How to dispose / recycle Li-Ion batteries?
by 92saturnsl2. 03/24/19 06:16 PM
New member of the (automotive) family!
by addyguy. 03/24/19 06:04 PM
6.2 f250 6.4 ram 2500 towing with a gasser
by FLORIDA. 03/24/19 05:55 PM
T5 15w40 for my bike?
by Degreaser. 03/24/19 05:47 PM
Studded tires in warm weather
by y_p_w. 03/24/19 05:28 PM
ST 15W40
by mobilaltima. 03/24/19 05:02 PM
I need a filter cutter person
by Marco620. 03/24/19 03:21 PM
VIRGIN BOSCH D+ 3421 CUT OPEN
by 53' Stude. 03/24/19 02:45 PM
My first cut. Donaldson P502503
by BeerCan. 03/24/19 02:25 PM
Sludge and Facebook's infinite wisdom
by RDY4WAR. 03/24/19 02:05 PM
Gear lube 75W90 Synthetic GM# 88900401
by rcbob. 03/24/19 01:47 PM
Rislone Rebates
by Nickdfresh. 03/24/19 01:42 PM
IndyCar Classic at COTA
by bdcardinal. 03/24/19 12:29 PM
STP 500 at Martinsville
by bdcardinal. 03/24/19 12:27 PM
Source For Microfiber Towels
by Wrenchturner44. 03/24/19 12:26 PM
Jcountry, CMichael, dude59, Petrolhead, stp
67608 Registered Users
102 registered members (2010Civic, 92saturnsl2, 2004tdigls, 2015_PSD, 11 invisible), 2,194 guests, and 60 spiders.
Topics286,352
Posts4,906,914
Members67,608
Most Online2,967
Mar 10th, 2019
Oversized Version of XG2 (updated Chrysler 4.7)? #4600715
12/11/17 02:34 PM
12/11/17 02:34 PM
North Dakota
mphilleo Offline OP
mphilleo  Offline OP
North Dakota
I'm planning on doing an oil change on my truck with the updated Chrysler 4.7 (22mm threads). It looks like my filter is the XG2, but so far my search for a longer version with the same threads and gasket diameter has been fruitless. Most references are to the previous version of the 4.7 which has a different thread. In fact, I think I found a conversation on here from 2011 or 2012 saying XG2 is all we get. Has that changed since then?
Re: Oversized Version of XG2 (updated Chrysler 4.7)? [Re: mphilleo] #4600795
12/11/17 03:56 PM
12/11/17 03:56 PM
San Antonio, TX
Nyogtha Offline
Nyogtha  Offline
San Antonio, TX
There are a few. My recollection is the Luber Finer PH26 and AC Delco PF26, both made by Champion Laboratories, are the same diameter as the Mopar MO-899 but about an inch taller. Refer to the AC Delco PF26 for media efficiency. IIRC the AC Delco has base end BPV and the Luber Finer has dome end BPV. Both have nitrile ADBV.
There are a number of larger Wix / Napa Gold oil filters that will work too but I don't remember the application numbers; search a little here in the oil filters sub-forum as this was discussed a few months ago. However, I do recall the Wix / NG oversize filters showed plain cellulose media with no efficiency rating listed, so probably significantly less than the 95% @ 20 microns performance of the standard Wix / NG media.
"No matter how paranoid you are you're not paranoid enough. Tell the truth. Reach as many people as you can with it. That's your weapon." - Susanne Modeski, aka "Holly" to The Lone Gunmen
Re: Oversized Version of XG2 (updated Chrysler 4.7)? [Re: mphilleo] #4600839
12/11/17 04:51 PM
12/11/17 04:51 PM
Canyon County Idaho
CT8 Offline
CT8  Offline
Canyon County Idaho
There is a 2 qt filter that will fit.
2015 Ford F150 2.7
2018 Ford F350 6.2
Re: Oversized Version of XG2 (updated Chrysler 4.7)? [Re: CT8] #4600845
12/11/17 05:02 PM
12/11/17 05:02 PM
North Dakota
mphilleo Offline OP
mphilleo  Offline OP
North Dakota
I'd love to know what it is and if there's a Fram XG equivalent.
Re: Oversized Version of XG2 (updated Chrysler 4.7)? [Re: mphilleo] #4600858
12/11/17 05:31 PM
12/11/17 05:31 PM
USA
slacktide_bitog Offline
USA
The XG2 isn't big enough? smile
Re: Oversized Version of XG2 (updated Chrysler 4.7)? [Re: slacktide_bitog] #4600866
12/11/17 05:41 PM
12/11/17 05:41 PM
North Dakota
mphilleo Offline OP
mphilleo  Offline OP
North Dakota
I'm not sure if I'd even be satisfied with a filter the size of a Hills Bros can. wink
Re: Oversized Version of XG2 (updated Chrysler 4.7)? [Re: mphilleo] #4600871
12/11/17 05:48 PM
12/11/17 05:48 PM
Port Orange, Florida
Panzerman Offline
Panzerman  Offline
I look at this way, the XG2 is about the biggest stock oil filter out there if Nissan's are going 200,000 plus on dinky little ATV oil filters and my Dodge won't make it on a coffee cup oil filter maybe I should look at Nissan not getting a bigger oil filter.
