The real culprit about 18k
by Ablebody. 09/20/18 06:04 PM
How not to drain a pool.
by StevieC. 09/20/18 05:50 PM
Tranny fluid in Old Ferguson Tractor ?
by Rudy1999 250. 09/20/18 03:39 PM
New (old) car inbound
by BeerCan. 09/20/18 02:42 PM
Ford AWD PTU fluid always black
by Raven. 09/20/18 02:34 PM
PC not charging
by sleepery. 09/20/18 01:53 PM
Can alternators make noise?
by Benzadmiral. 09/20/18 01:21 PM
Pr 1970 Superbirds For sale - Barn Find
by user52165. 09/20/18 12:32 PM
Fram Ultra Air Filters
by StevieC. 09/20/18 12:20 PM
Change oil filter or not. Very low miles
by Martin10. 09/20/18 11:37 AM
Toslink optical audio cable (plastic) experience
by ffhdriver. 09/20/18 11:30 AM
A woman I work with wants an affair with me!
by Drew99GT. 09/20/18 11:08 AM
ACEA A5/B5 REQUIREMENTS
by Kjmack. 09/20/18 10:56 AM
Carolina Reaper hot peppers
by gman2304. 09/20/18 09:54 AM
New Fram air filter?
by irv. 09/20/18 09:15 AM
Any golf cart experts?
by HawkeyeScott. 09/20/18 09:15 AM
EU Subaru 2.5 FB engine oil
by IMPALA08. 09/20/18 08:16 AM
FarmerDude, Bman90, Alday714, Joephoto, tlelectric
66021 Registered Users
84 registered members (2002 Maxima SE, 08z06, 4WD, 2010Civic, 77GrandPrix, 53' Stude, 5 invisible), 1,588 guests, and 68 spiders.
Topics290,728
Posts4,849,192
Members66,021
Most Online3,590
Jan 24th, 2017
Round-the-clock battery maintenance- good or bad? #4600303
12/10/17 11:51 PM
12/10/17 11:51 PM
ON, Canada
yugrus Offline OP
yugrus  Offline OP
ON, Canada
I have NOCO GENM1 4-Amp on-board charger/maintainer installed under the hood of my Tahoe. It is a part of the offshore 120V power devices grid on the car that are connected to power through wifi timers, so I can control the timing and what devices are on from the house.
The truck is parked outside, and is plugged in through the waterproof AC port plug mounted under the rear bumper.
The charger is on by default when other devices are on (transmission and engine heater pads, interior heater, seat heaters, etc). I also turn it on overnight once a week to run a full cycle.
The truck sits most of the time, and when it is in use, its smart charging system detects that the battery is fully charged and drops the voltage to 12.6V while driving.
I was wondering if it would be helpful at all to run the charger like that 24/7? Would it be helpful or detrimental to the battery life? It is a smart maintainer, after all.
What about when the ambient temperature drops to -10C? Or -20C?
I just don't want to do too much of a good deed...
'14 Chevrolet Tahoe
'15 Mazda CX-5
Re: Round-the-clock battery maintenance- good or bad? [Re: yugrus] #4600309
12/11/17 12:05 AM
12/11/17 12:05 AM
Kuwait
Falcon_LS Offline
Falcon_LS  Offline
Kuwait
Shouldn't be something to worry about, if anything it will prevent sulfation. I have an OptiMate 7 Select. If a car is not going to be used for a while, I leave it connected for a couple of days or so. In maintenance mode, it continually monitors the battery and adjusts voltage accordingly. Being a smart charger/maintainer, I'm sure the Noco works the same way.
99 Explorer: H17W02/GC 0W40
00 Pajero: XG9688/MC 15W40
01 Grand Marquis: XG2/XCess 5W40
03 Expedition SSV: XG2/XCess 5W40
05 Envoy: XG9837/5W30 ESP
06 XJ8L: C2C41611/5W30 ESP
07 SRX: XG8765/5W30 ESP
Re: Round-the-clock battery maintenance- good or bad? [Re: yugrus] #4600311
12/11/17 12:06 AM
12/11/17 12:06 AM
Michigan
researcher Offline
researcher  Offline
Michigan
personally I dont see an issue, what's the difference between this and keeping the battery on a battery tender outside of the vehicle. If it was stored, the battery would be having the same thing happen.
But a battery tender is charging the battery at room temp (inside). I think at a certain temp even batteries (lead-acid) can freeze and you don't want to charge them then! ouch!
Re: Round-the-clock battery maintenance- good or bad? [Re: yugrus] #4600315
12/11/17 12:12 AM
12/11/17 12:12 AM
ON, Canada
yugrus Offline OP
yugrus  Offline OP
ON, Canada
Thank you guys! Regarding low-temp conditions, maybe the battery blanket should be the next thing? It can be turned on through thermostatic switch whenever the maintainer is on. What do you say?
'14 Chevrolet Tahoe
'15 Mazda CX-5
Re: Round-the-clock battery maintenance- good or bad? [Re: yugrus] #4600320
12/11/17 12:22 AM
12/11/17 12:22 AM
Michigan
researcher Offline
researcher  Offline
Michigan
I should or you can too, look up what the minimum temp for charging a lead acid battery is.
but warm it up isn't a bad idea.
