Mobil Delvac 1 ESP 5w40 $23.65 at Walmart
by 71Chevyguy
06/23/18 04:36 PM
diesel oil in older engines- RE: cats etc
by 928
06/23/18 04:35 PM
2011 F-150 Ecoboost timing chain replacement
by 14Accent
06/23/18 04:31 PM
My stash of Kendall GT1 almost gone..
by Vern_in_IL
06/23/18 04:30 PM
mobil 1 rebate check
by Fitter30
06/23/18 03:52 PM
Cab mount failure
by ram_man
06/23/18 03:31 PM
02 Saab aero oil?
by Newuser
06/23/18 03:00 PM
Extend wifi range
by clarkflower
06/23/18 02:05 PM
Under valve cover pics 207,000 miles
by WobblyElvis
06/23/18 01:57 PM
Lease Buyout by Dealer
by Throt
06/23/18 01:52 PM
13 Ford Escape
by RedOak
06/23/18 01:10 PM
New washer pump leaking fluid
by llmercll
06/23/18 12:17 PM
Fuel dilution and CCS/MRV viscosity
by doyall
06/23/18 12:10 PM
Door Hinges
by Scrum67
06/23/18 11:59 AM
PBS, TV channels in different countries
by onetwoothreee
06/23/18 11:29 AM
Break in filter cut open/ Filtermag
by UncleDave
06/23/18 10:36 AM
Changed coil pack, now throwing cat code
by llmercll
06/23/18 10:36 AM
07 V6 Mustang oil leak.
by aquariuscsm
06/23/18 10:33 AM
Windows 10 Update, version 1803
by Sayjac
06/23/18 09:55 AM
Super Tech Euro Spec Synthetic
by Snagglefoot
06/23/18 09:48 AM
bwechols, bowupid, pod423, lemaitrix, azzid0906
65303 Registered Users
86 registered (2015_PSD, 928, 71Chevyguy, 1JZ_E46, 14Accent, 9 invisible), 1552 Guests and 46 Spiders online.
65303 Members
67 Forums
285863 Topics
#4599373 - 12/09/17 08:33 PM Fleetguard LF9028 Dual Flow Cut Open
DoubleWasp Offline
Loc: Fort Lauderdale, FL
Finally had a chance to cut one of these open. All media damage/distortion is due to my poor cutting and handling methods. Going to remember to order a filter cutter.
This filter has two filters in one: A standard Stratapore Venturi filter, and also a "stacked disc" bypass media section that filters to below 2-microns according to Cummins Filtration.
This filters was run for one single 27,800 mile OCI. Being a diesel filter, it is of course blacker than the darkest night.
#4599453 - 12/09/17 11:04 PM Re: Fleetguard LF9028 Dual Flow Cut Open [Re: DoubleWasp]
Linctex Offline
Loc: Waco, TX
I would LOVE to see the assembly process on one of these!
#4599700 - 12/10/17 09:22 AM Re: Fleetguard LF9028 Dual Flow Cut Open [Re: DoubleWasp]
Bighorn2500 Offline
Loc: Michigan, USA
Thatís what Iíve been waiting to see, stacked disc looks like it worked well
2012 Ram 2500 SLT 6.7L Cummins 4x4
2015 Jeep Cherokee 3.2L Latitude 4x4
#4599749 - 12/10/17 10:22 AM Re: Fleetguard LF9028 Dual Flow Cut Open [Re: DoubleWasp]
bullwinkle Offline
Loc: Cincinnati, OH, USA
Any chance of a UOA or a particle count from your oil on this one? I run these on my Ram, but it would take 6 years for me to get 30K on mine.
06 Ram 3500 CTD 4X4(FG Venturi), 93 GMC C3500 6.2, 89 F-450 7.3, 98 XJ 4.0(XG8A), 05 xB(XG3600), 15 Transit 3.7, 03 Merc Grand Marquis 4.6 2V(XG2)
#4599810 - 12/10/17 11:31 AM Re: Fleetguard LF9028 Dual Flow Cut Open [Re: DoubleWasp]
PiperOne Offline
Loc: A Highway Near You
Thanks for posting! If you want a really nice filter cutter, the one from Fleetguard is very good. Will do filters from 1" up to 6+" in diameter and is nicely balanced. Fleetguard part# 3310587S
Edited by PiperOne (12/10/17 11:35 AM)
HDEO in Diesel Engines. No spark plugs here.
#4599817 - 12/10/17 11:39 AM Re: Fleetguard LF9028 Dual Flow Cut Open [Re: PiperOne]
JohnnyJohnson Offline
Loc: Wet side WA
LOL and for that price it should clean the house and do dinner once a week!
2004 Toyota Corolla 121790
Out: QSUD 5W-30 Purolator One 5030
In: Valvoline ML 5w-30 TG4967 117530 2-8-18
2006 Duramax 74047
Out: T6 5W-40 M1-303
In: T6 5W-40 XG9100 73752 4-22-18
#4599850 - 12/10/17 12:31 PM Re: Fleetguard LF9028 Dual Flow Cut Open [Re: DoubleWasp]
Bighorn2500 Offline
Loc: Michigan, USA
With 27k miles on the change Iím guessing the Ram is deleted?
What oil was changed out that went that far?
Iíve had good results with the Donaldson DBL7349 but have been eyeing the LF9028 as well with reasonable pricing online.
#4599997 - 12/10/17 03:35 PM Re: Fleetguard LF9028 Dual Flow Cut Open [Re: JohnnyJohnson]
PiperOne Offline
How much were they? I got mine for free (fleet level filter usage though).
#4600021 - 12/10/17 03:55 PM Re: Fleetguard LF9028 Dual Flow Cut Open [Re: PiperOne]
Loc: Wet side WA
Amazon nearly $270.
2006 Duramax 74047
#4600343 - 12/11/17 12:53 AM Re: Fleetguard LF9028 Dual Flow Cut Open [Re: bullwinkle]
DoubleWasp Offline
My UOA is here: https://bobistheoilguy.com/forums/ubbthreads.php/topics/4491133/2007.5_Ram_Cummins_6.7,_26k_mi#Post4491133
Was actually closer to 27k miles. My mistake.
No particle count. Next time.
Quote:
. With 27k miles on the change Iím guessing the Ram is deleted?
Yes, deleted. Schaeffer's CJ4 15w/40 semi-syn.
I've gone back and forth with both filters as evidenced by my failure to update my Sig.
I might just pull the trigger on that high ticket filter cutter. Have plenty I'd like to do.
