Need Mice Advice
by Mr_Luke - 05/25/20 07:01 PM
pressure washer air compressor oil
by bedwards - 05/25/20 06:49 PM
2014 Elantra delayed shift 4th to 5th
by Propflux01 - 05/25/20 05:51 PM
2002 Ranger Electrical Weirdness (GEM, RAP?)
by DuckRyder - 05/25/20 05:47 PM
Oil change problems
by philipp10 - 05/25/20 05:41 PM
Denso 150 3024
by thrace - 05/25/20 04:58 PM
does ac delco warranty the replacement battery?
by apollo18 - 05/25/20 04:39 PM
Water drainage issue
by Paul_Siu - 05/25/20 04:39 PM
13 Corolla PCV
by AJB0009 - 05/25/20 04:24 PM
SpaceX Launch - Wednesday
by MasterSolenoid - 05/25/20 04:15 PM
Atf for my E4od
by R1jake - 05/25/20 04:04 PM
Having trouble finding the right part (VW)...
by gregk24 - 05/25/20 04:03 PM
Need a sensible but fun daily
by dparm - 05/25/20 03:52 PM
FJ cruiser knock sensors
by Chris142 - 05/25/20 03:51 PM
Rock Auto now carries Maval steering racks and pumps
by slacktide_bitog - 05/25/20 03:10 PM
Review: Cardone Reman Power Steering Pump
by RevelationLion - 05/25/20 02:09 PM
Carvana
by Bogdon - 05/25/20 02:06 PM
Mitsubishi SP-III universal fluid
by MontePrix28 - 05/25/20 12:22 PM
Typerguy, showtyme1958, rickyradit, YogiTheCat, StevePLR
71527 Registered Users
112 registered members (AJB0009, 71Chevyguy, 2004tdigls, 2015_PSD, alchargo, 2K2AcuraTL, 9 invisible), 2,438 guests, and 19 spiders.
Topics305,868
Posts5,281,753
Members71,527
Valvoline High Mileage Full Synthetic 0W20 Oil #4601335 12/12/17 09:37 AM
M
mphilleo Offline OP
M
This horse has been whipped to death but, since it's that time of year again, it's time for the poor guy to make his appearance again.
I was shopping for some oil at my local Walmart and found Valvoline High Mileage Full Synthetic 0W20 is now an option. My 2008 Commander is equipped with the 4.7 V8, which calls for 5W20. Since it's got upwards of 154,000 I figured I might transition to high mileage oil. Here in North Dakota, it's not unusual to spend several weeks per winter at 0F down to -30F. Since I know just enough about oil to be dangerous and have looked for a definitive opinion (which I haven't found) whether I can substitute this oil for the 5W20 called for, I thought I'd bug you guys. I know that it should improve cold temperature flow upon start up, but the same weight at operating temp. I imagine the base oils for this and the 5W20 are of similar quality, so only real drawback I can think of is whether the 0W20 might lead to a small amount of consumption. Since I haven't had this truck long enough to know if it has an issue with consumption or not, I thought I'd give it the benefit of the doubt. Is there any reason I'm overlooking why this 0W20 oil shouldn't be in my truck during winter or year round?
Re: Valvoline High Mileage Full Synthetic 0W20 Oil [Re: mphilleo] #4601338 12/12/17 09:40 AM
JohnnyJohnson Offline
Your truck will tell you. If it isn't currently burning oil and it burns 0w-20 you know the answer. No one else here can honestly answer your question. But we may have some that will venture an uneducated guess!
2004 Corolla 140080
Out: Havoline Pro DS 10w-30 Purolator PureOne 10-29-19 136457
In: Pennzoil Platinum HM 5W-20 ST 4386
2006 Duramax 77077
Out: T6 5W-40 XG9100 73909
In: Rotella Dino PH9100 11-3-19
Re: Valvoline High Mileage Full Synthetic 0W20 Oil [Re: mphilleo] #4601341 12/12/17 09:43 AM
A
ARCOgraphite Offline
A
What is your understanding of the 4.7 health at this stage? Noise, consumption, leak, cylinder balance etc.
