Good job Hyundai!!!
by Andy636. 01/17/19 02:43 PM
PP 0W-20 vs PP HM 0W-20 - Difference in VI
by The Critic. 01/17/19 02:34 PM
In praise of kludges...
by wings&wheels. 01/17/19 02:11 PM
Has Mobil 1 0w40 been discontinued?
by Doublehaul. 01/17/19 01:17 PM
Some questions for the home theater gurus
by grampi. 01/17/19 12:55 PM
Weird side problems after doing repairs
by mclasser. 01/17/19 12:31 PM
Shell Rotella Gasoline Truck.
by JHogan. 01/17/19 12:14 PM
Sears to stay open, for now
by addyguy. 01/17/19 11:35 AM
What Have I Gotten Myself Into?
by Gebo. 01/17/19 11:17 AM
Car stereo FM/ AM Reception Problems
by LazyDog. 01/17/19 11:13 AM
PPHM uoa requests
by aquariuscsm. 01/17/19 11:00 AM
Odd issue in Tacoma 3.5L V6 (2GR-FKS)
by 2019StingrayZ51. 01/17/19 10:58 AM
Alternative to Gillette Fusion razor
by gman2304. 01/17/19 10:55 AM
CAFE standards
by otis24. 01/17/19 10:01 AM
5w30 vs 5w40 Mercedes E220 BLUETEC
by Costas00. 01/17/19 09:56 AM
Moving mobility scooters
by supton. 01/17/19 08:59 AM
Car stumbling in idle
by dan765. 01/17/19 08:58 AM
Fiat 9.55535-GS1 Certification - Ravenol
by RamFan. 01/17/19 08:35 AM
Bigyetti83, Drava, supertrucker, neiltt, Drspel
66960 Registered Users
112 registered members (Andy636, anndel, addyguy, aquariuscsm, 28oz, AandPDan, 11 invisible), 2,191 guests, and 54 spiders.
Topics296,731
Posts4,957,830
Members66,960
Most Online2,577
Jan 14th, 2019
Torque Wrech #4600901
12/11/17 05:28 PM
12/11/17 05:28 PM
Texas
2009Edge Offline OP
2009Edge  Offline OP
Texas
I have a Snap On 150 ft/lb capable torque wrench, but my owners manual specifies 162 ft/lb for my lug nuts. Is there a cheap torque multiplier that can do this?
Re: Torque Wrech [Re: 2009Edge] #4600906
12/11/17 05:41 PM
12/11/17 05:41 PM
NE,Ohio
Rand Offline
Rand  Offline
NE,Ohio
I'd pass on a torque muliplier that is just a pita and expensive.
Just get a decent inexpensive 25-250 torque wrench.
https://www.amazon.com/TEKTON-24340-2-Inch-ft-lb-33-9-338-9/dp/B00C5ZL1NS
Re: Torque Wrech [Re: 2009Edge] #4600945
12/11/17 06:23 PM
12/11/17 06:23 PM
Roswell GA
eagle23 Offline
eagle23  Offline
Roswell GA
Are you sure about the 162 ft./lb.? That sounds really, really high for lug nuts. I would guess 80-100 ft./lb. would be plenty. I'd almost be concerned about snapping the wheel studs. A quick glance online shows 100 ft./lb.
On top of that, good luck with changing a tire on the side of the road on a dark and stormy night with wheel lugs torqued to those values.
Just my 2 cents.
Re: Torque Wrech [Re: 2009Edge] #4600955
12/11/17 06:39 PM
12/11/17 06:39 PM
NE,Ohio
Rand Offline
Rand  Offline
NE,Ohio
what vehicle is this for anyway?
Re: Torque Wrech [Re: 2009Edge] #4600963
12/11/17 06:54 PM
12/11/17 06:54 PM
South Florida
bubbatime Offline
bubbatime  Offline
South Florida
My GMC Sierra 1500 calls for 140 ft pounds on the 6 lugs... So 162 doesn't sound all that high???
17 Chrysler Pacifica Edge Syn 5W30
13 Yamaha XT250 Valv MC 10W40
10 Acura TSX 2.4 SuperTech Syn 5W20
06 GMC Sierra SuperTech 10W30
Re: Torque Wrech [Re: bubbatime] #4600975
12/11/17 07:05 PM
12/11/17 07:05 PM
VW Fanboy Island
maxdustington Offline
VW Fanboy Island
From what I understand the process for specs over the capacity of a normal torque wrench is 150 or whatever it is + rotation in degrees.
For my Jetta it was max torque + 15 degrees IIRC
EDIT: That was axle nut torque for my compact car, I thought lugs nuts were around 100 ft lbs on cars and light trucks?
