Fireworks Stores
by Warstud
06/20/18 09:36 PM
1994 Ranger fuel tank/frame cleanup & NOS part
by 01rangerxl
06/20/18 09:27 PM
Koreans top J.D. Power qlty; Ford, GM, FCA make strides
by wemay
06/20/18 09:18 PM
How Fast to Run a ZeroTurn Mower
by Gebo
06/20/18 09:10 PM
Bosch 3300 C&P Yamaha FZ-07
by bmwpowere36m3
06/20/18 08:49 PM
My FIL in hospice
by fdcg27
06/20/18 08:41 PM
Spraying Polyurethane
by Texican
06/20/18 08:37 PM
Dehumidifier icing
by Kestas
06/20/18 08:37 PM
Diesel lube in Petrol Engine
by Ducked
06/20/18 07:46 PM
New key programming cost
by 92saturnsl2
06/20/18 07:27 PM
When you help someone and its time to walk away
by RazorsEdge
06/20/18 07:09 PM
Sightly overfilled oil..ok or drain?
by flinter
06/20/18 07:08 PM
Wheel says 50 mph max
by pda1122
06/20/18 06:54 PM
15w40 Maxlife in Motorcycle
by Brian553
06/20/18 06:39 PM
BITOGer in Ottawa/Orleans Canada area ? ...
by Papa Bear
06/20/18 06:36 PM
Old Engine SOUND
by MasterSolenoid
06/20/18 06:06 PM
ProMotive PH 2500 CUT OPEN
by car51
06/20/18 04:54 PM
go green or Dexcool?
by umungus1122
06/20/18 04:50 PM
Latest info on ExxonMobil synthetic base stocks
by Gokhan
06/20/18 04:49 PM
Pennzoil Platinum 5w30 - $3.21/qt Amazon
by SnowmanCO
06/20/18 04:37 PM
bcj, Ilia, nmac9, Theraven, battleman13
65279 Registered Users
107 registered (4WD, addyguy, 01rangerxl, 87sammy, 97f150, 17 invisible), 1408 Guests and 52 Spiders online.
65279 Members
67 Forums
285679 Topics
#4600615 - 12/11/17 11:35 AM Napa/Felpro valve cover gasket = junk?
Drew99GT Online   happy
Loc: Colorado Springs
Bought one for my Corolla as the one in the car was leaking pretty bad. The Napa Felpro unit was a little too short around the cam sprocket and distributor; it just didn't fit in the groove all the way, but Napa already closed, so I went ahead and installed it hoping it will seat correctly when tightened. Plus the book says to use a dab of RTV in the corners where the cam/distributor come out the head as they are 90 degree corners.
It seems EVERYTHING I buy automotive nowadays is absolute JUNK, even OEM stuff. I though Felpro was still decent...
#4600626 - 12/11/17 11:42 AM Re: Napa/Felpro valve cover gasket = junk? [Re: Drew99GT]
mclasser Offline
Loc: The Northeast
I remember hearing about Felpro having issues with certain Corolla gaskets.
2018 Hyundai Elantra VE -- 3K
2013 Honda Pilot EX-L 4WD -- 55K
2002 Honda Accord EX-L -- 210K
#4600627 - 12/11/17 11:42 AM Re: Napa/Felpro valve cover gasket = junk? [Re: Drew99GT]
Mr Nice Offline
Loc: Orlando, FL
Maybe put some RTV silicone, that's what I do on our Hondas and I have zero leaks.
Did my RSX last year and no leaks.
#4600642 - 12/11/17 12:05 PM Re: Napa/Felpro valve cover gasket = junk? [Re: Drew99GT]
Kool1 Offline
Loc: California
Fel-Pro gaskets have been questionable for me as far as longevity is concerned. I've had excellent luck with Victor/Reinz gaskets. Unfortunately Victor/Reinz gaskets are a little tough to obtain and are now Mahle.