I will say the Valvoline regular 0w20 was the best option used in the Subaru FB after trying most of the store brands; close behind was QSUD.
2019 VW Jetta S 6MT OCI#2 7378mi-MOTUL Specific VW508.00+VW Service Filter; '17 Subaru Crosstrek CVT OC#9 70254mi-Rotella
Gas Truck 5W20 + Fram Ultra 7317 Filter
Re: Valvoline High Mileage Full Synthetic 0W20 Oil [Re: mphilleo] #4601342 12/12/17 09:43 AM
T
tig1 Offline
T
If you don't have a reason to use a HM oil then I wouldn't. My Fusion has 217K and I have never used HM oil. Have no reason to. Yet.
2007 Ford Fusion 258,000 miles
M1 5-20HM
2017 Ford Fusion 89K
M1 0-20EP
M1 ATF and M1 LV HP ATF
M1 10-30 in all OPE
MC filters
Re: Valvoline High Mileage Full Synthetic 0W20 Oil [Re: tig1] #4601354 12/12/17 09:52 AM
M
mphilleo Offline OP
M
Based on the rest of the truck, I'm under the impression it was well-maintained for the most part. I have no complaints, it runs well, has good power but I haven't had it long enough to confirm or deny any possible consumption. The only real noise I hear on cold start is maybe a little valve noise, but nothing extraordinary for something of that mileage (IMO). I'm a classic "over maintainer" and the truth of the matter is, this truck is no spring chicken anymore. High mileage oil may not be necessary but I don't see how it would necessarily do harm either.
I think I might have answered this a little bit in my reply above. smile
Re: Valvoline High Mileage Full Synthetic 0W20 Oil [Re: tig1] #4601356 12/12/17 09:53 AM
J
Jeffs2006EvoIX Offline
J
I agree on not using a "High Mileage" oil unless you need to. What does that mean? If you need to? Well I will give you an example on one of my cars.
2000 Dodge Grand Caravan 3.3 V6 155k miles. I was getting oil seepage out of the valve cover gaskets, among other small seepage in other areas. Nothing major, but the cost to get all the gaskets replaced would have been allot.
I tried out the M1 HM 5w30 figuring had nothing to lose. After the 2nd Oil Change with the M1 HM 5w30 the seepage has stopped. I now change the oil every 5k miles with this oil and have no issues.
If your car has no seepage issues, or no other minor issues that are oil related I would not use a HM oil.
Keep in mind too in your climate, HM oils tend to have a higher HTHS rating which may affect the pour point. Not a big deal where I live in California, but if its -30F out? It might.
Just a thought.
If it aint broke. Dont fix it.
Jeff
"You don't have to be crazy to do this... But it helps." Bob Ross.
Re: Valvoline High Mileage Full Synthetic 0W20 Oil [Re: Jeffs2006EvoIX] #4601369 12/12/17 10:03 AM
M
mphilleo Offline OP
M
Just a thought.
Jeff
Thanks for the thoughtful reply, Jeff. The only real seepage issue I have on my 4.7 is I think the front crank seal is starting to let go, but that's something big enough it probably won't be fixed with a HMO.
This is all interesting to me. For the longest time, I used PP High Mileage Full Syn on other older cars I've had in times past. Never kept them long enough to know it was good or not. Anyway, this brings me to a different question. If there's not necessarily a need for HMO in this truck, should I stick with OEM specced 5W20 or go with 0W20? I'm leaning toward the 0W because of our climate. If I pass on the whole HMO thing, what is the best full synthetic oil I can dump in the crank case that isn't Pennzoil Ultra?
Re: Valvoline High Mileage Full Synthetic 0W20 Oil [Re: mphilleo] #4601381 12/12/17 10:08 AM
J
J
This is where things are going to get sketchy. When anyone asks for the "Best" of anything punches get thrown around BITOG. Debates for days.
