VOA Amsoil 75W-140 Severe Gear Oil
Enjoy!
Blackstone comments:
No metal was present and the additives are pretty standard for a gear lube. The viscosity was correct for 75W/140. This oil contains a little silicon. That normally shows dirt, but here it's an anti-foam additive. No moisture or insolubles showed up. The TAN was 3.1, so the oil starts out with a little acidity due to all of the phosphorus additive present. In any case, this is serviceable oil.
Code:
Oil Brand/Type: Amsoil
Oil Viscosity: 75W-140
API Service: GL-5
Lab: BLKST
Date: 07/26/2012
Aluminum: 0
Chromium 0
Iron: 0
Copper: 0
Lead: 0
Tin: 0
Molybdenum: 0
Nickel: 0
Manganese: 0
Silver: 0
Titanium: 0
Potassium: 0
Boron: 99
Silicon: 11
Sodium: 0
Calcium: 3
Magnesium: 0
Phosphorus: 781
Zinc: 13
Barium: 0
SUS Viscosity @ 210°F 126.1
cSt Viscosity @ 100°C 26.35
Flashpoint in °F 390
Fuel % --
Antifreeze % --
Water % 0.0
Insolubles % 0.0
TBN N/A
TAN 3.1
Thanks for getting the information for us!
What about the amount of sulfur in modern (since 2010..2013) AMSOIL Severe Gear (75W-90 or 75W-110 or 75W-140)?
In VOA or UOA?
Only 781ppm phosphorus!!! (Old Amsoil Severe gear had 1300ppm phosphorus)
Is this real GL-5 oil?
Blackstone needs to re-calibrate again. The P is way low. Some people don't understand measuring P can be difficult, and a single VOA is not evidence of a formula change.
In VOA or UOA?
What about sulfur content?
You could always send in your own Amsoil sample and pay an extra $25 for the extra sulfur analysis.
I have done it. 2% of S
That appears to be 4X too high.
Can you post your complete analysis results?
