Bought a Model 3 for wifey
by JeffKeryk. 12/16/18 09:01 PM
Maybe I'm crazy.
by TRDPRO85. 12/16/18 07:50 PM
Pacer EON E-11 Synthetic Motor Fluid
by Brandon9797. 12/16/18 07:46 PM
Reuse transmission fluid??
by FFeng7. 12/16/18 07:35 PM
Amsoil SS color change
by BigShug681. 12/16/18 07:21 PM
Why don't owner's manuals specify the oil type
by OilUzer. 12/16/18 07:13 PM
belt tensioner problems
by mobilaltima. 12/16/18 06:57 PM
How bout them Patriots
by 53' Stude. 12/16/18 06:36 PM
Hand held Ham radio suggestions
by littleant. 12/16/18 05:20 PM
Ford 2.3 EB's using 87 vs 91/93 octane
by Whimsey. 12/16/18 04:48 PM
Oil analysis pump tube?
by maximum6. 12/16/18 03:56 PM
Mahle charcoal lined filter..the best!
by TiGeo. 12/16/18 03:45 PM
Diesel engines and emissions
by spasm3. 12/16/18 03:31 PM
Experiment time
by 53' Stude. 12/16/18 02:52 PM
2019 2.7L EB - Edge ST & Catch Can
by -SyN-. 12/16/18 02:51 PM
15 Grand Caravan
by zrxkawboy. 12/16/18 02:18 PM
Brandon9797, Landngroove, DanielH, Cpcz9382, PPWarrior
66699 Registered Users
99 registered members (69Torino, ABomb369, amblerman, 97K15004WD, AdditiveOCD, 12 invisible), 1,949 guests, and 47 spiders.
Topics295,166
Posts4,929,008
Members66,699
Most Online2,553
Oct 27th, 2018
10w30 T5 in chevy LS? #4601913
12/12/17 06:00 PM
12/12/17 06:00 PM
EasTn
Sealbilly Offline OP
EasTn
Is the new formula of rotella T5 dual rated oil? If not is it just a bunch of govermental [censored] or legitimately shouldn't be run in a gas engine.
Re: 10w30 T5 in chevy LS? [Re: Sealbilly] #4601922
12/12/17 06:10 PM
12/12/17 06:10 PM
America's Dairyland
LotI Offline
LotI  Offline
America's Dairyland
03 Honda Interceptor
11 Kawasaki KLR 650
12 Ford E450
17 VW GTI
[IMG]http://badges.fuelly.com/images/sig-us/803455.png[/IMG]
Re: 10w30 T5 in chevy LS? [Re: LotI] #4601932
12/12/17 06:35 PM
12/12/17 06:35 PM
EasTn
EasTn
Originally Posted By: LotI
Thanks both have a picture of a truck. Ps I didn't cuss it censored b. S.
Re: 10w30 T5 in chevy LS? [Re: Sealbilly] #4602308
12/13/17 06:35 AM
12/13/17 06:35 AM
Down Under
SR5 Offline
SR5  Offline
Down Under
I don't know about the T5 10W30, but the new CK-4 rated Shell Rotella T4 15W-40 still has 1200 ppm of zinc.
http://pqiadata.org/Shell_Rotella_T4_15W40_4192017.html
It's also Euro ACEA E9 which means reasonable SAPS levels. It is JASO MA/MA2 which is the Japanese standard for 4-stroke motorcycle oil, so it's fine for spark ignition gas / petrol engines.
Castrol GTX Ultraclean 15W40 A3/B3 + Wesfil-Cooper Z154
Re: 10w30 T5 in chevy LS? [Re: Sealbilly] #4602389
12/13/17 08:49 AM
12/13/17 08:49 AM
N.H, U.S.A.
ARCOgraphite Offline
N.H, U.S.A.
Whay ya want to run it? Got a BBl in the barn for the other farm machines?
Me I didn't like it twhen it first came out Maybe its better now.
Liked Triple protect T3 10w30 dino much better.
Is triple protect dino in the 10w30 off the market?
That was like THE universal smooth and gooey and tough oil. That would be sad if its gone or messed with.
2014 Nissan Rogue S CVT, OC#10 47272mi-QSUD10W30+5w20 Toughguard Filter; '17 Subaru Crosstrek CVT OC#2 ?? mi-SOA/Idemitsu 0w20 + SOA Filter
Re: 10w30 T5 in chevy LS? [Re: Sealbilly] #4603307
12/14/17 09:38 AM
12/14/17 09:38 AM
Houston, TX
ChrisGuerrero Offline
Houston, TX
Hi Sealbilly, our new Rotella T6 Multi-Vehicle product is our only duel-rated oil. We would not recommend any of our other products for gasoline engines.
Re: 10w30 T5 in chevy LS? [Re: ChrisGuerrero] #4603628
12/14/17 04:13 PM
12/14/17 04:13 PM
Down Under
SR5 Offline
SR5  Offline
Down Under
Thanks for your help Chris.
Two questions if I may:
- what would go wrong if you used the other Rotella products in a gas engine ?
- if a product is rated JASO MA/MA2 then isn't that for gas engines, as I have never seen a diesel motorcycle ?
Thank You in advance.
Re: 10w30 T5 in chevy LS? [Re: Sealbilly] #4604384
12/15/17 11:08 AM
12/15/17 11:08 AM
Chicago
Fraser434 Offline
Fraser434  Offline
Chicago
Don't go with the dual rated oil.
10W30 diesel oil CK4 fine, or 5W40 for LS engine.
Dual rated takes all the good additives out of the oil to appease the API.
The only reason why T5 and T6 arn't "dual rated" or don't carry an SN rating, the additive level zinc phos is higher than the allowable limit for SN. The formulation and additives have't changed only the specification changed for allowed limit in API SN. Hope this helps.
Re: 10w30 T5 in chevy LS? [Re: Sealbilly] #4605578
12/16/17 04:25 PM
12/16/17 04:25 PM
EasTn
EasTn
Thanks Fraser.
