125 years.
by Silk. 09/19/18 12:38 AM
How a VW DSG Transmission works
by StevieC. 09/18/18 10:42 PM
Full Synthetic vs HM Full Synthetic
by SierraMan. 09/18/18 10:06 PM
Champion AGM batteries
by bbhero. 09/18/18 08:53 PM
General opinion about Cooper CS5 Ultra?
by dan_erickson. 09/18/18 08:37 PM
Rotella Online Rebate
by PumpPusher. 09/18/18 08:13 PM
Audi A4 vs Volkswagen CC...or good old Passat?
by KCJeep. 09/18/18 07:19 PM
GM 454 engine
by dirtymudder. 09/18/18 07:13 PM
High Performance Motorcycle oil...which one?
by Neiz15. 09/18/18 06:50 PM
Need help High Performance Motorcycle oil?
by Neiz15. 09/18/18 06:38 PM
MC FL-500S CUT OPEN
by 53' Stude. 09/18/18 05:15 PM
FORD FACTORY FILTER CUT OPEN
by 53' Stude. 09/18/18 05:06 PM
2019 Harley Davidson FXDR 114
by DuckRyder. 09/18/18 04:59 PM
USS Forrestal question
by cjcride. 09/18/18 03:52 PM
Breaker Box
by Throt. 09/18/18 03:00 PM
Honda metal fuel tank seam leak
by wing0. 09/18/18 02:49 PM
Cracked single stage paint
by JHZR2. 09/18/18 01:45 PM
Options versus dealer oil changes
by Schmoe. 09/18/18 01:34 PM
Longevity of Mercon LV in a 2017 Ford Escape?
by mrdctaylor. 09/18/18 01:24 PM
vortex64, 19074, Redright9, Clif67, scotstr
66011 Registered Users
24 registered members (Atesz792, alcyon, cb4017, carloz, BlakeB, carlprop, 2 invisible), 861 guests, and 28 spiders.
Topics290,617
Posts4,847,564
Members66,011
Most Online3,590
Jan 24th, 2017
Need help with cold start noise - cause to worry? #4601644
12/12/17 02:14 PM
12/12/17 02:14 PM
Gatineau QC Canada
TheMidnightNarwh Offline OP
Gatineau QC Canada
Hey
So when it colder outside my car when I start it will do this knock/tick noise and go away after a few seconds. Here is a video showing off perfectly where you can clearly hear it. You also hear some kind of pulley or belt noise after, maybe it's related? But if I recall correctly the noise your hear after wasn't there before. Thanks! Car is a 2006 Hyundai Tucson with 180k KM (123K Miles). I checked the engine oil and it was replaced about a 2 month ago.
https://youtu.be/i68yMZhA1jc
Re: Need help with cold start noise - cause to worry? [Re: TheMidnightNarwh] #4601660
12/12/17 02:30 PM
12/12/17 02:30 PM
N.H, U.S.A.
ARCOgraphite Offline
N.H, U.S.A.
All the cars ive had lately sound like they are going to fall apart when cold started. Wifes Subaru, My rogue whatever. Funny the Subaru was pretty quiet with factory fill and factory filter, Not so with Idemitsu and the Framaroo Blue OE service filter. It quiets when warm. The Idemitsu seems t hold up well hot.
2014 Nissan Rogue S CVT, OC#9 41392mi-QSUD10W30 + M110A CHAMP Filter; 2017 Subaru Crosstrek CVT OC#2 ?? mi-SOA/Idemitsu 0w20 + SOA Filter
Re: Need help with cold start noise - cause to worry? [Re: TheMidnightNarwh] #4601661
12/12/17 02:30 PM
12/12/17 02:30 PM
Illinois
SHOZ Offline
SHOZ  Offline
Illinois
What filter and oil brand/grade are you using.
2008 Hyundai Accent 1.6L 5 sp manual hatchback
2010 Hyundai Genesis Coupe Track 2L Turbo 6sp manual
Re: Need help with cold start noise - cause to worry? [Re: TheMidnightNarwh] #4601670
12/12/17 02:35 PM
12/12/17 02:35 PM
canada
hemitom Offline
hemitom  Offline
canada
its stops within seconds !!
i don't think its anything to worry about, as asked before what weight of oil and filter are you using.
2006 kia spectra.
2010 pontiac vibe.
2012 mustang coupe.
Re: Need help with cold start noise - cause to worry? [Re: TheMidnightNarwh] #4601675
12/12/17 02:39 PM
12/12/17 02:39 PM
USA
oldhp Offline
oldhp  Offline
USA
My 2010 Ford Ranger 2.3 had a very loud tick for 45'ish seconds, sounded like forever, with Motorcraft FL-910S oil filter and Castrol Magnatec 5W20. I changed to a FRAM 3600 with same oil. Zero start up tick. From reading on here most of start up noises are 99.9% oil filter related.