#4600649 - 12/11/17 12:13 PM Re: Napa/Felpro valve cover gasket = junk? [Re: Kool1]
P8bsgOy Offline
Loc: The Deep Swamp
Get them on EBay. They have everything. Might be a little old but you should not have issue finding the other brands there.
#4600673 - 12/11/17 12:59 PM Re: Napa/Felpro valve cover gasket = junk? [Re: Drew99GT]
boom10ful Offline
Loc: California
I was pretty disappointed in Fel-Pro when I was replacing the water pump on my car. Their gasket was a cheap cardboard gasket that fell apart after torquing the bolts. I went to the dealer and bought an OEM metal gasket for $4 more.
#4600856 - 12/11/17 04:31 PM Re: Napa/Felpro valve cover gasket = junk? [Re: Drew99GT]
slacktide_bitog Online   content
Loc: USA
Rock Auto still has Mahle/Reinz gaskets smile
Get the Mahle/Victor Reinz, Beck/Arnley, or Magnum
#4600934 - 12/11/17 06:11 PM Re: Napa/Felpro valve cover gasket = junk? [Re: boom10ful]
Mr Nice Offline
Loc: Orlando, FL
Something that important you have to use metal gasket.
#4601023 - 12/11/17 08:05 PM Re: Napa/Felpro valve cover gasket = junk? [Re: Drew99GT]
Charlie2015 Online   content
Loc: Georgia
I have a Fel-pro valve cover gasket and tube seals on my f23a accord. No leaks. I had OE Hondabond RTV gasket maker for the pan gasket that leaked at the dip on the transmission side. I replaced it with an after-market fel pro gasket and no more leaks.
Sometimes, it is all about application.
1998 Honda Accord EX 2.3L Auto
2009 Scion TC Manual
#4601249 - 12/12/17 06:22 AM Re: Napa/Felpro valve cover gasket = junk? [Re: Drew99GT]
Lubener Offline
Loc: N.Ohio
Get a horse... Problem solved.
The "thinking" man's friend.
#4601619 - 12/12/17 12:55 PM Re: Napa/Felpro valve cover gasket = junk? [Re: Drew99GT]
nthach Offline
Loc: California
Fel-Pro can be hit or miss on Japanese cars, I insist on OEM gaskets for valve covers. On the flipside, I've installed a Fel-Pro valve cover gasket set on a Nissan Quest and it worked fine. I'm using Fel-Pro's plenum gaskets on my parent's current van and they fit and installed fine despite being made in China.
#4601687 - 12/12/17 01:47 PM Re: Napa/Felpro valve cover gasket = junk? [Re: Drew99GT]
I ordered a Beck Arnley; from the pics, it looks OEM, maybe Aisin. Hopefully it works...
Car is acting like it has a vacuum leak; rough idle etc. I knew I shouldn't have put that [censored] on my car. mad
Edited by Drew99GT (12/12/17 01:48 PM)
#4602043 - 12/12/17 07:47 PM Re: Napa/Felpro valve cover gasket = junk? [Re: Drew99GT]
miden851 Offline
Loc: GA
I used Felpro about 3 years back for the valve cover; after 3 years needs to be replaced; [censored] quality
2008 Mazda6i GT; @195K miles
2016 Honda CR-V EX-L; @29K miles
#4602061 - 12/12/17 07:54 PM Re: Napa/Felpro valve cover gasket = junk? [Re: Drew99GT]
bdcardinal Offline
Loc: Santa Barbara, CA
I think it is purely application specific. On a SBF the Fel-Pro one piece oil pan gasket is the bees knees. However for a head gasket Cometic MLS only.
1995 Ford Mustang GT
Ford/Mazda Parts Counter
NRA Benefactor Member
#4602500 - 12/13/17 11:20 AM Re: Napa/Felpro valve cover gasket = junk? [Re: Drew99GT]
ZebRuaj Offline
Loc: MN
I share the same sentiment. Used a Fel-Pro valve cover gasket on an 2003 Matrix with the 1.8. Even dabbed silicon on the spots where the service manual indicated to help. Still leaked.
~Shade tree mechanic for friends and family.
