Valve issues
by kawie_guy. 09/21/18 01:54 PM
2018 Elantra SE
by wolf_06. 09/21/18 01:36 PM
Nasty looking oil filter
by atikovi. 09/21/18 12:43 PM
Laughing hard.
by StevieC. 09/21/18 12:26 PM
Apologies
by Drew99GT. 09/21/18 12:15 PM
Would Like the Manual Transmission to Make a Comeback?
by Speak2Mountain. 09/21/18 11:39 AM
Leaf Mulcher
by kwijibo. 09/21/18 11:32 AM
Pizza dough too crusty
by zorobabel. 09/21/18 11:26 AM
Lubegard Red or Platinum
by diyjake. 09/21/18 11:01 AM
Storing Car Outside
by Delta. 09/21/18 10:47 AM
Looking at a cheap commuter!
by ryan2022. 09/21/18 09:46 AM
Does Your 3.5EB Make Oil
by Gene K. 09/21/18 09:07 AM
F150 Front Differential
by hatt. 09/21/18 08:45 AM
EU version of Subaru 2.5 FB engine
by IMPALA08. 09/21/18 08:40 AM
New “rules” changing your choice of car?
by daves87rs. 09/21/18 06:04 AM
WIX51334XP Oil Filters
by CB900F2. 09/21/18 05:14 AM
Signal Oil Company radio advertising
by 21Rouge. 09/21/18 04:07 AM
Anyone "Wim Hof"ing ?
by Shannow. 09/21/18 02:35 AM
ScottRousell, Direct_Rejection, donatom, Sylent_Snyper, Ajizzle
66034 Registered Users
100 registered members (853okg, 2010Civic, 14Accent, Al, 10 invisible), 1,801 guests, and 42 spiders.
Topics290,766
Posts4,849,983
Members66,034
Most Online3,590
Jan 24th, 2017
Toying with the idea of Replacing Oxygen Sensor #4602685
12/13/17 04:25 PM
12/13/17 04:25 PM
Clovis, CA
Merkava_4 Offline OP
Clovis, CA
Quote:
What are the symptoms of a bad oxygen sensor?
Symptoms of a Bad Oxygen Sensor:
When you have a bad oxygen sensor, your vehicle will run less efficiently, it can sometimes have a poor idle, erratic jerking at steady throttle, hard starting problems, cause the check engine light to come on, and will cause high fuel consumption.
Quote:
How do you know if your oxygen sensor is bad?
Check this list to see if it's time to replace YOUR vehicle's oxygen sensors:
Sudden decrease in fuel mileage....
Flashing check engine light or malfunction indicator lamp in the vehicle?s dash board....
Failure to pass smog....
Overall poor vehicle performance; rough idling, stalling, hesitation on acceleration, etc.
2000 Buick LeSabre
My fuel mileage has been pegged at 17.1 mpg for several months now. When I first bought the car when it was only 5 years old, fuel mileage was pegged at 19.6 mpg. Some websites recommend changing the oxygen sensor every 100k. The car now has over 131k and is still on the original upstream and downstream oxygen sensors. Idle quality is not super smooth and fuel mileage is down. No scanner to check fuel trims, so if I replaced the upstream oxygen sensor, it would be based on a hunch and the above info.
Re: Toying with the idea of Replacing Oxygen Sensor [Re: Merkava_4] #4602692
12/13/17 04:28 PM
12/13/17 04:28 PM
North Carolina
spasm3 Offline
spasm3  Offline
North Carolina
I have picked up mileage on cars past 100k by changing the upstream sensors. Not a huge change but say 1.5-2mpg.
13 elantra 70k 5w30 QSUD
03 chevy avalanche79k synpwr 10w30
01 saturnsc1 185k synpwr rebuilt
17 mazda cx-5 5600 miles m1 0w30
Re: Toying with the idea of Replacing Oxygen Sensor [Re: spasm3] #4602693
12/13/17 04:29 PM
12/13/17 04:29 PM
Clovis, CA
Clovis, CA
spasm3 - Did your engine's idle quality smooth out too ?
Re: Toying with the idea of Replacing Oxygen Sensor [Re: Merkava_4] #4602697
12/13/17 04:36 PM
12/13/17 04:36 PM
OH
SatinSilver Offline
SatinSilver  Offline
OH
Could just be the winter fuel blend decrease in mpg you're noticing. See if the car still has the same mileage next June.
Re: Toying with the idea of Replacing Oxygen Sensor [Re: Merkava_4] #4602698
12/13/17 04:38 PM
12/13/17 04:38 PM
Champlain/Hudson Valley
Kira Offline
Kira  Offline
1) "It's always the front one" uncredited quote
2) A neighbor with a V-6 @ 135mpg had all replaced when one threw a code.
She thought her garage an honest one.
3) My front O2 sensor went out and saw a measured 20% drop in mileage.
Your's fell 13%.
CONCLUSION: I don't know.
edit: spasm, 1.5 - 2 mpg AIN'T SMALL.