03 Jetta AWP/09A 205k kms
Edge 0W40 + Mann 719/30
Re: Torque Wrech [Re: 2009Edge] #4600978
12/11/17 07:08 PM
12/11/17 07:08 PM
Clovis, CA
Merkava_4 Offline
Merkava_4  Offline
Clovis, CA
The most important thing with lug nuts is that they're all even; torque reading accuracy in not critical.
But on gaskets that involve inch pounds, put your money into that wrench!
Re: Torque Wrech [Re: 2009Edge] #4600980
12/11/17 07:10 PM
12/11/17 07:10 PM
KansasCity
twoheeldrive Offline
KansasCity
I would torque to 150# and call it good. I would probably re-torque them in a few hundred miles (also at 150#) just to be safe... usually good practice for alloy wheels anyway. It would not be unusual for a cheap torque wrench to be off by +/-10%.
... using Mobil 1 since 1976.
Re: Torque Wrech [Re: 2009Edge] #4600991
12/11/17 07:19 PM
12/11/17 07:19 PM
NE,Ohio
Rand Offline
Rand  Offline
NE,Ohio
Ah this is a 2017 edge,
162 lb.ft (220 Nm)
wowsers.. the old ones were all 100lb-ft so that is sort of odd.
Re: Torque Wrech [Re: 2009Edge] #4600996
12/11/17 07:23 PM
12/11/17 07:23 PM
Bolivia
widman Offline
widman  Offline
Bolivia
It says 150 here:
wheel torque specs
Re: Torque Wrech [Re: 2009Edge] #4600997
12/11/17 07:26 PM
12/11/17 07:26 PM
Chicago, IL
EdwardC Offline
EdwardC  Offline
Chicago, IL
I'd probably just buy an inexpensive unit that goes up to 250 ft-lbs. Or, if you want to spend more, I just bought a split beam clicker that goes up to 250 ft-lbs on eBay, really excited for it.
https://www.ebay.com/itm/Snap-On-1-2-Drive-Flex-Head-TQ-Series-Torque-Wrench-40-250-ft-lb-TQFR250C/192377549391?hash=item2cca98724f:g:9DsAAOSwPIhaG8xo
https://www.ebay.com/itm/Precision-Instruments-1-2-40-250-ft-lbs-SplitBeam-Torque-Wrench-C3FR250F-w-Case/272970012891?epid=2255325218&hash=item3f8e47d8db:g:eoMAAOSw9hdaJtAG
Re: Torque Wrech [Re: Rand] #4601025
12/11/17 08:11 PM
12/11/17 08:11 PM
Missouri
gabriel9766 Offline
gabriel9766  Offline
Missouri
162 lb.ft (220 Nm)
u kidding me? No way im gonna torque the wheels to 162. Trucks get 140 and cars/suvs get 100. I impact all my wheels on at work with my Milwaukee 1/2 batt impact then go around the cars witha torque wrench to either 100 or 140 foot lbs.
2015 Malibu LT 2.5L PPPP 0w20 46.1K
2007 Escape XLT 3.0L 5Q STHM 5w30/1Q MC full syn 5W20 115K
2010 Fusion SE 2.5L MC 0w20 110K
2008 Escape XLT 2.3L MC 5w30 187K
2007 Fusion SE 2.3L- 173.5K STHM 0W20
Re: Torque Wrech [Re: Rand] #4601030
12/11/17 08:14 PM
12/11/17 08:14 PM
Texas
2009Edge Offline OP
2009Edge  Offline OP
Texas
2017 Ford Edge
Re: Torque Wrech [Re: gabriel9766] #4601049
12/11/17 08:30 PM
12/11/17 08:30 PM
Waco, TX
Linctex Online content
Linctex  Online Content
Waco, TX
Originally Posted By: gabriel9766
Are you kidding me? No way I'm gonna torque the wheels to 162. Trucks get 140 and cars/suvs get 100. I impact all my wheels on at work with my Milwaukee 1/2 batt impact then go around the cars witha torque wrench to either 100 or 140 foot lbs.
I concur with this - 162 is dangerous in my opinion, because the threaded portion of the stud will be pre-stressed abnormally high.
The result = hit a bad pothole, all wheel studs POP and the wheel says "Sayonara".... No thanks.
Re: Torque Wrech [Re: 2009Edge] #4601051
12/11/17 08:32 PM
12/11/17 08:32 PM
Michigan
stockrex Offline
stockrex  Offline
Michigan
steel wheels?
op, I have a diesel 3/4 ton and mine mucho mucho bigger wheels spec lower torque.
Where did you see this torque spec? owners manual?
Ridgeline, Dmax, Ford 3.5
Oil Whisperer!*Fear the DINO*
