2005 Pontiac GTO | 44,750 miles | 6-Speed
by Georgiey22. 03/25/19 10:39 PM
GWR Silencer Spray
by agpatel. 03/25/19 10:30 PM
Fuel line insulation to remedy vapor lock?
by motor_oil_madman. 03/25/19 10:22 PM
Running a fan to reduce humidity
by motor_oil_madman. 03/25/19 10:15 PM
stuck grease zerk on my JD tractor
by PaulH. 03/25/19 09:33 PM
S&W M&P 2.0 9MM Range Time
by 2015_PSD. 03/25/19 09:26 PM
Poor quality Ford wheel finish...
by gregk24. 03/25/19 09:12 PM
2013 GMC SIERRA PICKUPS
by Honda2003. 03/25/19 09:10 PM
Fighting HOA - anyone have any luck?
by pezzy669. 03/25/19 09:05 PM
Here's an oldie "Riding a film of oil"
by dbias. 03/25/19 08:47 PM
'14 Mopar 62TE transmission service?'s
by sloinker. 03/25/19 08:25 PM
Dodge Transmissions (Humor)
by StevieC. 03/25/19 07:57 PM
How a differential works
by StevieC. 03/25/19 07:37 PM
My first!
by BigMoneyGrip. 03/25/19 07:20 PM
Sizing Rims for 17 inch Light Truck Tires
by Snagglefoot. 03/25/19 06:38 PM
Mobil 1 Cartridge Filters On Clearance at WM
by IndyFan. 03/25/19 06:19 PM
Ford Unibody Pickup
by SubLGT. 03/25/19 05:52 PM
DCDMan, silverbullet21, gentzel, ksu90, SMA2020
67622 Registered Users
89 registered members (Aichiguy, agpatel, AdditiveOCD, 77GrandPrix, 2015_PSD, 12 invisible), 1,437 guests, and 61 spiders.
Topics286,436
Posts4,908,161
Members67,622
Most Online2,967
Mar 10th, 2019
Page 1 of 3 1 2 3
Is it ok to switch gas stations? #4602144
12/12/17 10:15 PM
12/12/17 10:15 PM
ILL
boostedtsiawd Offline OP
ILL
I just bought this car and i have no idea what type of gas the previous owner used in it but it takes premium and i always fill at shell but i couldn't find a shell station close by so i filled up with bp premium but now its getting low on gas and i wanna fill up with shell vpower is it ok to mix bp with shell gas as long as its premium? i really wanted the gas to get close to empty so i can fill with shell v power like i always do but its winter and i dont wanna leave the tank low.
Re: Is it ok to switch gas stations? [Re: boostedtsiawd] #4602145
12/12/17 10:16 PM
12/12/17 10:16 PM
Central Washington
Colt45ws Offline
Colt45ws  Offline
Central Washington
It doesnt matter at all.
-Colton
2002 Ford Crown Vic PI 207k, Ex-Kootenai County, ID Unit #42
Down for engine swap
2003 Ford Crown Vic PI 86k
Pennzoil Conv HM 5W30, Fram XG2
Re: Is it ok to switch gas stations? [Re: boostedtsiawd] #4602147
12/12/17 10:17 PM
12/12/17 10:17 PM
Upper Midwest
kschachn Offline
kschachn  Offline
Upper Midwest
What would you do if you were on a trip and had to stop somewhere where there weren’t any Shell stations?
This is the first time in your life you’ve had to confront the possibility of using another brand?
1994 BMW 530i, 241K
1996 Honda Accord, 267K
1999 Toyota Sienna, 409K
2000 Toyota ECHO, 280K
Re: Is it ok to switch gas stations? [Re: boostedtsiawd] #4602149
12/12/17 10:19 PM
12/12/17 10:19 PM
Wet side WA
JohnnyJohnson Online content
JohnnyJohnson  Online Content
Wet side WA
Fill it up at Costco for probably 30 cents a gallon less!
2004 Corolla 130035
Out: EDGE EP 5W-30 Bosch 3311 7156 Miles
In: Havoline Pro DS 10w-30 Purolator PureOne 3-14-19 129693
2006 Duramax 74725
Out: T6 5W-40 M1-303
In: T6 5W-40 XG9100 73705 4-22-18
Re: Is it ok to switch gas stations? [Re: boostedtsiawd] #4602151
12/12/17 10:21 PM
12/12/17 10:21 PM
Great Lakes
Quattro Pete Offline
Great Lakes
LOL at the questions on BITOG these days.
'02 530i (Edge 0W-40)
'15 Q5 3.0T (Edge 5W-40)
'18 Charger SRT (PUP 0W-40 SRT)
Re: Is it ok to switch gas stations? [Re: boostedtsiawd] #4602157
12/12/17 10:26 PM
12/12/17 10:26 PM
Virginia
bbhero Online sick
bbhero  Online Sick
Virginia
Shell V power has a lot of sulfur ions in it and it can bond with the extra carbon ions in the BP 93 and form sulfuric acid in your gas tank. Which would obviously destroy your gas tank and fuel lines... Goodness gracious what that combo would do to your combustion chamber...