Re: Toying with the idea of Replacing Oxygen Sensor [Re: Merkava_4] #4602704
12/13/17 04:43 PM
12/13/17 04:43 PM
The Midwest
skyactiv Offline
skyactiv  Offline
The Midwest
If there is an NTK sensor for it cheap, buy that. The spark plug company NGK make them.
You can test them with an oscilloscope.
http://www.sixityauto.com/ngk-ntk-oxygen...AiABEgJxi_D_BwE
Me: 13' VW GTI 3 door 6 speed manual
Re: Toying with the idea of Replacing Oxygen Sensor [Re: SatinSilver] #4602705
12/13/17 04:43 PM
12/13/17 04:43 PM
Orlando, FL
Mr Nice Offline
Mr Nice  Offline
Orlando, FL
True.
Or it could be a lazy O2 sensor needing replacement.
Re: Toying with the idea of Replacing Oxygen Sensor [Re: Mr Nice] #4602718
12/13/17 05:01 PM
12/13/17 05:01 PM
OH
SatinSilver Offline
SatinSilver  Offline
OH
True.
Or it could be dragging brakes, low tire pressure, the OP gaining weight with the holidays approaching. All sorts of things to ponder. But for $40 not a bad price for a quality part. The same NTK front 02 sensor on the Matrix runs $280. But if it was AWD the price would be around $80. crazy
Re: Toying with the idea of Replacing Oxygen Sensor [Re: Merkava_4] #4602736
12/13/17 05:32 PM
12/13/17 05:32 PM
Silicon Valley
PandaBear Offline
PandaBear  Offline
Silicon Valley
You're from California. The best way to see if your O2 is working is to look at your SMOG test result. High CO, HC, NoX and you should just try a new O2. I think most cars are $20-30 from Rockauto these days. It is worth replacing as a preventive maintenance once in a while (i.e. every 100k or so).
"You keep asking questions PandaBear and you'll end up a vegetarian like my wife" - Camu Mahubah
Re: Toying with the idea of Replacing Oxygen Sensor [Re: Merkava_4] #4602744
12/13/17 05:47 PM
12/13/17 05:47 PM
Marshfield , MA
andyd Online content
andyd  Online Content
Marshfield , MA
you can test an O2 sensor with a voltmeter. A good one will dither between .2 and .9 rapidly. If it is slow to change or doesn't change , it is NG.
Thick oil is better grin2
Re: Toying with the idea of Replacing Oxygen Sensor [Re: Merkava_4] #4602757
12/13/17 06:02 PM
12/13/17 06:02 PM
Middlesex County CT
simple_gifts Offline
Middlesex County CT
Based on some of your posts, you should invest in an oxygen sensor in the cabin of the vehicle
j/k.
2004 Prius; 97K ML Syn 5W-30
2007 Yaris 71K 0w-40 Castrol
2006 B2300;130K;ALM
Was driving an ox cart; Now on the USS Enterprise
Re: Toying with the idea of Replacing Oxygen Sensor [Re: Merkava_4] #4602772
12/13/17 06:17 PM
12/13/17 06:17 PM
WI
HoosierJeeper Offline
WI
Any codes? I wait to replace till I get a code.
15 Jeep KL Limited V6: Formula Shell 5W20
07 LR3 SE V8: Maxlife 5W30
05 Jeep KJ Limited: PHM 5W30
96 Jeep XJ Country: STP HM 5W30 (winter)
Re: Toying with the idea of Replacing Oxygen Sensor [Re: Merkava_4] #4602781
12/13/17 06:37 PM
12/13/17 06:37 PM
North Carolina
spasm3 Offline
spasm3  Offline
North Carolina
No, no change, there was no idle issue for me. I just replaced them due to mileage. It was an 03 ford escape v-6 with 130k at the time.
Re: Toying with the idea of Replacing Oxygen Sensor [Re: Merkava_4] #4602792
12/13/17 06:50 PM
12/13/17 06:50 PM
New England
NibbanaBanana Offline
New England
I replaced 3 out of 4 in the first six months of owning my E150. At AZ's recommendation after they scanned it for me. Every couple months I'd get a CEL. They'd scan it and recommend an O2 sensor. Did some more research after the CEL came on again. Changed the isolator bolts. It's been working for a few years now. Have a feeling I didn't need to change those O2 sensors.
Replaced the downstream in the Aveo after the scan read low voltage. After that failed to fix it I found a very small crack in the exhaust right below the sensor. Replaced the exhaust pipe and everything was fine.
Replaced one in a 1990 Dodge B250 that was bad.
Ran 185K and 186K miles on two Geo metros and never a problem with the O2 sensors.
That's my experience with O2 sensors.
1993 Ford E350 5.8L, 68K
2002 Ford E150 4.2L, 85K
2006 Chevy Aveo 1.6L 215K
2013 Kia Reo 1.4L, 101K
7500 OCI, M1 5-30 winter, M1 10-30 summer
Re: Toying with the idea of Replacing Oxygen Sensor [Re: Merkava_4] #4602823
12/13/17 07:28 PM
12/13/17 07:28 PM
Phoenix
dishdude Offline
dishdude  Offline
Phoenix
Merk, if you have money you want to throw away I'll PM you my address.
2018 Challenger SRT