Re: Need help with cold start noise - cause to worry? [Re: TheMidnightNarwh] #4601693
12/12/17 02:52 PM
12/12/17 02:52 PM
Chicago Suburbs
Nitronoise Offline
Nitronoise  Offline
Chicago Suburbs
My 04 sonata has had a tick like that for 200000 miles with the filter on the bottom of the motor just above the oil pan mounted horizontally your going to have some oil draing back i have run it with bosch or wix filters and qsgb or citgo supergard 5w30 since new
07 Ford Freestyle 135K
04 Hyundai Sonata 280K
03 Hyundai Santa Fe 165K
02 Ford Tarus 98K
00 Buick Regal SC 135K
95 Goldwing 28K
Re: Need help with cold start noise - cause to worry? [Re: SHOZ] #4601711
12/12/17 03:04 PM
12/12/17 03:04 PM
Gatineau QC Canada
Gatineau QC Canada
Oil is 5w-20. Filter and oil brand don't know, Midas did the oil change, car was just given to me after that.
Re: Need help with cold start noise - cause to worry? [Re: ARCOgraphite] #4601715
12/12/17 03:05 PM
12/12/17 03:05 PM
Gatineau QC Canada
Gatineau QC Canada
I was told there may be a bulletin about non OEM filter doing this. You guys think it's this? I preferably won't be rehanging my oil and filter until next year so.
It shouldn't do any damage or anything?
Re: Need help with cold start noise - cause to worry? [Re: TheMidnightNarwh] #4601724
12/12/17 03:14 PM
12/12/17 03:14 PM
Illinois
SHOZ Offline
SHOZ  Offline
Illinois
I doubt if Midas uses a high quality filter.
Re: Need help with cold start noise - cause to worry? [Re: TheMidnightNarwh] #4601732
12/12/17 03:20 PM
12/12/17 03:20 PM
New England
Virtus_Probi Offline
New England
My daughter reported having a hard time cold starting her car after my wife took it to Midas (against my will) for an oil change...I checked that the oil level was OK and then noticed that the oil filter was a very small brand X. I took it off (top mount is nice) and found that it didn't have an ADBV, then put on a spare filter I had around that was a Mazda branded Tokyo Roki that is apparently identical to Subaru's factory filter on the cars built in Japan.
Nary a starting complaint since...I certainly don't have proof, but I suspect the cheap filter was the issue.
2014 Forester XT, 86000 miles
Last Change;
M1 5W30 d1G2
Tokyo Roki 15208AA170 filter
Re: Need help with cold start noise - cause to worry? [Re: Virtus_Probi] #4601741
12/12/17 03:26 PM
12/12/17 03:26 PM
Gatineau QC Canada
Gatineau QC Canada
[censored] uh, I figured it wouldn't be optimal to go someplace like that. I'll keep it this way for now, might do an oil change after winter and change that filter, it's under the car horizontally... anyhow I might buy myself a car when summer comes so I'll see.
Re: Need help with cold start noise - cause to worry? [Re: TheMidnightNarwh] #4601770
12/12/17 04:12 PM
12/12/17 04:12 PM
West Ma.
rollinpete Offline
rollinpete  Offline
West Ma.
Mounted horizontally, probably oil draining out of filter...JMHO but i'd change out the filter ,knowing that filter might be defective or no anti drain valve...
Pete.
97 Ford Expl.Sport 4.0 ohv 4wd 5spddrive184k miles
Last Change;
Penn. Plat. HM. 5w30
Fram xg8a, Fram CA8141
I like my oil (slippery).
Re: Need help with cold start noise - cause to worry? [Re: TheMidnightNarwh] #4601790
12/12/17 04:43 PM
12/12/17 04:43 PM
NE Ohio
knerml Offline
knerml  Offline
NE Ohio
The next time you change the oil use a Hyundai/Kia 26300-35503 or 26300-35504, or a Mann W811/80 (Mann's after market version of the 26300-35504) filter.
2015 Hyundai Elantra Sport 2.0 GDI Mobil 1 5W20 & OEM/Mann W811/80 Filter
2018 Hyundai Santa Fe Sport 2.0T Castrol Edge 5W40 & OEM/Mann W811/80 Filter
Re: Need help with cold start noise - cause to worry? [Re: TheMidnightNarwh] #4601866
12/12/17 06:04 PM
12/12/17 06:04 PM
MA USA
andrewp1998 Offline
andrewp1998  Offline
MA USA
Mine did it last winter and spring, then went away now its back to once in a while since October. It lasts a few secs to about 1 or 2 mins when it does happen which is once in a while. I went from napa silver, to gold to a baldwin but nothing changed. I run 30 or 20w full syn oil.
2001 Honda civic HX vtecE- 5 spd,232k+
Re: Need help with cold start noise - cause to worry? [Re: TheMidnightNarwh] #4601964
12/12/17 07:55 PM
12/12/17 07:55 PM
Gatineau QC Canada
Gatineau QC Canada
But I'm curious, what makes the noise? What is the technical explanation? Is it because it's missing oil or..?
