosion, and excess moisture could freeze around small seals and "o" rings.
So in answer to your question, yes put the RV anti-freeze in there. HTH
God Bless Our Troops
Re: Blowing out water from pressure washer pump? [Re: motor_oil_madman] #4603113
12/14/17 05:03 AM
12/14/17 05:03 AM
wi
dave123 Offline
dave123  Offline
wi
Same as stated above but do it after every use with pre mix 50% EG antifreeze no reason to blow it out.
Re: Blowing out water from pressure washer pump? [Re: motor_oil_madman] #4603134
12/14/17 05:50 AM
12/14/17 05:50 AM
Oneida County, NY
rsylvstr Offline
rsylvstr  Offline
Oneida County, NY
Wow. Iíve never done either.
2013 F150 SCrew Lariat 4X4 5.0 3.55
2012 Altima SL that still vibrates.
2018 Polaris Sportsman 850 SP. Polaris fluids and filter.
Re: Blowing out water from pressure washer pump? [Re: motor_oil_madman] #4603264
12/14/17 08:54 AM
12/14/17 08:54 AM
Houston, Texas
Houston, Texas
After blowing the water out i went ahead and filled the hose with the rv antifreeze and blew that through too.
Re: Blowing out water from pressure washer pump? [Re: motor_oil_madman] #4603298
12/14/17 09:21 AM
12/14/17 09:21 AM
Houston, Texas
Houston, Texas
Demar I wanted to be able to get the water out of the pressure washer hose. That's why I got the blow out attachment.
Re: Blowing out water from pressure washer pump? [Re: motor_oil_madman] #4606013
12/17/17 08:10 AM
12/17/17 08:10 AM
USA
mk378 Offline
mk378  Offline
USA
Generally you should follow the manufacturer's instructions for winterizing rather than half-bake your own regimen.
Re: Blowing out water from pressure washer pump? [Re: motor_oil_madman] #4607978
12/19/17 08:44 AM
12/19/17 08:44 AM
Illinois
tig1 Offline
tig1  Offline
Illinois
After every use I purge my pump with pump lubricant that not only lubes the pump but purges water from the system. You can buy it everywhere pressure washers are sold. Here is a link.
http://www.sears.com/briggs-stratton-pum...CFTPJ4wcdqQMN4Q
2007 Ford Fusion 235,000 miles
M1 0-20 EP
2017 Ford Fusion 60K
M1 0-20 EP
M1 ATF and Valvoline LV
M1 10-30 in all OPE
MC filters
Re: Blowing out water from pressure washer pump? [Re: motor_oil_madman] #4617463
12/29/17 07:36 AM
12/29/17 07:36 AM
Houston, Texas
Houston, Texas
I would think the way I did it would be fine. I do t really want to spend the money on a pump winterizing can every time I use it.
