DIY alignment done right?
by tookien. 03/24/19 10:03 PM
Cell phone privacy question
by loneryder. 03/24/19 10:00 PM
Ride quality between 45 and 35 sidewall
by bowlofturtle. 03/24/19 09:23 PM
FRAM TG 7317 - 12K miles opened
by crazy_raccoon. 03/24/19 09:01 PM
2014-2017 Toyota Corolla CVT Quiet Recall
by StevieC. 03/24/19 08:11 PM
Finally Found Factory Ammo my 308 Bolt Gun Likes
by Fastzntn. 03/24/19 08:10 PM
Umarex Glock 19 Co2
by Sonic. 03/24/19 07:57 PM
I put in 2 1/2 qts, damage?
by JLawrence08648. 03/24/19 07:21 PM
How to dispose / recycle Li-Ion batteries?
by 92saturnsl2. 03/24/19 06:16 PM
New member of the (automotive) family!
by addyguy. 03/24/19 06:04 PM
6.2 f250 6.4 ram 2500 towing with a gasser
by FLORIDA. 03/24/19 05:55 PM
T5 15w40 for my bike?
by Degreaser. 03/24/19 05:47 PM
Studded tires in warm weather
by y_p_w. 03/24/19 05:28 PM
ST 15W40
by mobilaltima. 03/24/19 05:02 PM
I need a filter cutter person
by Marco620. 03/24/19 03:21 PM
VIRGIN BOSCH D+ 3421 CUT OPEN
by 53' Stude. 03/24/19 02:45 PM
My first cut. Donaldson P502503
by BeerCan. 03/24/19 02:25 PM
Rollo, Drifted, Jcar516, gregjr7, daveed
67613 Registered Users
78 registered members (4WD, 2010Civic, 2015_PSD, ArrestMeRedZ, 9 invisible), 1,644 guests, and 57 spiders.
Topics286,361
Posts4,907,085
Members67,613
Most Online2,967
Mar 10th, 2019
Oil recommendation for old garden tractor on plow #4600110
12/10/17 07:16 PM
12/10/17 07:16 PM
West chicagoland
PrimitiveJunk Offline OP
West chicagoland
It's an old 14hp Cast Iron Kohler K321. About 100 hr on a rebuild. Plows for about .75-2 hours a snow event. Usual temperatures are 20-30 degrees F, as I try to get it cleaned up before the real cold sets in after the storm. Sometimes I have to run it from 0-20F, but only a few times a year. It sleeps in an unheated garage I'd guess about 25-35 degrees, but sometimes I leave the door open like a dummy & it starts from a colder ambient.
I run delo 15w40 in the warm seasons in it.
I was going to fill with my on hand 5w40 Rotella T6, but after looking it up, that's a THICK oil. (Like 14.x cst IIRC) so I had second thoughts. It's air cooled, and well shrouded. With the low ambient temperature, i wonder if it'd even hit 100c running. The motor is Spec'd for straight sae30 over 32 degrees, and 10w30 0-32 degrees with the (possibly old skool) caveat that it will consume from Kohler. Does that seem kinda thick & too far off spec for a splash luber?
So I jumped on BITOG, and wasted hours of my life lurking, and had mostly concluded GC 0w30. But I don't think that exists any more? Then I thought about M1 HM 5w30, or Rotella T5 10w30, but the are both super low cst IIRC, like [email protected]? This thing runs rich & probably shears oil like a sheep. Doesn't that seem pretty low vis?
Now I'm just lost & confused. Over analysis paralysis! Please help! (God I wish I could get GC 0w30!)
What's the best 0w / 5w HEAVY 30wt?
Is the 5w40 T6 really too heavy as I figure? I like that oil, and have it on hand. Maybe I should just dump that in
I'd prefer some good Zn / strong add pack for the old skool flat tappet design.
What would you guys recommend for a winter fill?
Sorry for the novel. Thanks for your time!
