And They Say Spelling is Not Important.
by PimTac. 09/22/18 12:06 PM
Toyota Genuine oil 10W30
by gordond. 09/22/18 09:27 AM
Good Dealers
by HowAboutThis. 09/22/18 09:12 AM
electric brakes rely on heat to work?
by motor_oil_madman. 09/22/18 09:09 AM
help please 7.25 briggs idle too fast
by edwardh1. 09/22/18 08:49 AM
Java update and Flash not working
by JLTD. 09/22/18 08:47 AM
Bought a Giulia
by RamFan. 09/22/18 08:38 AM
by gordond. 09/22/18 08:37 AM
Mobil 1 Extended Protection High Mileage Test
by njohnson. 09/22/18 07:57 AM
WPA 3 Wireless Security Coming
by StevieC. 09/22/18 01:16 AM
Robo Calls/Telemarketers
by Nick1994. 09/22/18 12:47 AM
What oil should be used!
by BigShug681. 09/22/18 12:28 AM
VW Electronic Parking Brake
by StevieC. 09/21/18 11:48 PM
Leak Sealing and Mould Treatments?
by Ducked. 09/21/18 11:44 PM
UPS / FedEx / USPS
by StevieC. 09/21/18 11:21 PM
puncture repair question
by neo3. 09/21/18 10:55 PM
Can I use a 10 amp extension cord for...
by gregk24. 09/21/18 10:48 PM
Sarrge, Big_R, gordond, mrgreggn, JRMFt11
66040 Registered Users
51 registered members (BAJA_05, 4WD, Anduril, 53' Stude, BrianF, BigCahuna, 3 invisible), 1,905 guests, and 32 spiders.
Topics290,821
Posts4,851,009
Members66,040
Most Online3,590
Jan 24th, 2017
Parker 3-micron hydraulic filter cut open #4599379
12/09/17 09:48 PM
12/09/17 09:48 PM
Fort Lauderdale, FL
DoubleWasp Offline OP
Fort Lauderdale, FL
This filter went through 12000 miles service on my Ram's 68RFE transmission. I kept it short on Parker's advice to make the first use of this filter a short one, since it's cleaning out a system never equipped with filtration this fine. Probably unnecessary as it went in with new trans fluid on a complete fluid exchange (cooler line method) and this filter is designed for much larger systems with much higher flow rates than the 68RFE.
I put eight 95 lb. magnets in the pan at the same time.
This filter is in the cooler line before the transmission cooler. The return line goes into a spin-on cooler return line filter mounted inside of the pan from the factory. I replaced the factory spin-on return line filter with a Fram Ultra XG7317, so my trans gets filtered both ways.
I opened this filter using a hacksaw, which would explain metal shavings. Made a bit of a mess.
No ADBV or bypass on this filter. Bypass is in the filter head.
Re: Parker 3-micron hydraulic filter cut open [Re: DoubleWasp] #4599388
12/09/17 09:59 PM
12/09/17 09:59 PM
Fort Worth, Texas
clinebarger Offline
clinebarger  Offline
Fort Worth, Texas
Thanks for the post, I really like Parker/Racor filters!
2001 Chevy Camaro L92/4L80E
2010 Toyota Corolla 2ZR-FE/Auto
Re: Parker 3-micron hydraulic filter cut open [Re: DoubleWasp] #4599456
12/10/17 12:13 AM
12/10/17 12:13 AM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
What oil filter part number?
Re: Parker 3-micron hydraulic filter cut open [Re: DoubleWasp] #4599696
12/10/17 10:19 AM
12/10/17 10:19 AM
Alberta
tcp71 Offline
tcp71  Offline
Alberta
I foresee a transmission that will outlast the rest of the vehicle.
2016 F150 Eco: Edge 0w40
2005 Sienna 3.3: mobil 0w40 (varies)
Re: Parker 3-micron hydraulic filter cut open [Re: DoubleWasp] #4600346
12/11/17 02:02 AM
12/11/17 02:02 AM
Fort Lauderdale, FL
Fort Lauderdale, FL
4ZC91
Seems to be doing well. Last thing I need to do is get my under-bed transmission cooler installed.
Re: Parker 3-micron hydraulic filter cut open [Re: DoubleWasp] #4600474
12/11/17 09:14 AM
12/11/17 09:14 AM
Southeast
meep Offline
meep  Offline
Southeast
nice work. I'd think you could let the next filter stay there for 30k or more. My first external filter looked about the same after 15k.
