Making new springs?
JHZR2
Staff member
New Jersey
Need to make a new spring for this:
A piece from an old mortise lock.
What's the best source/approach? Are there special methods for bending springs so they work properly?
If you cannot find a reproduction,
you can get the correct type of steel, anneal it (soften)
cut, shape, form......
Hardening it to the correct temp is very, very tricky to do on a part that small.
Fortunately it's a non critical part, just want it right...
What is the right type of stee?
I'm not interested in a reproduction lock set, this one works perfect aside from this spring. Something else had fallen inside of the assembly, which can be understood after nearly 100 years...
Start off with this..
https://www.ebay.com/itm/FLAT-SPRING-STEEL-ASSORTMENT-MORTISE-LOCK-REPAIR/401307926188?hash=item5d6fd0feac:g:NfkAAOSwPcVVgecN
You can order music wire from McMaster Carr if you think a round spring can work. It can bend in hard condition. The Spot weld will be more difficult unless you have a spot welder. You could bend a 90 on the spring and then use some well cured JB weld it might work.
Rod
You can order music wire from McMaster Carr if you think a round spring can work. It can bend in hard condition. The Spot weld will be more difficult unless you have a spot welder. You could bend a 90 on the spring, put in in a drilled hole and then use some well cured JB weld it might work.
Rod
Rod
Fortunately it is not a spot weld, just a punched spot to either index the spring or help it stay.
Id like to learn how to properly shape and craft spring steel. Not sure how useful of a skill it will be for me, but it will be fun.
Making springs can be difficult. Spring steel is not very ductile. I believe they are formed first, then heat treated to make them "springy." It's called bainitic hardening. That's why spring metal snaps when you try to form them further.
Maybe you can use a metal tube to "sleeve" both ends together.
