Planes, smoke, pyrotechnics and lasers
by Shannow. 03/26/19 08:55 AM
Rust paint that works? Canada
by nobb. 03/26/19 07:19 AM
Synthetic motor oil in a gun
by Yuk. 03/26/19 01:07 AM
air suspension on a towed trailer?
by columnshift. 03/25/19 11:57 PM
AeroShell W100 SAE50 in Motorcycles?
by CCI. 03/25/19 11:02 PM
Spark plug torque when using anti-seize
by Reddy45. 03/25/19 10:58 PM
My kid is 8 now - use the front seat?
by y_p_w. 03/25/19 10:53 PM
2005 Pontiac GTO | 44,750 miles | 6-Speed
by Georgiey22. 03/25/19 10:39 PM
GWR Silencer Spray
by agpatel. 03/25/19 10:30 PM
Fuel line insulation to remedy vapor lock?
by motor_oil_madman. 03/25/19 10:22 PM
Running a fan to reduce humidity
by motor_oil_madman. 03/25/19 10:15 PM
stuck grease zerk on my JD tractor
by PaulH. 03/25/19 09:33 PM
S&W M&P 2.0 9MM Range Time
by 2015_PSD. 03/25/19 09:26 PM
Poor quality Ford wheel finish...
by gregk24. 03/25/19 09:12 PM
2013 GMC SIERRA PICKUPS
by Honda2003. 03/25/19 09:10 PM
Fighting HOA - anyone have any luck?
by pezzy669. 03/25/19 09:05 PM
bgm6881, machv5, freewayken, JustMatt, DCDMan
67626 Registered Users
93 registered members (ARCOgraphite, andyd, 2010Civic, Astro14, 11 invisible), 1,668 guests, and 71 spiders.
Topics286,446
Posts4,908,443
Members67,626
Most Online2,967
Mar 10th, 2019
QS HM oil info #4598759
12/09/17 08:42 AM
12/09/17 08:42 AM
Wichita, Kansas
vwalburn Offline OP
vwalburn  Offline OP
Wichita, Kansas
I see that Quaker State says that their HM oils have a boosted zinc package for more protection. Does anyone have any idea what they "boost" their zinc level to?
1996 Dodge Ram 1500
Valvoline MaxLife
2002 Honda Accord
Valvoline SynPower
2011 Chevrolet Equinox
Mobil1
1964 Pontiac GTO
Pennzoil 10W-40
Re: QS HM oil info [Re: vwalburn] #4598764
12/09/17 08:47 AM
12/09/17 08:47 AM
Kendall, FL
wemay Offline
wemay  Offline
Kendall, FL
I haven't seen a VOA for the newer formulation but when it was Quaker State Defy...
18 KIA Sportage 2.4 AWD
M1HM 10W30, OEM
ST SYN 5W30, ST9688 (next)
13 Hyundai Santa Fe Sport 2.0T
PPeL 5W30, OEM
M1HM 10W30, OEM (next)
Re: QS HM oil info [Re: wemay] #4598798
12/09/17 09:32 AM
12/09/17 09:32 AM
Wichita, Kansas
vwalburn Offline OP
vwalburn  Offline OP
Wichita, Kansas
I'm sure it's lower now than that SL-rated oil. Just wondering how high can an oil go with an SN rating.
1996 Dodge Ram 1500
Valvoline MaxLife
2002 Honda Accord
Valvoline SynPower
Mobil1
1964 Pontiac GTO
Pennzoil 10W-40
Re: QS HM oil info [Re: vwalburn] #4598881
12/09/17 11:22 AM
12/09/17 11:22 AM
Michigan
Building3 Offline
Building3  Offline
Michigan
I had the same question so I called the Shell tech phone line. The fellow said that Defy used to have the boosted zinc level but no more. It is lowered to be consistent with the SN rating. Of all of the Quaker State/Pennzoil/Shell motor oils they sell, he recommended Rotella T4 for flat tappet engines. It has 1100 ppm of Zinc. If you are looking for conventional motor oils, there are the specialty oils like Joe Gibbs, Brad Penn, etc., and diesel truck oils like Rotella and others. If you are looking for synthetics, then Mobil 1 has several. The 15w-50 specifically says it is for flat tappets. The 0w-40 and the 5w-50 also have over 1000 ppm of zinc. Castrol Edge 5w-50 states it is for classic cars and older vehicles. So there are plenty of choices, but what was good in the past may not be in the future so it's always good to check.
