The case for quitting Facebook
by StevieC. 03/23/19 11:21 PM
Mixing Toyota Spec'ed 0w20 & 5w20
by David2431. 03/23/19 09:59 PM
Run old DOS games on your Wii
by StevieC. 03/23/19 09:51 PM
Live in PA? Need a car? Want something UNIQUE?
by 14Accent. 03/23/19 09:33 PM
Painting plastic
by HangFire. 03/23/19 09:27 PM
Rav4 vs Forester
by fdcg27. 03/23/19 09:07 PM
cleanser stain on cylinder liners
by neo3. 03/23/19 09:06 PM
Electronics and DC Voltage Question
by maverickfhs. 03/23/19 08:39 PM
Oil Change Tips for the Newbie
by StevieC. 03/23/19 08:39 PM
DashCams
by Eddie. 03/23/19 08:07 PM
Rough idle... Only in drive
by nicholas. 03/23/19 07:02 PM
Using synthetic blend or full synthetic oil
by FixItDad28. 03/23/19 07:01 PM
What's in Maxima oil?
by Truckedup. 03/23/19 06:29 PM
2015 Acura TLX 3.5L V6
by blackdiamond. 03/23/19 06:20 PM
Group 3 oil with best heat stability?
by LSXHitman. 03/23/19 05:24 PM
FixItDad28, RandomJoe, Sciascia, sosp197, peppercorn
67597 Registered Users
25 registered members (c502cid, dishdude, carlprop, csandste, Blkstanger, 3 invisible), 740 guests, and 56 spiders.
Topics286,320
Posts4,906,408
Members67,597
Most Online2,967
Mar 10th, 2019
Gap the spark plugs or leave them? #4600774
12/11/17 03:34 PM
12/11/17 03:34 PM
The Northeast
mclasser Offline OP
mclasser  Offline OP
The Northeast
I've got OEM NGK plugs on the way for my Infiniti. FSM calls for a 0.043 in gap, but they come pre-gapped @.044 in. A lot of people say not to mess with the gap and just drop 'em in.
Since gaps open up over time I think I should set them to spec from the get-go. What do you guys think?
2018 Hyundai Elantra VE
2013 Honda Pilot EX-L 4WD
2002 Honda Accord EX-L
Re: Gap the spark plugs or leave them? [Re: mclasser] #4600778
12/11/17 03:37 PM
12/11/17 03:37 PM
Santa Barbara, CA
bdcardinal Offline
bdcardinal  Offline
Santa Barbara, CA
Put them in as is. Would not lose sleep over .001" difference. You aren't building a race engine where you modify the electrode shape and index the plugs.
1995 Ford Mustang GT
Ford/Mazda Parts Counter
NRA Benefactor Member
Re: Gap the spark plugs or leave them? [Re: mclasser] #4600787
12/11/17 03:49 PM
12/11/17 03:49 PM
NC
fenixguy Offline
fenixguy  Offline
NC
I wouldn't mess with them myself. I always check new plugs but that's plenty close enough.
'16 Frontier SV 4x4-PP/Nissan OEM
'08 CR-V EX AWD-Valvoline Syn MaxLife/Fram TG
'01 Civic EX-Valvoline Syn MaxLife/Fram UG
'00 Civic LX-PYB/Fram UG
Re: Gap the spark plugs or leave them? [Re: mclasser] #4600790
12/11/17 03:52 PM
12/11/17 03:52 PM
D/FW Metroplex
The_Nuke Offline
The_Nuke  Offline
D/FW Metroplex
Verify they are within the range of acceptable gap for your application (into which 0.044" does indeed fall) before you stab 'em.
I've had plugs come pre-gapped at a different gap than what was listed in the book, so checking for that first and adjusting if found is more important than trying to close the gap 0.001" IMHO (something which would be very difficult to accomplish with any degree of accuracy I would think).
2012 Charger Pursuit aka "The Bacon Hauler"
- 5.7L + NAG1 (A5) + 2.62 (215mm)
Re: Gap the spark plugs or leave them? [Re: mclasser] #4600791
12/11/17 03:53 PM
12/11/17 03:53 PM
S California
OneEyeJack Offline
OneEyeJack  Offline
S California
There's the thought that they are correct and your measurement is off .001. smile
Re: Gap the spark plugs or leave them? [Re: mclasser] #4600799
12/11/17 03:59 PM
12/11/17 03:59 PM
Ontario, Canada
mightymousetech Offline
Ontario, Canada
If they have a platinum ground electrode, they can not be regapped.