2006 Dodge Ram 2500 Hemi 4x4
2016 Dodge Challenger Scat Pack
Re: Oversized Version of XG2 (updated Chrysler 4.7)? [Re: mphilleo] #4600884
12/11/17 06:03 PM
12/11/17 06:03 PM
San Antonio, TX
Nyogtha Offline
Nyogtha  Offline
San Antonio, TX
As someone who ran PH8A equivalent size filters as stock on our motors for years, I was disappointed my 400 cubic inch engine in my 73 Charger called for the reduced size PH43, after that my next 2 vehicles (trucks) used the PH16 equivalent, and now its metric cousin the PH2. I'm OK with running this size on my 345 cubic inch V8 after zero engine problems running PH16 equivalent filters on a 318 and a 360 cubic inch engine over two decades.
My ZTR mower takes the PH3614 equivalent, I've been running oversize Wix CQ Blue 85516 filters instead (TG3600 equivalent).
I don't recall any Fram brand oversize offerings for the PH/TG/XG2 coming up in the discussion a few months ago, just Champion Labs and WIX / NG as I mentioned earlier. You can try a PM or email to board member Motorking aka Jay Buckley who works for Fram, to ask a knowledgable Fram employee directly about Fram offerings.
Or convert your current engine oil filter mount to the earlier generation 4.7l which took PH16 equivalent and run a XG8A instead.
Re: Oversized Version of XG2 (updated Chrysler 4.7)? [Re: mphilleo] #4600952
12/11/17 07:35 PM
12/11/17 07:35 PM
Central Washington
Colt45ws Offline
Colt45ws  Offline
Central Washington
There is nothing bigger as a XG2. If you had the earlier model with the XG16 you could use the XG8A. The XG line only covers the applications with a decent amount of throughput. They are not going to make a XG of a filter only called out on a 50 year old farm tractor.
There IS a larger filter with 22mm threads but its standard element.
If you want a rediculously large filter, do a remote mount setup with a 3/4-16 filter head, and there is a 2 qt 3/4-16 filter that baldwin makes a high efficiency part number.
-Colton
2002 Ford Crown Vic PI 207k, Ex-Kootenai County, ID Unit #42
Down for engine swap
2003 Ford Crown Vic PI 86k
Pennzoil Conv HM 5W30, Fram XG2
Re: Oversized Version of XG2 (updated Chrysler 4.7)? [Re: mphilleo] #4600956
12/11/17 07:43 PM
12/11/17 07:43 PM
Central Washington
Colt45ws Offline
Colt45ws  Offline
Central Washington
Baldwin B7311-MPG high efficiency baldwin 3/4-16 filter. -MPG meaning maximum performance glass.
If you wanna get crazy, use a stud converter on the 3/4-16 head to go to 1-16 thread.
Then you can use a fleetguard LF9028.
That filter has a 2 micron bypass element in addition to a standard element inside of it.
-Colton
Re: Oversized Version of XG2 (updated Chrysler 4.7)? [Re: Colt45ws] #4600961
12/11/17 07:52 PM
12/11/17 07:52 PM
Fort Lauderdale, FL
DoubleWasp Offline
DoubleWasp  Offline
Fort Lauderdale, FL
That's what I did to my 00 JGC.
Re: Oversized Version of XG2 (updated Chrysler 4.7)? [Re: mphilleo] #4601022
12/11/17 09:04 PM
12/11/17 09:04 PM
Waco, TX
Linctex Online content
Linctex  Online Content
Waco, TX
Originally Posted By: mphilleo
It looks like my filter is the XG2, but so far my search for a longer version with the same threads and gasket diameter has been fruitless. ....XG2 is all we get.
XG2 is PLENTY for all of your needs, all the way to 20,00 miles easily.
I ran the smaller (FL-500) size Tough Guard TG10575 on a 4.6 in an F150, and it did great for 15,000 miles:
https://bobistheoilguy.com/forums/ubbthreads.php/topics/4426839/
Re: Oversized Version of XG2 (updated Chrysler 4.7)? [Re: mphilleo] #4601139
12/11/17 11:41 PM
12/11/17 11:41 PM
Waco, TX
Waco, TX
Then there's this one:
WIX 57045
Re: Oversized Version of XG2 (updated Chrysler 4.7)? [Re: mphilleo] #4601185
12/12/17 01:45 AM
12/12/17 01:45 AM
San Antonio, TX
Nyogtha Offline
Nyogtha  Offline
San Antonio, TX
I *think* this was one of the Wix alternatives, the thread matches and the gasket is just a few mm different than the 57899.
http://www.wixfilters.com/Lookup/PartDetails.aspx?Part=2019366
Re: Oversized Version of XG2 (updated Chrysler 4.7)? [Re: Panzerman] #4601190
12/12/17 01:58 AM
12/12/17 01:58 AM
Virginia
bbhero Offline
bbhero  Offline
Virginia
I have 211k miles on my Nissan Altima 3.5 two door coupe. Running those rinky dink small 7317s.
Nissan Altima 3.5 Coupe
Mobil Super 5w30 Wix 57356
"Treat your family like your friends and treat your friends like your family."