2018 F150
2015 crv (wifey!)
Re: Parker 3-micron hydraulic filter cut open [Re: DoubleWasp] #4600968
12/11/17 08:01 PM
12/11/17 08:01 PM
Fort Lauderdale, FL
Fort Lauderdale, FL
For sure. I was a little spooked by their "50 hours on first use" recommendation, but that might be accurate for the much larger and higher flowing systems this filter was designed for. This is a 20GPM filter. That's massive for a transmission of this size and use.
Got a nice stack of magnets today that I'm going to toss down the center tube.
Re: Parker 3-micron hydraulic filter cut open [Re: DoubleWasp] #4601154
12/12/17 12:03 AM
12/12/17 12:03 AM
Ontario, Canada
StevieC Offline
StevieC  Offline
Ontario, Canada
Are these really needed though? My Santa Fe went 300K miles with just fluid changes and it has no replaceable filter and the pan isn't removed for the change, just a plug to drain the oil. shrug
I mean sure it's an older type Ford transmission from the 1990's Tauruses sure but modern transmissions?
'18 Highlander - AMSOIL SS 0w20 / ATF / Severe Gear
'06 Santa Fe - 535,000km AMSOIL SS 0w30 / ATF (R.I.P)
Re: Parker 3-micron hydraulic filter cut open [Re: DoubleWasp] #4601198
12/12/17 02:28 AM
12/12/17 02:28 AM
Fort Lauderdale, FL
Fort Lauderdale, FL
Needed? No. Will it help? Likely.
Almost everything with a motor and trans at my warehouse has a large spin on transmission filter, so I decided to give this one a leg-up too. Also, it routinely tows 10-22K lbs.
Re: Parker 3-micron hydraulic filter cut open [Re: tcp71] #4601800
12/12/17 04:56 PM
12/12/17 04:56 PM
Idaho
CT8 Offline
CT8  Offline
Idaho
Unless something breaks.
2015 Ford F150 2.7
2018 Ford F350 6.2
Re: Parker 3-micron hydraulic filter cut open [Re: DoubleWasp] #4601835
12/12/17 05:39 PM
12/12/17 05:39 PM
Fort Lauderdale, FL
Fort Lauderdale, FL
68RFE's rarely break parts. Wearing out 5-6 gear clutches and valve body issues are another matter entirely.
I had to replace the solenoid pack in this transmission due to absolutely nothing but contamination. The solenoids are very sensitive to that. That's my #1 reason for having this filter. Less stuff running around, less chance of ending up in limp-home over a solenoid pack issue.
Re: Parker 3-micron hydraulic filter cut open [Re: DoubleWasp] #4602194
12/12/17 11:14 PM
12/12/17 11:14 PM
Central Washington
Colt45ws Offline
Colt45ws  Offline
Central Washington
Nice thing is if the trans ever does for some reason blow up, you can save buying a new transmssion cooler, since it wouldve captured anything going out to the cooler. The money savings there would pay for many of these filters Im sure.
-Colton
2002 Ford Crown Vic PI 207k, Ex-Kootenai County, ID Unit #42
Down for engine swap
2003 Ford Crown Vic PI 75k
Castrol EDGE HM 5W30, Fram XG2
Re: Parker 3-micron hydraulic filter cut open [Re: DoubleWasp] #4602240
12/13/17 02:21 AM
12/13/17 02:21 AM
Fort Lauderdale, FL
Fort Lauderdale, FL
Depends on the failure. I've seen transmissions go hundreds of miles ejecting shards of metal. Only thing that even brought it to attention was overheating due to the cooler becoming plugged. In such a case, the filter will plug, bypass, and then it keeps going.
What I do need to do is take advantage of the ports in the filter head and install a pressure differential gauge. Then, I'll know exactly when to change a filter, and if there is a problem.
Re: Parker 3-micron hydraulic filter cut open [Re: DoubleWasp] #4605823
12/16/17 09:45 PM
12/16/17 09:45 PM
Idaho
CT8 Offline
CT8  Offline
Idaho
There is lots of metal being made when new.
2015 Ford F150 2.7
2018 Ford F350 6.2
Re: Parker 3-micron hydraulic filter cut open [Re: DoubleWasp] #4607830
12/19/17 03:40 AM
12/19/17 03:40 AM
Fort Lauderdale, FL
Fort Lauderdale, FL
Made one error. This is a 50GPM filter, not 20GPM.
