New car wax score
by Marco620. 01/16/19 02:42 PM
Bought a used Cherokee Trailhawk
by Sunnyinhollister. 01/16/19 02:34 PM
Air Fryer....whose got'em?
by Schmoe. 01/16/19 01:59 PM
ebates - anyone a member?
by Papa Bear. 01/16/19 01:29 PM
Ordered a 2019 X5 for the Wife
by gofast182. 01/16/19 12:48 PM
Today, I ride
by SirTanon. 01/16/19 12:02 PM
2019 Nissan Rogue SL
by JTK. 01/16/19 11:19 AM
Does GM oil life monitor % go down without driving?
by Corollaman. 01/16/19 10:37 AM
Ford tire wear issues?
by Redright9. 01/16/19 10:23 AM
New Battery
by CarlGR. 01/16/19 10:21 AM
It's January and I Need My Motorcycling "Therapy" !!
by LoneRanger. 01/16/19 10:13 AM
Are New Vehicles Too Expensive?
by SubLGT. 01/16/19 10:02 AM
Manual transmission fluid in Europe for Mazda
by zsero. 01/16/19 07:31 AM
Affected by the gov't shutdown?
by xBa380. 01/16/19 07:04 AM
Opinion Needed / 1998 Olds 88
by Mark72. 01/16/19 06:24 AM
Chevron Supreme color change
by OilUzer. 01/16/19 05:14 AM
Dual exhaust benefits
by OilUzer. 01/16/19 03:02 AM
M1 0w40
by Pinoak. 01/16/19 01:55 AM
M1 0w40
by Pinoak. 01/16/19 01:51 AM
VV03, Witchipoo, Durco1977, ConnorM, dkar26
66950 Registered Users
116 registered members (4WD, 53' Stude, 28oz, 2004tdigls, 2002 Maxima SE, 10 invisible), 2,214 guests, and 35 spiders.
Topics296,645
Posts4,956,535
Members66,950
Most Online2,577
Jan 14th, 2019
Dumbest thing I've done in a while.. #4602853
12/13/17 07:05 PM
12/13/17 07:05 PM
South Louisiana
Soggydog Offline OP
Soggydog  Offline OP
South Louisiana
I was helping my dad with his mclane edger last weekend and he mentioned a pair of generators he had in a shed that flooded. He claimed both were new, one "honda" and one "onan". We retreived the honda which was a honda gx390 powered Blackmax brand that I had often seen for sale at Sam's club. The onan, still in the box, had some stuff stacked on it so we left it for later.
I've hed pretty good luck getting most of my junk running after the same flood so I volunteered to take a look at it.
There was oil and water in the crankcase, a rusty liquid substance in the fuel tank and thankfully no water above the piston. I drained the oil, flushed the fuel tank (best I could) and cleaned the carb. I got it running breifly and then the fuel filter clogged. I then drained the milky oil again and refilled it. I replaced the fuel filter and fired it back up. After about 45 seconds the fuel filter clogged again and I drained the milky oil again. The oil was clearer this time and I noticed some (rust??) particles flowing out the drain hole. I got the bright idea to flush it out by spraying carb cleaner through thd fill hole while the the old oil was dripping out the opposite side of the block. The plan seemed to work out till I saw the red straw thing disappear into the fill hole.
It was getting dark and my patience was suddenly wearing thin so I left it for tomorrow. I'll try to work the straw out a little more tomorrow but I refuse to open up the case. Doing so will require removing the generator head from the tapered shaft which I'm sure is well rusted into place.
Currently running...
2011 Ford F250 4x4 6.7L, 2011 Toyota Camry SE 2.5L, 2002 Dodge Caravan 3.3L,
2012 Honda Rincon,2012 Honda Rancher AT,09 Honda Trx90
Re: Dumbest thing I've done in a while.. [Re: Soggydog] #4602892
12/13/17 07:47 PM
12/13/17 07:47 PM
Port Orange, Florida
Panzerman Online happy
Panzerman  Online Happy
Turn it upside down and the red straw should fall back out otherwise I wouldn't worry about it. It will just get chewed up. Not like a Uranium rod in there.
2006 Dodge Ram 2500 Hemi 4x4
2016 Dodge Challenger Scat Pack
Re: Dumbest thing I've done in a while.. [Re: Soggydog] #4602930
12/13/17 08:23 PM
12/13/17 08:23 PM
Pittsburgh,PA U.S.A.
JimPghPA Offline
JimPghPA  Offline
Some of those generator motors have plastic gears in them for the cam, or governor. If it has any plastic gear the plastic straw may be enough to mess them up if it were to get caught between the teeth of the gear.
Boy will I be happy when ALL vehicles on public roads are autonomous.
JimPghPa
Re: Dumbest thing I've done in a while.. [Re: Soggydog] #4602944
12/13/17 08:39 PM
12/13/17 08:39 PM
Jupiter, Florida
Cujet Offline
Cujet  Offline
Jupiter, Florida
I've done that! I was able to clean out the sump and get the straw out. Took a little effort and fishing around with a some thin wire.
