Hifly Hf 805
by chrisri. 12/15/18 10:00 AM
Preferred 5.3L L83 Oil Filter
by zfasts03. 12/15/18 09:58 AM
sonata plastic fork starter failed three times.
by JustinH. 12/15/18 09:17 AM
HVAC Problems
by WTJackalope. 12/15/18 09:15 AM
Rough Idle after short trip
by Datarock. 12/15/18 09:07 AM
Homelite 360
by mobilaltima. 12/15/18 09:04 AM
Lovin' the Etec!
by IndyFan. 12/15/18 06:10 AM
Air Impact Wrench
by BenZahel. 12/15/18 05:19 AM
Luber finer 750 bypass oil filter info
by BigRich954. 12/15/18 03:59 AM
Ford Pickup Front Wheel Bearings 2WD
by benjamming. 12/14/18 10:52 PM
GMC oil fill tube
by Redright9. 12/14/18 10:24 PM
Where do I buy Toto toilets? That has them!
by Vern_in_IL. 12/14/18 10:04 PM
Best filter cutter for the price?
by DONWATERS. 12/14/18 09:38 PM
5W-40 vs 10W-30 for a 2018 Audi A4
by jcr1293. 12/14/18 09:25 PM
Gave up on quadrajet electric choke today...
by leroyd92. 12/14/18 08:54 PM
2015 Odyssey - Which synthetic ATF?
by AngryScientist. 12/14/18 07:56 PM
Hyundai extended my warranty
by ernied. 12/14/18 07:33 PM
2016 Traverse 6350mi Schaeffers 9000 5W30
by chevman4life. 12/14/18 07:21 PM
Spkrdctr, torchredone12, JNG, Edmundo, NEKGuy
66688 Registered Users
92 registered members (4ever4d, 2002 Maxima SE, 4WD, 69GTX, aba4430, 8 invisible), 1,952 guests, and 38 spiders.
Topics295,103
Posts4,927,837
Members66,688
Most Online2,553
Oct 27th, 2018
08 lacrosse TRACTION CONTROL ISSUES #4598892
12/09/17 10:39 AM
12/09/17 10:39 AM
northeast
lucerne06 Offline OP
northeast
Have a very well cared for 08 lacrosse with 64,000 miles,,, a few weeks ago started noticing small shudder/hesitation when making tight turns, yesterday when making a u turn my traction control dash light comes on and my info center says SERVICE TRACTION CONTROL UNIT and SERVICE THEFT DETERANT UNIT. drove it home with then only the info panel saying service the traction control unit and cannot switch the traction control light off....ANY THOUGHTS or suggestions...is this something simple and not to expensive..? is a dealer visit in my future or a regular good mechanic can handle this...thanks in advance.
Re: 08 lacrosse TRACTION CONTROL ISSUES [Re: lucerne06] #4598903
12/09/17 10:56 AM
12/09/17 10:56 AM
Buffalo, NY
JTK Offline
JTK  Offline
Buffalo, NY
I'd guess it's a wheel speed sensor issue, but you'd need a scan with a more advanced scan tool to identify it.
2017 Ram 1500 4x4, 3.6L. 2016 Nissan Quest SV (Babe magnet IV)
Re: 08 lacrosse TRACTION CONTROL ISSUES [Re: lucerne06] #4598913
12/09/17 11:05 AM
12/09/17 11:05 AM
MN
TmanP Offline
TmanP  Offline
MN
I'd go to a trusted mechanic. I had a similar issue on mine, turns out I ran over some debris that cut the harness running to the wheel. Mine said "SERVICE TRACTION SYSTEM" and "SERVICE ABS SYSTEM" as well as lighting the ABS light and Traction Control off light. It wasn't too expensive of a repair. Good luck!
