ACDelco Dexos 0W20 UOA
by DanMiller
06/24/18 10:44 AM
Mopar window regulator (some assy. rqd.)
by dlundblad
06/24/18 10:27 AM
5.3L Silverado Water Pump Torque Specs
by Gito
06/24/18 10:25 AM
Rhino Ramps at Canadian Tire 50% off
by Snagglefoot
06/24/18 10:18 AM
What to do when your Glock jams
by bigj_16
06/24/18 10:13 AM
Pennzoil Platinum 5w30 vs 10w30
by Snagglefoot
06/24/18 09:09 AM
LM MoS2. Honest, if not appropriately tested?
by wemay
06/24/18 09:03 AM
Brisket flat on charcoal
by 04SE
06/24/18 08:45 AM
Weird Oil level question
by audia6
06/24/18 08:27 AM
DNA test and opening a can of worms
by WhyMe
06/24/18 08:11 AM
Ghetto testing a wheel speed sensor
by Nayov
06/24/18 06:23 AM
dash cam
by DAC2018
06/24/18 05:08 AM
WoO driver Jason Johnson injured
by bdcardinal
06/24/18 01:08 AM
Plastic burning smell when WOT
by Jaha24k
06/24/18 12:57 AM
Duckham's 15w50 Oil 12 one liter bottles
by Lolvoguy
06/24/18 12:00 AM
Ruger LCP .380
by PW01
06/23/18 11:24 PM
Launching boat with stick shift
by troutfisher
06/23/18 11:22 PM
Free oil
by Spitter
06/23/18 10:53 PM
Porsche Panamera buying advice
by CharlieBauer
06/23/18 10:04 PM
RC cars
by red7404
06/23/18 09:36 PM
bwechols, bowupid, pod423, lemaitrix, azzid0906
65303 Registered Users
67 registered (93cruiser, AdmdeVilleneuve, andyd, 4WD, ammolab, 10 invisible), 1486 Guests and 63 Spiders online.
65303 Members
67 Forums
285902 Topics
Page 1 of 2 1 2 >
#4601225 - 12/12/17 04:55 AM P0128 - 2005 Accord LX 2.4l
Will32283 Offline
Loc: NC
This past Thursday, my CEL came on and took it to Advance immediately for a code test. P0128 is what they gave me. I got this car with 266xxx miles on it in November 2015. I have put 15k (281,142) miles on it as of now. Ever since I have had it, it takes the car approximately five minutes to warm up. My car is not over heating at all but the temperature gauge needle usually takes 2 minutes to move. I know the P0128 code could be between the sensor, thermostat, or alerting coolant level. It is not extremely low but towards the minimum level. Is it best to go ahead and replace the thermostat? Much appreciated!
#4601242 - 12/12/17 05:55 AM Re: P0128 - 2005 Accord LX 2.4l [Re: Will32283]
Brybo86 Offline
Loc: Chicago, IL
I would add a little coolant first and see what happens
08 Honda Accord EX-L 2.4L M1 EP 0w20 145k
01 Kymco People 50
95 Lexus LS400 M1 AFE 0w30 193k
95 Yamaha Jog
#4601246 - 12/12/17 06:06 AM Re: P0128 - 2005 Accord LX 2.4l [Re: Brybo86]
Will32283 Offline
Loc: NC
I know the OM calls for Honda Blue Type 2. Looking in my tank the coolant looks green. Is it safe to add the Honda Type 2 with the green that's already there or do I need to drain?
#4601250 - 12/12/17 06:23 AM Re: P0128 - 2005 Accord LX 2.4l [Re: Will32283]
HoosierJeeper Offline
Loc: WI
I'd do a coolant flush and new tstat. Get OEM for both.
Edited by HoosierJeeper (12/12/17 06:23 AM)
15 Jeep KL Limited V6: Formula Shell 5W20
07 LR3 SE V8: Maxlife 5W30
05 Jeep KJ Limited: PHM 5W30
96 Jeep XJ Country: STP HM 5W30 (winter)
#4601260 - 12/12/17 06:52 AM Re: P0128 - 2005 Accord LX 2.4l [Re: Will32283]
Jim_Truett Offline
Loc: San Diego, California
If it has green coolant in it, there is also a fair chance it has an aftermarket thermostat as well. I would replace it with an OEM unit and proper blue coolant after a flush. The ECT sensor can be removed and tested with a DMM and a pan of boiling water.
