New member of the (automotive) family!
by addyguy. 03/24/19 06:04 PM
6.2 f250 6.4 ram 2500 towing with a gasser
by FLORIDA. 03/24/19 05:55 PM
T5 15w40 for my bike?
by Degreaser. 03/24/19 05:47 PM
Studded tires in warm weather
by y_p_w. 03/24/19 05:28 PM
ST 15W40
by mobilaltima. 03/24/19 05:02 PM
I need a filter cutter person
by Marco620. 03/24/19 03:21 PM
VIRGIN BOSCH D+ 3421 CUT OPEN
by 53' Stude. 03/24/19 02:45 PM
My first cut. Donaldson P502503
by BeerCan. 03/24/19 02:25 PM
Sludge and Facebook's infinite wisdom
by RDY4WAR. 03/24/19 02:05 PM
Gear lube 75W90 Synthetic GM# 88900401
by rcbob. 03/24/19 01:47 PM
Rislone Rebates
by Nickdfresh. 03/24/19 01:42 PM
IndyCar Classic at COTA
by bdcardinal. 03/24/19 12:29 PM
STP 500 at Martinsville
by bdcardinal. 03/24/19 12:27 PM
Source For Microfiber Towels
by Wrenchturner44. 03/24/19 12:26 PM
SUPREME C3-X SYNTHETIC 5W-30
by 21Rouge. 03/24/19 12:17 PM
Jcountry, CMichael, dude59, Petrolhead, stp
67608 Registered Users
107 registered members (ArrestMeRedZ, addyguy, 2004tdigls, arowbat, 2002 Maxima SE, 10 invisible), 2,213 guests, and 62 spiders.
Topics286,351
Posts4,906,907
Members67,608
Most Online2,967
Mar 10th, 2019
Page 1 of 3 1 2 3
Run 0W-40 in a car requiring 5W-30? #4601828
12/12/17 05:29 PM
12/12/17 05:29 PM
Richmond VA, Washington DC
johnchui1984 Offline OP
Hello everyone,
I wonder what happens to the car if I use other viscosity oil? My Nissan Versa 2016 owner manuals recommend 5W-30 or 10W30; what if I use 0W-40, 5W-40 or 10W-40? Does it provide better protection?
I read a post about using Mobil 1 0W-40 in a similar car: https://bobistheoilguy.com/forums/ubbthr...ke_#Post4563199
I recently changed my oil and I used Castrol Magnatec 5W-30 Dexos 1 Gen 2 along with a Fram Ultra. I think it smooths the engine pretty well because it now rarely has random shaking when travelling at low speed. I am not sure if it is the efforts of Castrol or the GM dexos specs was doing the trick. But the difference is very noticeable compared to the major brands oil used in the past two years. I am thinking of going to the 40 weight oil to see if it completely iron out the issue?
Any thoughts about switching to a higher grade? Will there any negative effects on the engine or the catalytic converter, for example?
Thank you,
John
2016 Nissan Versa S-Plus CVT
Castrol Magnatec + Fram Ultra
Re: Run 0W-40 in a car requiring 5W-30? [Re: johnchui1984] #4601831
12/12/17 05:35 PM
12/12/17 05:35 PM
Ontario, Canada
mightymousetech Offline
Ontario, Canada
I use Castrol 0W40 in my Civic which calls for 5W30 without issue.
Mighty Mouse Tech
BMW Tech, Former Acura Tech
2010 Civic Si Castrol 0W40, Redline MTL
2013 BMW 135i M Sport Edition Castrol 0W40, Redline MTL
Re: Run 0W-40 in a car requiring 5W-30? [Re: mightymousetech] #4601837
12/12/17 05:40 PM
12/12/17 05:40 PM
Do you feel any difference between 30 and 40 weight oil? Thanks
Re: Run 0W-40 in a car requiring 5W-30? [Re: johnchui1984] #4601838
12/12/17 05:40 PM
12/12/17 05:40 PM
5600 feet elevation, Arizona
double vanos Offline
Castrol Edge 0w-40 in my Ecoboost pickup, no problems at all. In fact, highly recommended! grin
Sabine Schmitz is the Queen of the 'Ring; Svetlana Kapanina is the Queen of the SKIES...
Re: Run 0W-40 in a car requiring 5W-30? [Re: johnchui1984] #4601840
12/12/17 05:42 PM
12/12/17 05:42 PM
MN
oil_film_movies Offline
MN
No negative wear effects. It could hurt the catalytic convertor if you consume more than about a quart every 3,000 miles due to the often higher phosphorus content in 0w40 oils. Its not much more phosphorus, so if you don't use much oil between oil changes, then its not a problem really.