Re: Dumbest thing I've done in a while.. [Re: Soggydog] #4603051
12/13/17 11:19 PM
12/13/17 11:19 PM
Clovis, CA
Merkava_4 Offline
Merkava_4  Offline
Clovis, CA
I've made some mistakes so dumb that by comparison, you would look like the most brilliant angle God has in heaven.
Re: Dumbest thing I've done in a while.. [Re: Soggydog] #4603076
12/14/17 12:36 AM
12/14/17 12:36 AM
S California
OneEyeJack Offline
OneEyeJack  Offline
S California
Funny, I've yet to make a smart mistake.
I'd go after it. Then make the decision to run it or not. If you don't get the spray nozzle and run it and there's no problem then your smart, a genius maybe. If you tank the engine you're an idiot.
Re: Dumbest thing I've done in a while.. [Re: Soggydog] #4603099
12/14/17 04:12 AM
12/14/17 04:12 AM
N.Ohio
Lubener Offline
Lubener  Offline
N.Ohio
Some day , someone will invent the superior, fly proof applicator straw. I have lost more of those in all kinds of places than I can name.
The "thinking" man's friend.
Re: Dumbest thing I've done in a while.. [Re: OneEyeJack] #4603110
12/14/17 05:00 AM
12/14/17 05:00 AM
Indiana
dlundblad Offline
dlundblad  Offline
Indiana
Same!
Mistake 1: Speaking of DUMB mistakes and dropping articles into the abyss, I about lost the tensioner bolt for her car when we did the timing belt. I set it on the intake manifold once unbolted. Did some other stuff and went to lunch. Came back, did some more stuff, positioned the belt etc. went to grab the bolt and clunk. It fell somewhere into the engine... Lots of metallic contacting sounds on the way down. I probably searched for 15 minutes saying every swear word imaginable. Come to find out, it fell on the splash pan under the car..
Mistake 2: Not sure why I didn't use my HF magnetic bowl. It was right there with other nuts/ bolts.
03 Jeep WJ 4.0 202k Edge 10w40 HM Fram XG16
02 Volvo S60 2.4T 186k M1 0w40 Mahle OX149D
97 Chevy Blazer 4.3 153k Synpower 5w30 Supertech ST3980 (Ecore)
Re: Dumbest thing I've done in a while.. [Re: Soggydog] #4603153
12/14/17 06:15 AM
12/14/17 06:15 AM
Sweden
lars11 Offline
lars11  Offline
Sweden
consider it viscosity improver! Or.... not
I would try to fish it out, sometimes luck, swearing and wire can solve these situations. Trust me, I know.
Re: Dumbest thing I've done in a while.. [Re: lars11] #4603165
12/14/17 06:30 AM
12/14/17 06:30 AM
Champlain/Hudson Valley
Kira Offline
Kira  Offline
LOOK, LOOK....another call for an optical viewer. Poke it into whatever holes you have and look around!
Then you'd know where to go fishing.
How 'bout a "community owned" optical viewer? No one person needs one for long!
Re: Dumbest thing I've done in a while.. [Re: Soggydog] #4603203
12/14/17 07:38 AM
12/14/17 07:38 AM
Upstate NY
Donald Online content
Donald  Online Content
Upstate NY
Getting a generator head off a tapered shaft is not easy. I needed to do it on a Winco generator and pulled off the generator housing and then used a block of hard wood and a few good whacks of a small sledge hammer to loosen it. This was all mentioned in a Winco document.
2015 Ford F250 w/Powerstroke
Re: Dumbest thing I've done in a while.. [Re: Soggydog] #4603207
12/14/17 07:43 AM
12/14/17 07:43 AM
One Step Beyond
MasterSolenoid Offline
One Step Beyond
I made a mistake once,
I thought I made a mistake, but I didn't.
2002 Ford Ranger
2 Wheel Drive
3.0 Liter Engine
Four basic premises of writing:
Clarity, Brevity, Simplicity, and Humanity.
Re: Dumbest thing I've done in a while.. [Re: Soggydog] #4603352
12/14/17 10:20 AM
12/14/17 10:20 AM
South Louisiana
Soggydog Offline OP
Soggydog  Offline OP
South Louisiana
I'll work on it some more this weekend.
Maybe i'll flush it with some diesel and the straw will work it's way out or tilt the unit towards the fill hole and it'll show it's self where I can grab it with some needle nose.
Re: Dumbest thing I've done in a while.. [Re: Soggydog] #4603465
12/14/17 11:54 AM
12/14/17 11:54 AM
Wisconsin
Srt20 Offline
Srt20  Offline
Wisconsin
If I couldnt get it out in 5 mins, Id leave it.
Re: Dumbest thing I've done in a while.. [Re: Soggydog] #4603948
12/14/17 09:53 PM
12/14/17 09:53 PM
Lakeside CA
another Todd Offline
Lakeside CA
Amsoil used to sell a straw leash. It was rubber with a large end for going around the can and a tiny end you stuck the straw through, worked awesome. I am not sure if they still have them.
2015 Ford F250 Diesel Crew Cab FX4
2017 Ford Escape 2.0
2002 GMC Yukon
2015 Hyundai Accent
2008 Yamaha Rhino 700 FI