Re: Round-the-clock battery maintenance- good or bad? [Re: yugrus] #4600326
12/11/17 12:33 AM
12/11/17 12:33 AM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
That's not right at all.....
Re: Round-the-clock battery maintenance- good or bad? [Re: yugrus] #4600327
12/11/17 12:37 AM
12/11/17 12:37 AM
Northern Kentucky
901Memphis Offline
901Memphis  Offline
Northern Kentucky
It's definitely good to keep the battery full. These type of batteries want to stay full as much as possible
2012 Chevy Cruze LT 1.4T - 50k
2002 Buick Century 130k - Built 4T65e(Maxlife) - Edge 0w40 + Fram XG3980
Re: Round-the-clock battery maintenance- good or bad? [Re: Linctex] #4600330
12/11/17 12:42 AM
12/11/17 12:42 AM
ON, Canada
yugrus Offline OP
yugrus  Offline OP
ON, Canada
Well, that's what most of the new owners of this family of trucks say when they see the needle going to the left of the scale. Some begin to panic. But in fact, this is perfectly normal. ECU monitors the charging process very closely, using the voltage AND the current information. There is in fact the current measuring loop on the main wire.
Besides it's intended purpose to be able to claim fuel consumption reduction, the system protects the battery from overcharging. It kicks right back in when the battery charge becomes depleted. The voltage isn't constant and varies according to the charging demands.
On the other hand, our Mazda, with its hi-tech Skyactiv has a very dumb charging system, with 14V+ no matter what the conditions are. Go figure. ..
'14 Chevrolet Tahoe
'15 Mazda CX-5
Re: Round-the-clock battery maintenance- good or bad? [Re: yugrus] #4600359
12/11/17 04:44 AM
12/11/17 04:44 AM
ME
eljefino Offline
eljefino  Offline
ME
Sounds brilliant. As an added bonus shore power is 10-15x cheaper than that you generate yourself via gasoline. Just sad that your truck comes to this-- they should sense winter and not pull MPG shenanigans.
Re: Round-the-clock battery maintenance- good or bad? [Re: eljefino] #4600430
12/11/17 08:00 AM
12/11/17 08:00 AM
Los Gatos CA
djb Offline
djb  Offline
Los Gatos CA
I think you had better review your numbers. Around here, only the off-peak residential electric rate is less expensive than gasoline power and it's a close call for that.
The trade-off will obviously vary with rates and efficiency, but it's certainly not 10x-15x.
Smart chargers vary considerably in their 'smarts'. I would check that your specific model compensates for the temperature and battery chemistry correctly.
Battery charge optimization has been around for at least a quarter century. A basic version was on Japanese alternators that used the brake light circuit to increase output. That would increase engine braking when slowing down, and reduce the engine load when pulling away after stopping. Modern versions are similar, which much more information available. They can target a state-of-charge range that maximizes the battery life, not always pushing to 100% charged.
Re: Round-the-clock battery maintenance- good or bad? [Re: yugrus] #4600431
12/11/17 08:02 AM
12/11/17 08:02 AM
New England
Virtus_Probi Offline
New England
I can't even imagine how many times I would drive away with the plug still attached if I had a system like that...
2014 Forester XT, 86000 miles
Last Change;
M1 5W30 d1G2
Tokyo Roki 15208AA170 filter
Re: Round-the-clock battery maintenance- good or bad? [Re: yugrus] #4600456
12/11/17 08:39 AM
12/11/17 08:39 AM
ON, Canada
yugrus Offline OP
yugrus  Offline OP
ON, Canada
I back into the driveway, and I need to literally trip over the cord to get in the truck, so no concern of driving away with it attached.
The charger does not have temperature compensation. It was intended for marine applications. Does that mean that it will overcharge the battery at the temperature extremes? I already have plans for thermostatic battery blanket, so this mitigates the low-side concern, but still.
Going down to -10C, would un-changed rate of charge be detrimental to the battery life?
'14 Chevrolet Tahoe
'15 Mazda CX-5
Re: Round-the-clock battery maintenance- good or bad? [Re: yugrus] #4600500
12/11/17 10:18 AM
12/11/17 10:18 AM
Idaho
CT8 Offline
CT8  Offline
Idaho
Not scientific but the battery on my John Deere 4310 the tractor lasts 2 years without a charger and 7 years with a msintenance charger.
"Don't let your preconceived notions get in the way of facts."
Geoff Metcalf
Re: Round-the-clock battery maintenance- good or bad? [Re: yugrus] #4600513
12/11/17 10:30 AM
12/11/17 10:30 AM
Marshfield , MA
andyd Offline
andyd  Offline
Marshfield , MA
just a quick question. How cold does it have get to freeze a lead acid battery with a charge in it? It was my understanding that a charged battery , even a low charge, can't freeze. School me please. TIA
Thick oil is better grin2
Re: Round-the-clock battery maintenance- good or bad? [Re: andyd] #4600530
12/11/17 10:56 AM
12/11/17 10:56 AM
USA
Reddy45 Offline
Reddy45  Offline
USA
There is a good analysis here: http://mathscinotes.com/2013/02/battery-freezing-math/
The freeze point is quite low...and I think only people in very northern climates need to worry.