2012 Toyota Camry 2.5 30,000 mi
2015 Chevy Silverado LT Z71 5.3 V8 30,000 mi
2010 Toyota Sienna 3.5 V6 150,000 mi
Re: 08 lacrosse TRACTION CONTROL ISSUES [Re: JTK] #4598950
12/09/17 12:10 PM
12/09/17 12:10 PM
'murica
Ethan1 Offline
Ethan1  Offline
'murica
/thread
Re: 08 lacrosse TRACTION CONTROL ISSUES [Re: lucerne06] #4599047
12/09/17 02:17 PM
12/09/17 02:17 PM
New York Queens
Ram02 Offline
Ram02  Offline
New York Queens
Take it to the dealership it could be a module
2013 Malibu 2LT M1 5w30
2013 Accord Sport M1 AP 0w20
Re: 08 lacrosse TRACTION CONTROL ISSUES [Re: lucerne06] #4599058
12/09/17 02:26 PM
12/09/17 02:26 PM
ME
eljefino Offline
eljefino  Offline
ME
It would actually be cheaper if it were also an ABS issue as that would point to the commonality of a wheel speed sensor.
I'm afraid you have a module with scrambled brains, or solder failure, or bad capacitors, or...
Re: 08 lacrosse TRACTION CONTROL ISSUES [Re: eljefino] #4599109
12/09/17 03:19 PM
12/09/17 03:19 PM
northeast
northeast
about as helpful as [censored] on a bull, thanks
Re: 08 lacrosse TRACTION CONTROL ISSUES [Re: lucerne06] #4599138
12/09/17 03:53 PM
12/09/17 03:53 PM
'murica
Ethan1 Offline
Ethan1  Offline
'murica
So is your whole thread until you pull codes and start tracing wires thumbsup
Re: 08 lacrosse TRACTION CONTROL ISSUES [Re: lucerne06] #4599155
12/09/17 04:14 PM
12/09/17 04:14 PM
MA, Mittelfranken.de
Trav Offline
Trav  Offline
ABS light on?
Re: 08 lacrosse TRACTION CONTROL ISSUES [Re: lucerne06] #4599240
12/09/17 06:09 PM
12/09/17 06:09 PM
British Columbia, Canada
ecotourist Offline
ecotourist  Offline
A module might have gone too.
If it's expensive consider having your old one rebuilt. $300 for an ABS/Traction control module for my BMW at ModuleMaster, with a 5 year guarantee. The cost for a new one plus the usual 'this and that' would have been $1400 at my usual specialty repair shop. I replaced it myself. It took less than 5 minutes to remove it and less than 5 minutes to replace it. PS That service writer no longer works at the specialty shop. They now (and possibly even then) have them rebuilt as well.
2000 BMW 528i 5MT
2007 Honda Accord EX-L 4Door V6 6MT
Re: 08 lacrosse TRACTION CONTROL ISSUES [Re: lucerne06] #4599291
12/09/17 07:03 PM
12/09/17 07:03 PM
Clovis, CA
Merkava_4 Offline
Merkava_4  Offline
Clovis, CA
Sounds like an expensive fix for something that's totally unnecessary.
Re: 08 lacrosse TRACTION CONTROL ISSUES [Re: lucerne06] #4606642
12/17/17 08:12 PM
12/17/17 08:12 PM
northeast
northeast
the next day started it up, traction off control light is gone, have not had a single issue since, but today I did find a broken wire that goes to my brake fluid resivor...??? strange
Re: 08 lacrosse TRACTION CONTROL ISSUES [Re: lucerne06] #4606684
12/17/17 08:56 PM
12/17/17 08:56 PM
Phoenix
dishdude Offline
dishdude  Offline
Phoenix
Did it snow or anything the day you had the issue?
2018 Challenger SRT 392 PUP 0w-40 Wix 57899XP
2018 GTI
Re: 08 lacrosse TRACTION CONTROL ISSUES [Re: lucerne06] #4607219
12/18/17 12:25 PM
12/18/17 12:25 PM
Southeast
meep Offline
meep  Offline
Southeast
it sounds to me like the TC was actually working and the sharp U-Turn was tight and quick enough for it to try to brake the faster wheel. Its the same as tight cornering with braking can trigger ABS. Fancier systems should have a steering angle sensor so that the computer allows the turn or even biases to support it. A bad sensor could throw it off, but you need to pull codes for clues.
and, there might not be anything wrong. You may have just driven aggressively outside its expected parameters. I'd wait to see if it gets worse or the error comes back.
-m
2018 F150
2015 crv (wifey!)
Re: 08 lacrosse TRACTION CONTROL ISSUES [Re: dishdude] #4608636
12/19/17 07:06 PM
12/19/17 07:06 PM
northeast
northeast
actually a little ice and some wet leaves on the pavement