Max
Re: Oil recommendation for old garden tractor on plow [Re: PrimitiveJunk] #4600114
12/10/17 07:23 PM
12/10/17 07:23 PM
Cincinnati, USA
Dave9 Offline
Dave9  Offline
Cincinnati, USA
5W30 synthetic. Move to 10W40 when wear makes it sloppy
Re: Oil recommendation for old garden tractor on plow [Re: PrimitiveJunk] #4600118
12/10/17 07:26 PM
12/10/17 07:26 PM
Kalifornia Kollective
BrocLuno Offline
BrocLuno  Offline
If it liked 40 (Delo) in the summer and it's just winter temps you are concerned with, I'd switch it to 0W-40 and be happy (any brand as they are all good in this range). Very stout base oils and not too thick at op temp, plus very nice at cold temps when starting.
Does this thing have an electric starter, or are you pulling a rope?
As far as rich, I'd look into that... Does not need to be rich. The main jet on most of these old carbs is adjustable. So once it's up at op temp, tery turning it in a bit smile
Re: Oil recommendation for old garden tractor on plow [Re: PrimitiveJunk] #4600122
12/10/17 07:30 PM
12/10/17 07:30 PM
OH
fdcg27 Offline
fdcg27  Offline
OH
You have T6 on hand?
Use it. I would. This is a higher quality oil than what Kohler had in mind when they made their recommendations.
No worries since it is a 5W qualified oil and a HDEO might be a better choice for this OPE.
These engines aren't all that picky about oil grade anyway.
18 Accord Hybrid FF
17 Forester 18K VME 0W-20
12 Accord LX 96K SSO 0W-20
09 Forester 95K M1HM 10W-30
01 Focus ZX3 118K PP 5W-20
96 Accord LX 104K T5 10W-30
95 318i
Re: Oil recommendation for old garden tractor on plow [Re: PrimitiveJunk] #4600156
12/10/17 08:12 PM
12/10/17 08:12 PM
Port Orange, Florida
Panzerman Offline
Panzerman  Offline
My dad always ran 10w30 in his old wheel horses plowing and blowing snow in zero weather in PA. Never a issue in the Kohler motors. All this 0 Weight oil is hype. 10w30 would be fine. That's a simple motor.
2006 Dodge Ram 2500 Hemi 4x4
2016 Dodge Challenger Scat Pack
Re: Oil recommendation for old garden tractor on plow [Re: PrimitiveJunk] #4600171
12/10/17 08:34 PM
12/10/17 08:34 PM
Campbellsville, KY
Alex_V Offline
Alex_V  Offline
Campbellsville, KY
The K series Kohler is a tough engine that will live a long life on conventional oil. I ran SAE 30 in mine year-round, but most of the hours were accrued mowing in the summer. I'd use a syn blend 10w30 in winter.
To quote a friend, "Synthetics, man."
'85 GMC C3500, 454, 132K
'82 Mercedes 300CD, OM617 turbo, 173K (totaled 2018, in rehab)
'85 Mercedes 300TD, OM617 turbo, 217K (wife's)
'67 Suburban, 350, 331K
Re: Oil recommendation for old garden tractor on plow [Re: PrimitiveJunk] #4600224
12/10/17 09:42 PM
12/10/17 09:42 PM
OBX & Central FL
NormanBuntz Offline
NormanBuntz  Offline
OBX & Central FL
If it's like the Wheel Horse 310-8 tractor I had for 19 years with a Kohler 10 HP, it was made to run on conventional oil. I'd use a solid 10w-30 and just keep a close eye on your oil level, because it will use oil. I'd say you don't want to start that thing at 0-20 degrees with a straight 30.
2017 Honda Odyssey SE, 18K
2013 Honda Accord LX, 59K
2007 Honda Ridgeline RTS, 89K
2007 Infiniti M35, 107K
Re: Oil recommendation for old garden tractor on plow [Re: PrimitiveJunk] #4600233
12/10/17 09:54 PM
12/10/17 09:54 PM
West chicagoland
West chicagoland
How comfortable would everyone be using oil that's like 14.5 cst instead of the recommended 12.5 cst? In a winter application like this?
