Bought an old horizontal/vertical metal band saw of unknown make, likely pretty old, seems to run good now. It was a mess, but I took it mostly apart, cleaned and lubed, reassembled, adjusted as best as I could figure out, and it cuts real well, square to well inside of 1/32".
Only problem is on thin wall tube sometimes the blade will stop. It's a fairly fine tooth blade. I suppose it could have something to do with metal wheels on metal blade, maybe this is to be expected. On thicker material it cuts very smooth.
I tensioned the blade as much as seemed prudent with the hand wheel,it used to stop a lot, now it hangs up only on 1/16" material just as it enters the vertical component of the square tube. So now I'm wondering, how tight is tight enough and how tight is too much on that blade?