And 0.043 vs 0.044? Just leave them.
Mighty Mouse Tech
BMW Tech, Former Acura Tech
2010 Civic Si Castrol 0W40, Redline MTL
2013 BMW 135i M Sport Edition Castrol 0W40, Redline MTL
Re: Gap the spark plugs or leave them? [Re: mclasser] #4600800
12/11/17 04:00 PM
12/11/17 04:00 PM
New Zealand
Silk Offline
Silk  Offline
New Zealand
It's a Japanese vehicle, the gap is 1.1mm, which is 0.0433070088'' Get it right - .043 is too tight, .044 too wide, set it to 1.1mm.
1987 BMW R65 - Aegis SAE30
2005 Nissan Expert - 5W-40 Castrol Magnatec diesel.
1996 Volvo T5 - Penrite HPR15 - 15W-60. Ryco syntec filter.
Re: Gap the spark plugs or leave them? [Re: mclasser] #4600810
12/11/17 04:09 PM
12/11/17 04:09 PM
Illinois
SHOZ Offline
SHOZ  Offline
Illinois
I always gap mine a couple thou under. But I would not put them in without checking them.
2008 Hyundai Accent 1.6L 5 sp manual hatchback
2010 Hyundai Genesis Coupe Track 2L Turbo 6sp manual
Re: Gap the spark plugs or leave them? [Re: Silk] #4600855
12/11/17 05:30 PM
12/11/17 05:30 PM
USA
slacktide_bitog Offline
USA
For the I35, I would strongly suggest iridium, sine they are impossible to replace in your car since you have to remove the intake to access them. You may also want to replace the valve cover gasket, the rear 3 fuel injectors, clean the EGR tube, and possibly replace the knock sensor, too.
Platinum is good for 60k. Iridium is good for 100k
Denso #3417 or #4703
+1
Re: Gap the spark plugs or leave them? [Re: slacktide_bitog] #4600903
12/11/17 06:30 PM
12/11/17 06:30 PM
Suburban St. Louis
dkcase Offline
dkcase  Offline
Suburban St. Louis
If indeed the original spec is 1.1mm (accurate only to the tenths place), you might think that could be rounded from 1.051 to 1.149. In which case correct could be 0.041 to 0.045. I'd say leave them.
Re: Gap the spark plugs or leave them? [Re: dkcase] #4600950
12/11/17 07:31 PM
12/11/17 07:31 PM
Champlain/Hudson Valley
Kira Offline
Kira  Offline
I vote for post #4600800. Very funny.
Re: Gap the spark plugs or leave them? [Re: mclasser] #4600960
12/11/17 07:51 PM
12/11/17 07:51 PM
Clovis, CA
Merkava_4 Offline
Merkava_4  Offline
Clovis, CA
I would gap them! If you leave them at .044" when the manufacturer specifies .043" - you're losing .001" allowable electrode wear. That's a huge amount of wear for spark plugs that you would be just giving away.
Re: Gap the spark plugs or leave them? [Re: Kira] #4600986
12/11/17 08:16 PM
12/11/17 08:16 PM
Southeastern, PA
Rick in PA Offline
Rick in PA  Offline
Southeastern, PA
Slow night here. It turns out the last significant digit is less that the diameter of an atom.
A wise man told me:
"Heat is your friend." and "Any oil is better than no oil."
Re: Gap the spark plugs or leave them? [Re: mclasser] #4601029
12/11/17 09:13 PM
12/11/17 09:13 PM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
A big gap is my friend - - always has been.
Olds Big Blocks in the 70's were gapped at .080" !!!!
I usually open everything up to at least .050-.055", sometimes .060" before installing them.
Re: Gap the spark plugs or leave them? [Re: Merkava_4] #4601035
12/11/17 09:17 PM
12/11/17 09:17 PM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
No, it isn't.
Sparks jump from sharp edges - the distance (gap) is NOT as important as having a sharp point/edges.
That is why iridium plugs have such a tiny wire in the center.
I have seen it on the dyno - old, worn plugs with rounded electrodes gapped down to .040" will always make less power than new electrodes with sharp edges gapped to .060".