Nissan Altima 3.5 Coupe
Mobil Super 5w30 Wix 57356
"Treat your family like your friends and treat your friends like your family."
Re: Is it ok to switch gas stations? [Re: boostedtsiawd] #4602159
12/12/17 10:27 PM
12/12/17 10:27 PM
Kalifornia Kollective
BrocLuno Offline
BrocLuno  Offline
Yeah, sure I'd be worried about gasoline making acid ...
Even though it says premium on the gas cap and maybe in the OM, it might be fine on "regular". It depends on your local gasoline blends (required additives), the ambient temp, the way you drive, and the relative humidity.
If you were at the drags or circle tracks, we'd be either re-jetting or changing the fuel curve (digital) for the local conditions of the moment. But OEM systems are more general and can mostly run any fuel that will go in the tank. Anywhere from 0% to 15% ethanol, etc.
So give it a shot of regular. Say 5 gallons and see what it runs like? If it pings and/or gives you any thing to worry about, top up with premium and you know... If it runs normally, you know you are good on whatever is readily available smile
My wife's Jag specifically says Premium everywhere. It's been on regular since she bought, well over 100,000 miles. It runs fine for her and never hick-ups at all laugh
Re: Is it ok to switch gas stations? [Re: BrocLuno] #4602167
12/12/17 10:34 PM
12/12/17 10:34 PM
Virginia
bbhero Online sick
bbhero  Online Sick
Virginia
You hopefully realize that I am kidding around here smile Not being remotely serious.
Re: Is it ok to switch gas stations? [Re: Quattro Pete] #4602169
12/12/17 10:36 PM
12/12/17 10:36 PM
Katy, Republic of Texas
blupupher Offline
blupupher  Offline
Yup, I guess this is what it has come to.
2018 Hyundai Santa Fe: Delo XLE 10w-30, OEM filter, 3k
2012 Scion xB: QSUD 0w-20, CQ Blue, 5k
2002 Ford F150: Magnatec 5w-20, Bosch D+, 1yr
1994 Honda VT1100: Peak 15w-40, PSL, 1yr
Re: Is it ok to switch gas stations? [Re: boostedtsiawd] #4602171
12/12/17 10:37 PM
12/12/17 10:37 PM
ON, Canada eh?
StevieC Online content
StevieC  Online Content
ON, Canada eh?
I drive all day long for work. I use the cheapest gas I can find and from any station offering it. I have 0 issues.
'18 Dodge Grand Caravan GT - 26k KM - AMSOIL SS 0w20
'06 Hyundai Santa Fe - 535k KM AMSOIL SS 0w30
Re: Is it ok to switch gas stations? [Re: boostedtsiawd] #4602180
12/12/17 10:52 PM
12/12/17 10:52 PM
Virginia
bbhero Online sick
bbhero  Online Sick
Virginia
I would run the highest octane gas if it were recommended in the owner's manual. However like Brucluno said there are some vehicles that can run well on regular gas even if they are specd to run higher octane gas.
There is no problem at all mixing those gasoline's together. It will obviously be no problem. And like you stated if it is not to be run for awhile then make sure to fully fill up the tank.
Re: Is it ok to switch gas stations? [Re: bbhero] #4602200
12/12/17 11:26 PM
12/12/17 11:26 PM
PimTac Offline
PimTac  Offline
Is it true about those sulfur ions? My Mazda has been belching rotten egg smell since I filled with Shell. Maybe I should try Chevron?
Cannot see signatures any longer so it doesn’t matter.
Re: Is it ok to switch gas stations? [Re: Quattro Pete] #4602206
12/12/17 11:37 PM
12/12/17 11:37 PM
MTL, CANADA
Rolla07 Offline
Rolla07  Offline
MTL, CANADA
+1
Like waaaaat????
Go crazy put in regular...lol
2007 Corolla Red Pearl 155k miles
PP 0w20 & ST 4967
Re: Is it ok to switch gas stations? [Re: Rolla07] #4602209
12/12/17 11:49 PM
12/12/17 11:49 PM
Dallas,Tx USA
aquariuscsm Offline
aquariuscsm  Offline
Dallas,Tx USA
+1
Like waaaaat????
I say put in a collage of all three grades,kind've a gasoline casserole laugh
1996 Nissan 300ZX 5-speed,Arctic Pearl(#175 of 300)
Quaker State Ultimate Durability 10W30
2012 Honda Accord Coupe EX-L 2.4,auto,San Marino Red
Pennzoil Platinum HM 10W30
Re: Is it ok to switch gas stations? [Re: boostedtsiawd] #4602214
12/13/17 12:17 AM
12/13/17 12:17 AM
DFW
Timo325 Offline
Timo325  Offline
DFW
I think we are getting trolled..
2011 Odyssey Touring Elite 80k mi. M1 EP, 0W-20, FU
2008 Mustang GT 81k mi. Edge EP (Gold) 5W-20, FU
Page 1 of 3 1 2 3