I'd really like to use my 5w40 T6 I'm really just not sure how significant this viscosity difference is.
I know these are tough motors. I know that it's pretty hard to kill them. LoL. When I bought this tractor, it consumed a pint of oil every 15 minutes of operation. I'm just hoping to get 1200 hours out of it, and if it locks on me, it'll really ruin my winter.
It took me well over a quart to mow my yard.
Ran it like that for about 75 hours. LoL.
Wasted alot of oil. Fogged a lot of mosquitos.
Re: Oil recommendation for old garden tractor on plow [Re: PrimitiveJunk] #4600266
12/10/17 10:40 PM
12/10/17 10:40 PM
Campbellsville, KY
Alex_V Offline
Alex_V  Offline
Campbellsville, KY
If you're worried about extended oil starvation I don't see how a 5w40 is going to be much different than a 10w30. However I'd never personally put 5w30 in such an engine. While I didn't put many hours on my K321 in severe cold (maybe a few dozen) I've plowed quite a bit with a Briggs 23CFB (9 HP flat head, side shaft) with straight 30 in the sump and it hasn't hurt it... but then again, I dunno what would.
My K321 used nearly no oil.
Re: Oil recommendation for old garden tractor on plow [Re: Alex_V] #4600280
12/10/17 11:22 PM
12/10/17 11:22 PM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
Yes, and it was designed almost 70 years ago.
ANY oil that serves modern autos will be fine.
5W-40 will not be "too thick" for that engine for winter snowblowing.
Re: Oil recommendation for old garden tractor on plow [Re: PrimitiveJunk] #4600282
12/10/17 11:25 PM
12/10/17 11:25 PM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
Just:
1) Never start at full throttle. That's just plain ol' stupid.
2) do NOT over-choke it. Once it starts, let it breathe!
Use only just as much choke as needed to keep it running - NO MORE.
3) Let it warm up slowly before putting it to work.
Re: Oil recommendation for old garden tractor on plow [Re: PrimitiveJunk] #4600312
12/11/17 12:06 AM
12/11/17 12:06 AM
Panzerman Offline
Panzerman  Offline
If that engine was using that much oil I would put 15w40 in it or straight weight. I would not being worried about cold starts. If that engine uses that much oil to mow the grass it has plenty of clearance between moving parts.
Re: Oil recommendation for old garden tractor on plow [Re: PrimitiveJunk] #4600362
12/11/17 05:35 AM
12/11/17 05:35 AM
Indiana
dlundblad Offline
dlundblad  Offline
Indiana
I have an old 1965-ish Wheelhorse Charger 12 with (I think) a similar engine. Just curious, why the rebuild? Also, why do you have the 1 pint of consumption every 15 mins?
Castrol 0w40 is nearly identical to GC 0w30. If that's what you want, get it. Honestly, you're not going to kill anything with a 15w40 though. Given the consumption, that is what I'd use.
I'd look into fixing the oil leak too.
03 Jeep WJ 4.0 202k Edge 10w40 HM Fram XG16
02 Volvo S60 2.4T 186k M1 0w40 Mahle OX149D
97 Chevy Blazer 4.3 153k Synpower 5w30 Supertech ST3980 (Ecore)
Re: Oil recommendation for old garden tractor on plow [Re: dlundblad] #4600366
12/11/17 05:51 AM
12/11/17 05:51 AM
Lima, Ohio, USA
earlyre Offline
earlyre  Offline
Lima, Ohio, USA
you kind of answered your own question(i think, if i read it right...)
that consumption was when op first bought it, and has been rebuilt since.
Mine:
13 Ford C-MAX hybrid: MC 5w20, & FL910s (in theory)
Re: Oil recommendation for old garden tractor on plow [Re: Panzerman] #4600381
12/11/17 06:31 AM
12/11/17 06:31 AM
Pennsylvania
Slick17601 Offline
Slick17601  Offline
Pennsylvania
+1
2018 RAM Bighorn 5.7
2008 Toyota Sienna 3.5