I would go with what the manufacturer recommends and if that is a 5w20 and its worked for you this long?
Any of the "Big" names will be fine. A good place to start is Mobil 1. Really is tough to beat and can be bought pretty much anywhere. Wallyworld has great deals on it too in the 5qt jugs.
Dont make it complicated. For me? I like the Castrol products. I use 5w20 Edge Gold Bottles in my Hyundai's. Much quieter engines to the point the woman even noticed hide
Jeff
Re: Valvoline High Mileage Full Synthetic 0W20 Oil [Re: mphilleo] #4601451 12/12/17 10:56 AM
B
Boss302fan Offline
B
Valvoline Full synthetic with Maxlife tech is a good oil and I have used it in different weights in many vehicles. Very happy with it so far in all the vehicles I have used it in.
John P
Wisconsin
2018 Subaru Outback 3.6R Limited
2006 GS 430
2006 Lexus LS 430
1990 Jaguar XJS V12
2011 Hyundai Santa Fe V6
Other fun cars
Re: Valvoline High Mileage Full Synthetic 0W20 Oil [Re: mphilleo] #4601469 12/12/17 11:08 AM
PimTac Offline
Valvoline is a excellent oil and they state that the Maxlife version can be used in newer vehicles with no problems.
I just picked up a jug of the Valvoline Advanced Synthetic for the 1000 mile change out.
2017 Mazda CX5
Mobil 1 Annual Protection 0w20
Roki OEM filter.
Re: Valvoline High Mileage Full Synthetic 0W20 Oil [Re: Boss302fan] #4601480 12/12/17 11:17 AM
M
mphilleo Offline OP
M
That's the impression I was under, too. IMO, I think the seal-sweller thing is a bit overblown. If it was detrimental to seals, the manufacturers would not suggest using it in vehicles of any mileage. I think the phrase is that its properties are beneficial to high mileage vehicles, but can be used in any vehicle. I just noticed Castrol Edge HM and the VOAs on that look really good. I'm going to have to compare that with Valvoline Maxlife and see which route to go, possibly.
Re: Valvoline High Mileage Full Synthetic 0W20 Oil [Re: mphilleo] #4601484 12/12/17 11:22 AM
PimTac Offline
Just my thinking but the engines of today have different seal and gasket materials. Most are just squirted out by robots. It is different from the older methods that these oils worked on. I would imagine the oil companies adapted their formulations along the way.
2017 Mazda CX5
Roki OEM filter.
Re: Valvoline High Mileage Full Synthetic 0W20 Oil [Re: mphilleo] #4601548 12/12/17 12:34 PM
L
loneryder Offline
L
My Ford 150 has 155k and was weeping oil from front and rear seals. It stopped when I used Mobil 1 HM oil and hasn't leaked since. Why not try it and 0-20 for winter. Next spring you may not have any leaks.
Re: Valvoline High Mileage Full Synthetic 0W20 Oil [Re: tig1] #4601646 12/12/17 02:15 PM
B
bigt61 Offline
B
+1 Only reason I'd ever use HM oil is to stop oil leaks-usage.
92 Suburban 2500 7.4L 58k M1_0w40 5yr OCI
99 Olds Aurora 4.0L 91K M1_5w30 5yr OCI
13 Dodge Dart 2.0L 30k PP 0w20 OLM OCI
70 Camaro 5.7L 59k
Re: Valvoline High Mileage Full Synthetic 0W20 Oil [Re: mphilleo] #4601707 12/12/17 03:02 PM
M
mphilleo Offline OP
M
This is all interesting food for thought. I've done a lot of checking and M1 AFE 0W20 looks like a really good non-HM oil. It has really low cold viscosity, pretty good TBN, NOACK and some good anti-wear additives. I'm starting to lean this way. I think my perception of it was painted negatively when I used it in a new 2013 Subaru Outback that drank the stuff like no tomorrow (which really was a flaw on the engine's part).