You do increase engine friction going to a thicker (hot) oil like 0w40 (HTHS~=3.5) vs. an SN GF-5 5w30 (HTHS~=3.0), which translates into about ~1.5% less peak power and lower MPG too.
For a newer car like yours, I'd just stick with the 5w30 full synthetic you are already using. I doubt if engine wear will be helped by going to a 0w40, but a 0w40 could help if you're towing or running the engine hard in hot weather for a prolonged time.
Re: Run 0W-40 in a car requiring 5W-30? [Re: double vanos] #4601841
12/12/17 05:42 PM
12/12/17 05:42 PM
Hello, is it the Ford EcoBoost? What oil does Ford recommend? Do you feel any difference when switching to 40 weight oil?
Re: Run 0W-40 in a car requiring 5W-30? [Re: johnchui1984] #4601842
12/12/17 05:44 PM
12/12/17 05:44 PM
Rabbit Creek, Alaska
jayg Offline
jayg  Offline
You won't and your Versa doesn't care.
Run the cheapest API SN 5w30 you can in it until you get sick of driving it.
2018 Ford Ecosport AWD- Napa 0w20
2017 Ram 1500 Ecodiesel- CP Triton ECT 5w40
1973 Datsun 240Z 10w30- VWC from '73
1973 Triumph Bonneville 750- M1 5w50
1967 BSA 441 Victor Special- M1 5w50
Re: Run 0W-40 in a car requiring 5W-30? [Re: oil_film_movies] #4601844
12/12/17 05:46 PM
12/12/17 05:46 PM
Hello Mr Movies! Thanks for your detailed explanation! The car has zero consumption of oil. Current MPG is around 37-43 so 1.5% less efficiency is acceptable to me. I just wanna see if it helps solve the problem of random dumb shaking when going below 25 mpg. It is a great reliable transportation car so I want to keep it for a long time laugh
Re: Run 0W-40 in a car requiring 5W-30? [Re: jayg] #4601848
12/12/17 05:49 PM
12/12/17 05:49 PM
LOL I also run Mobile Super and Chevron Supreme in the past. But seems like they need longer time to warm up the engine in winter so I usually get syn-blend or full syn if they are on sale> smile
Re: Run 0W-40 in a car requiring 5W-30? [Re: johnchui1984] #4601850
12/12/17 05:49 PM
12/12/17 05:49 PM
jayg Offline
jayg  Offline
This is not a symptom of oil viscosity. Take it to a tech familiar with Nissan CVT's and have them properly diagnose it. Spoiler alert: Changing oil weight isn't the problem.
Re: Run 0W-40 in a car requiring 5W-30? [Re: jayg] #4601858
12/12/17 05:57 PM
12/12/17 05:57 PM
MN
MN
Very true. The Nissan (Jatco brand) CVT is notorious for odd behavior. I rented an Altima last year that started running at 3,000 rpm while on flat ground doing 30 mph steady. It wouldn't change ratios. The Hertz rental place said they get a lot of complaints and failures of Nissan CVT's .
Re: Run 0W-40 in a car requiring 5W-30? [Re: johnchui1984] #4601859
12/12/17 05:58 PM
12/12/17 05:58 PM
MA USA
andrewp1998 Offline
andrewp1998  Offline
MA USA
Maybe Trav will chime in, he has exp with this?
2001 Honda civic HX vtecE- 5 spd,238K
Re: Run 0W-40 in a car requiring 5W-30? [Re: oil_film_movies] #4601870
12/12/17 06:09 PM
12/12/17 06:09 PM
I think the CVT works great in my car. To me sounds like the random shaking is from the engine position I believe? Just would like to see if changing oil weight helps. Provided that the 40 grade oil doesnt increase wear, I think I will give it a try next oil change laugh
Re: Run 0W-40 in a car requiring 5W-30? [Re: johnchui1984] #4601889
12/12/17 06:31 PM
12/12/17 06:31 PM
jayg Offline
jayg  Offline
So you have convinced yourself that will help though there is no logical reason why it would?
You have speed dependent shaking which sounds to me like a driveline issue. Changing from 30 to 40 wt and expecting that to help it is the same as putting a new air freshener in it and expecting that to do something.
Re: Run 0W-40 in a car requiring 5W-30? [Re: johnchui1984] #4601893
12/12/17 06:38 PM
12/12/17 06:38 PM
Down Under
SR5 Offline
SR5  Offline
Down Under
Going to a 40 grade oil from a 30 grade will not increase wear. You will be fine, cars are less fussy on oil weight than the average BITOG member.
Right now I'm running M1 5W30 (GF-5) my previous fill was SynPower 0W40 (A3/B4), they both work fine.
Castrol GTX Ultraclean 15W40 A3/B3 + Wesfil-Cooper Z154
Page 1 of 3 1 2 3