2008 F250 6.4 PowerStroke 43k
2005 Honda CR-V 193k
2005 Honda Pilot 235k
1963 Nova SS 84k
2015 Civic Si 23k
2013 Mahindra 3016HST 99hrs
#4601284 - 12/12/17 07:38 AM Re: P0128 - 2005 Accord LX 2.4l [Re: Will32283]
mightymousetech Offline
Loc: Ontario, Canada
FYI, Honda Type 2 used to be green.
Replace the thermostat, it is probably sticking, and only use OE. If there is any coolant in the overflow bottle, the level is fine.
Edited by mightymousetech (12/12/17 07:39 AM)
Mighty Mouse Tech
Acura Tech
2010 Civic Si Castrol 0W40, Redline MTL
2013 BMW 135i M Sport Edition Castrol 0W40, Redline MTL
#4601288 - 12/12/17 07:45 AM Re: P0128 - 2005 Accord LX 2.4l [Re: mightymousetech]
propuckstopper Offline
Loc: MB, Canada
Certainly not arguing here, but when was Type 2 ever green? I have had my Honda since 2005, and never remember seeing anything but blue Honda coolant. In fact, I had not ever seen blue coolant before the acquisition of my Honda, so I found it a bit strange way back then.
1965 Pontiac GTO Tri-Power 4-Speed Hardtop (Montero Red)
1968 Pontiac GTO Covertible 400 H.O./Auto (Solar Red)
2000 Lexus ES300
2003 Honda Element AWD
#4601291 - 12/12/17 07:53 AM Re: P0128 - 2005 Accord LX 2.4l [Re: mightymousetech]
WobblyElvis Offline
Loc: Toronto Canada
I agree.
#4601357 - 12/12/17 08:53 AM Re: P0128 - 2005 Accord LX 2.4l [Re: propuckstopper]
Smoky14 Offline
Loc: Nowhere NM
It changed to blue in 2000 , approximately.
Smoky
99 Acura 2.3CL 5speed MT
12 Ford Fusion 2.5S 6speed MT
05 Suzuki Bandit 1200.
#4601415 - 12/12/17 09:24 AM Re: P0128 - 2005 Accord LX 2.4l [Re: Smoky14]
Loc: MB, Canada
Smoky
That would make sense, then, as I only began with the Honda in 2005.
2000 Lexus ES300
#4601430 - 12/12/17 09:36 AM Re: P0128 - 2005 Accord LX 2.4l [Re: Will32283]
Vikas Offline
Loc: NorthEast
put an el cheapo scanner and get the engine coolant temperature. If it is not in 180F or higher, then obviously you need new thermostat.
#4601528 - 12/12/17 11:11 AM Re: P0128 - 2005 Accord LX 2.4l [Re: Will32283]
The Critic Online   crying
Loc: CA
Most likely needs a T-stat at that mileage. Get one from the dealer as well as the coolant. The thermostat is part of the plastic water outlet assembly; when you buy a new thermostat from the dealer, it comes preinstalled into the water outlet. They are around $50.
2011 Toyota Prius - 168k - ServicePro Dexos 0W-20
2007 Honda Accord 2.4 - 128K - Idemitsu 5W-20
#4601727 - 12/12/17 02:15 PM Re: P0128 - 2005 Accord LX 2.4l [Re: Will32283]
Will32283 Offline
Loc: NC
Thanks all. I ordered the OEM T-stat and coolant.
#4601740 - 12/12/17 02:26 PM Re: P0128 - 2005 Accord LX 2.4l [Re: Will32283]
JMJNet Offline
Loc: TX, USA
Bad T-stat. Happened in my previous Sienna.
Buy a Honda genuine T-stat and NOT the Stant or anything else.
  • 2017 Toyota Sienna
#4601742 - 12/12/17 02:26 PM Re: P0128 - 2005 Accord LX 2.4l [Re: Will32283]
SatinSilver Offline
Loc: OH
Good Man! thumbsup
Page 1 of 2 1 2 >
