Plasti Diping my OEM rims question
by dblshock. 03/24/19 07:53 AM
"The new" Mobil 1 Racing Oil ?
by lawnguy. 03/24/19 06:32 AM
Arlen Ness passes
by 02SE. 03/24/19 03:15 AM
Plants - they learn and remember
by Shannow. 03/24/19 03:02 AM
Rotella Gas Truck
by jpstiles02. 03/24/19 02:53 AM
The case for quitting Facebook
by StevieC. 03/23/19 11:21 PM
Mixing Toyota Spec'ed 0w20 & 5w20
by David2431. 03/23/19 09:59 PM
Run old DOS games on your Wii
by StevieC. 03/23/19 09:51 PM
Live in PA? Need a car? Want something UNIQUE?
by 14Accent. 03/23/19 09:33 PM
Painting plastic
by HangFire. 03/23/19 09:27 PM
Rav4 vs Forester
by fdcg27. 03/23/19 09:07 PM
cleanser stain on cylinder liners
by neo3. 03/23/19 09:06 PM
Electronics and DC Voltage Question
by maverickfhs. 03/23/19 08:39 PM
Oil Change Tips for the Newbie
by StevieC. 03/23/19 08:39 PM
DashCams
by Eddie. 03/23/19 08:07 PM
Rough idle... Only in drive
by nicholas. 03/23/19 07:02 PM
Using synthetic blend or full synthetic oil
by FixItDad28. 03/23/19 07:01 PM
GSXRBullwinkie, Mark1970, FixItDad28, RandomJoe, Sciascia
67599 Registered Users
61 registered members (A1O, arowbat, aloe2018, AdditiveOCD, ARB1977, aircooled, 8 invisible), 1,391 guests, and 55 spiders.
Topics286,321
Posts4,906,384
Members67,599
Most Online2,967
Mar 10th, 2019
Parasound Back On-line #4599374
12/09/17 09:36 PM
12/09/17 09:36 PM
Central Texas
sleddriver Offline OP
Central Texas
A few years back, I noticed some increasingly LOUD buzzing from my surround sound set-up. One cause was the surround sound controller itself, the Citation 7. That reworking process was documented here several years back. Since the Citation 7 has been restored to service, it's worked perfectly ever since.
I peaked under to hood of the Parasound multi-channel amp and noticed the majority of the main PS caps were bulging. Well that's not good. So I removed it from service, ordered new caps with a higher Voltage rating, then began to disassemble the rectifier/filter board, replace the main caps and reassemble.
Here's one photo I found. Looking for the others. I discovered my disassembly notes while cleaning up the servicing bench, properly ordered the wiring, found the hardware and looking forward to getting it back on-line. This photo shows the height difference between the OEM 65V caps and the newer 80Vs. All six were replaced.
Recently had an unrelated problem with the HP amp cutting out. Thought perhaps the electrolytic caps in the DC protection ckt were out-of-spec. Then while listening last week, heard a faint 'crack' while one channel of the LP amp went silent.
So I dug into it last weekend and discovered a loose power switch and a loose bass level control on the custom active EQ/XO I built. I retightened, then checked by playing the cannon shot scene from "Master & Commander". No cut outs! Success!
Evidently the stereo control had become loose and vibration was sufficient to short the control wiring. This was the fault rather than the HP amp's DC protection ckt.
Sure makes a difference with respect to presence, depth, and spaciousness when BOTH subwoofers are functional. Each cabinet has a pair of 12" drivers. With both working, I'm back to four 12" drivers once again.
The cannons sound great!
1998 Volvo V70 T5 228,880 mi. Original Owner.
M1 10W-30 HM
"It's never a mistake to buy tools, defined broadly. They're not a cost, they're an investment." - J.B. Peterson
Re: Parasound Back On-line [Re: sleddriver] #4599493
12/10/17 02:24 AM
12/10/17 02:24 AM
Maryland USA
rubberchicken Offline
Maryland USA
Master and Commander: One of the finest movies ever ! What makes capacitors go bad ? This is a common problem on older PC motherboards.
Re: Parasound Back On-line [Re: sleddriver] #4599515
12/10/17 05:04 AM
12/10/17 05:04 AM
Deutschland
Motor_Boater Offline
Deutschland
Originally Posted By: sleddriver
...noticed the majority of the main PS caps were bulging... ...perhaps the electrolytic caps in the DC protection ckt were out-of-spec...
The electrolyte simply evaporates out. 20 years longevity is usually the max. I repaired the control board of my wash machine myself, following a youtube vid. The factory wanted a few hundred for a replacement board. I then replaced the offending 2 caps for only 1.15. You can just about repair any board inexpensively, as long as the programmable chip doesn't fail. As you see, none of the caps bloated yet. So, I had to run a test outside of the machine, heating up the chip with a hair dryer, to get the drum to spin:
Re: Parasound Back On-line [Re: rubberchicken] #4599826
12/10/17 12:49 PM
12/10/17 12:49 PM
Central Texas
Central Texas
Yes it is. Being a sailor and loving boats, it's one of my favorites.
Electrolytic capacitors in particular are the type that experience problems with aging. Reason being they use electrolytic paste inside rather than a plastic film. Over time, this paste will slowly dry out, lowering the EC's value, meaning it no longer acts like a good capacitor. The internal AC impedence will also rise, which causes it to heat up. Over time this either dries/cooks the electrolite, causing the casing to expand or causing it to be vented externally.
Some ckts have local power filtering around them for stability; some don't. Once formerly steady DC voltage now has AC ripple mixed into it, causing power fluctuations, and noise to be fed into all other ckts.
Like batteries, the quality of EC's varies widely.
