Should i go for even thinner fluid ?
by NICAT. 12/18/18 11:06 AM
Viscosity question
by dbierman. 12/18/18 10:50 AM
48 hours and a used car
by Imp4. 12/18/18 09:32 AM
Test driving PHEV w no battery charge
by RichardS. 12/18/18 09:02 AM
2005 Ford PSD with hard shifts when cold?
by racin4ds. 12/18/18 08:08 AM
18% off Ravenol + EVERYTHING @ Blauparts.com
by CleverUserName. 12/18/18 07:48 AM
Mattress shopping .....
by dblshock. 12/18/18 04:57 AM
AmazonBasics Oil May Drive Prices Down
by knerml. 12/18/18 04:45 AM
Hemi MDS issues are how common?
by Gasbuggy. 12/18/18 03:21 AM
Why use Redline and Redline Clone oils...
by burla. 12/17/18 11:38 PM
Tire choice
by CincyReds. 12/17/18 11:14 PM
Transmission fluid leak
by dawgn86. 12/17/18 07:53 PM
QuickJack BL-5000SLX and my Optima...
by WhizkidTN. 12/17/18 07:23 PM
Champion Air Filter Opinions?
by JerryBob. 12/17/18 06:18 PM
Tundra transfer case plug torque (Borg Warner)
by Idlewild294. 12/17/18 06:03 PM
Winter tire question?
by Muskieteer. 12/17/18 05:31 PM
Who makes good ball joints these days?
by GSCJR. 12/17/18 04:51 PM
MuhThugga, wxo, dbierman, keyblade, leeal
66716 Registered Users
92 registered members (69Torino, 66Monza, 28oz, 2K2AcuraTL, Ag76, Aero540T, 8 invisible), 1,994 guests, and 42 spiders.
Topics295,216
Posts4,930,201
Members66,716
Most Online2,553
Oct 27th, 2018
Fuel Dilution - FAQ #4599227
12/09/17 05:44 PM
12/09/17 05:44 PM
ON, Canada eh?
StevieC Offline OP
StevieC  Offline OP
ON, Canada eh?
LOL
'18 Dodge Grand Caravan GT - AMSOIL SS 5w20
'06 Santa Fe - 535,000km AMSOIL SS 0w30 / ATF
Re: Fuel Dilution - FAQ [Re: StevieC] #4599371
12/09/17 08:30 PM
12/09/17 08:30 PM
Taiwan
Ducked Offline
Ducked  Offline
Taiwan
Goes on a bit.
(fuel dilution) "is why the service interval has a time limit as well as a mileage limit" (probably not an exact quote but close enough) doesn't appear to make sense.
Re: Fuel Dilution - FAQ [Re: StevieC] #4599386
12/09/17 08:56 PM
12/09/17 08:56 PM
ON, Canada eh?
StevieC Offline OP
StevieC  Offline OP
ON, Canada eh?
Excessive idling / stop-go traffic. Low miles but high fuel dilution because of lots of injection cycles and/or low temps not heating the oil enough to evaporate some of the fuel.
Re: Fuel Dilution - FAQ [Re: StevieC] #4599393
12/09/17 09:14 PM
12/09/17 09:14 PM
Taiwan
Ducked Offline
Ducked  Offline
Taiwan
I dunno. Are low miles necessarily, or even generally, slow miles?
I was thinking of my own situation, where the car is mostly recreational use so infrequent but gets up to temperature when it is used.
Re: Fuel Dilution - FAQ [Re: StevieC] #4599420
12/09/17 10:00 PM
12/09/17 10:00 PM
ON, Canada eh?
StevieC Offline OP
StevieC  Offline OP
ON, Canada eh?
It really depends on what temperature the oil reaches and for how long to help evaporate the contaminants. Then if it spends more time idling than actually moving then that is a factor as well as my first point. grin2
Re: Fuel Dilution - FAQ [Re: StevieC] #4599433
12/09/17 10:26 PM
12/09/17 10:26 PM
PNW
ZeeOSix Offline
ZeeOSix  Offline
PNW
That guy's a bit "snotty" ... LOL Guess he thinks that gets subscribers.
Re: Fuel Dilution - FAQ [Re: StevieC] #4599671
12/10/17 09:00 AM
12/10/17 09:00 AM
ON, Canada eh?
StevieC Offline OP
StevieC  Offline OP
ON, Canada eh?
He is cranky for sure.... grin2
Re: Fuel Dilution - FAQ [Re: StevieC] #4599711
12/10/17 09:35 AM
12/10/17 09:35 AM
Texas & Global
4WD Offline
4WD  Offline
Texas & Global
I could not even finish ~ donít think Iíd send him a question and then sit and hear it mocked like a school boy Ö
2018 Chevy 1500 Z71 4WD
2017 Chevy Tahoe LT 4WD
2014 Fusion Hybrid Titanium
2013 Cruze LTZ - RS Turbo
Re: Fuel Dilution - FAQ [Re: StevieC] #4599737
12/10/17 10:06 AM
12/10/17 10:06 AM
Florida, Cape Coral
Eddie Online sleepy
Eddie  Online Sleepy
Florida, Cape Coral
I would like to see some REAL data that plots % fuel vs wear. Based on 5 or so UOAs I've seen showing fuel dilution of 1 to 3% I've observed no real increase in wear. I think some of us get paranoid over the idea of fuel dilution. Ed
CX5 Touring 2.5L :-)
Re: Fuel Dilution - FAQ [Re: StevieC] #4599772
12/10/17 10:48 AM
12/10/17 10:48 AM
Marshfield , MA
andyd Offline
andyd  Offline
Marshfield , MA
In the norm, from reading UOAs, fuel < 1%. Fuel dilution was a major deal with carbs and chokes. In a modern car, its a non-problem.
Thick oil is better grin2
Re: Fuel Dilution - FAQ [Re: andyd] #4599815
12/10/17 11:34 AM
12/10/17 11:34 AM
ON, Canada eh?
StevieC Offline OP
StevieC  Offline OP
ON, Canada eh?
I think lubricants have improved in this regard as well since then as well.
Re: Fuel Dilution - FAQ [Re: andyd] #4599855
12/10/17 12:46 PM
12/10/17 12:46 PM
Danh Offline
Danh  Offline
You're likely reading UOAs from Blackstone, which are not reliable for gauging fuel dilution. Look at Oil Analyzers/Polaris UOAs instead, which uses gas chromotography for this purpose. On Blackstone UOAs ignore fuel dilution and look at viscosity instead: you'll see lots of samples below or nearly below grade.
Fuel dilution is an issue withnDI/TGDI engines; the question is how harmful it is. But when you hear reports of increasing sump levels it can't be a non-problem.
Re: Fuel Dilution - FAQ [Re: Danh] #4600202
12/10/17 08:11 PM
12/10/17 08:11 PM
West Michigan
Balrog006 Online content
Balrog006  Online Content
West Michigan
Why not? Increasing to what level? Slight increases arenít any cause for concern-just like normal slight overfills arenít, but Iíve yet to see any pictures of major increases in overall sump volume reported here.
19 Ridgeline RTL-E >1K factory fill, A01
08 CRV 275K+ VSyn w/ML, A01
04 JD L130 740H, Mobil S 5w30
13 JD 2032r 325H, JD Plus 50 ii 15w40
M1Delvac 5w40 in OPE