M1 10W-30 HM
Re: Parasound Back On-line [Re: sleddriver] #4599866
12/10/17 02:04 PM
12/10/17 02:04 PM
dayton oh
kc8adu Offline
kc8adu  Offline
dayton oh
and even higher priced equipment tends to use garbage lytics.
do i see a group of lytics on the left board standing off the board by their leads?
very bad on things like a sub amp.they break off due to vibration.
and a sub by design creates lots of low freq vibration!
i see plenty of this sort of failure on industrial controls.
a common brand of cnc control often comes to me with caps rolling around in the case.
you think the designer would know better!
a blop of high temp hot glue would have prevented this.
Re: Parasound Back On-line [Re: kc8adu] #4599904
12/10/17 03:00 PM
12/10/17 03:00 PM
Central Texas
Central Texas
Good eye. They are indeed floating above the pcb to make room for a tiny, small capacitance bypass cap. Solved a spring/mass problem producing a bad harmonic a few years ago in a loudspeaker woofer. Very puzzling until I saw it for what it was...
I concur this isn't good practice at all. Obviously they didn't want to put the small bypass caps on the opposite side of the board.
This isn't a sub amp though. Not connected to any cabinet. It powers the center spkr and both rear surrounds. 6ch's are bridged to three.
M1 10W-30 HM
Re: Parasound Back On-line [Re: sleddriver] #4600228
12/10/17 09:47 PM
12/10/17 09:47 PM
Central Texas
Central Texas
Found the older photos I took before pulling the filter board out:
From this perspective, it's easy to see three of the EC's with bulging lids:
Here's another angle:
M1 10W-30 HM
Re: Parasound Back On-line [Re: sleddriver] #4600928
12/11/17 07:06 PM
12/11/17 07:06 PM
dayton oh
kc8adu Offline
kc8adu  Offline
dayton oh
3 of them had open vents poking the plastic.
the higher voltage caps being a larger can means lower esr.
translates to lower ripple.
good job!
Re: Parasound Back On-line [Re: kc8adu] #4601057
12/11/17 09:43 PM
12/11/17 09:43 PM
Central Texas
Central Texas
  • I recently acquired a used ESR meter. I'll check each cap and report back.
  • I generally go with a higher V cap for that very reason...as long as they'll fit.
  • Lower ripple is always a good thing!
  • Thanks.
  • BTW, I'm interested in your flashlight hot-rodding. Have a few old Mag-lites laying around.
M1 10W-30 HM
Re: Parasound Back On-line [Re: sleddriver] #4602224
12/13/17 12:41 AM
12/13/17 12:41 AM
Maryland USA
Maryland USA
On the EC pics: thanks for pointing out the bulge- I would not have recognized that as being a problem: usually the caps I look at have silver tops with lines stamped in, so the bulge would be more noticeable.
Re: Parasound Back On-line [Re: rubberchicken] #4602574
12/13/17 02:12 PM
12/13/17 02:12 PM
Central Texas
Central Texas
You're welcome RC.
The EC's you're referring to are a different type & construction, if I understand your description correctly.
M1 10W-30 HM
Re: Parasound Back On-line [Re: sleddriver] #4632914
01/12/18 09:04 PM
01/12/18 09:04 PM
FL
Clausen Offline
Clausen  Offline
FL
Hi. I have this same amp and I had to replace all the relays in it, which I did myself. I also have a hum that is especially noticeable if I turn up the gains. I was wondering what uf value these caps are and where to get them. It looks like in the picture they are 12,000 uf but it's hard to tell from that!
Thanks for this post!
BTW, is this the HCA-806a? I thought it said it was somewhere.
Re: Parasound Back On-line [Re: Clausen] #4633854
01/13/18 06:10 PM
01/13/18 06:10 PM
Central Texas
Central Texas
The originals are Elna LP5, 12,000uF 63V cans. I bought similar uF from Mouser, going with 80Vdc. 60Hz Hum & buzz are good signs caps are mis-behaving due to age.
M1 10W-30 HM
Re: Parasound Back On-line [Re: sleddriver] #4634027
01/13/18 10:09 PM
01/13/18 10:09 PM
FL
Clausen Offline
Clausen  Offline
FL
OK...yeah that's where I bought the relays from,(Mouser). I'll crack it open to see what's there I guess, just being lazy. This is a huge relief for me though! I really like this amp. Its driving these...http://www.diyaudio.com/forums/multi-way/97043-elsinore-project-thread-203.html
Thanks again!
Re: Parasound Back On-line [Re: sleddriver] #4664366
02/12/18 10:33 PM
02/12/18 10:33 PM
Central Texas
Central Texas
Update:
Last night I worked out a few installation bugs, set up the SLM and leveled all the spkrs., then watched Master & Commander, then Rush.
Having a center again indeed makes a difference as the vocals are solidly anchored front & center. Never had any problem hearing them in 2ch mode due to the excellent resolution and focus of the Scandinavian SEAS drivers in the FL & FR. In surround mode, the mono signal is removed from these two and combined and restricted to center.
The surrounds do indeed fill in the side/back and are located at about 4 and 7 on the clock. It's been far longer than I remembered having all of this working. Life happens and interrupts.
The cap replacement has resulted in dead quiet from all six channels, even at full volume. No hum, no buzz, no noise....just dead quiet.
I also took the Moto-tool to a bulged cap. Rather suprised just how thick the aluminum walls were. Far more stout than I thought. The 'electrolytic roll' was not completely dried out, however there was a dark red/brown liquid in the bottom that smelled a bit burnt. For this cap to actually vent, quite a lot of pressure would have to develop internally. It only made it doming the top.
I'll post some photos later.
M1 10W-30 HM
