Smart charges/time
by Duffyjr. 12/13/18 08:24 AM
7.3 powerstroke water pump
by mobilaltima. 12/13/18 07:10 AM
98 Jeep Cherokee, what oil is spec'd?
by otis24. 12/13/18 06:31 AM
fixing LED Christmas lights
by danez_yoda. 12/13/18 06:30 AM
Things are not as they seem to be..
by CourierDriver. 12/13/18 06:09 AM
Oz Ranger Raptor
by Shannow. 12/13/18 05:22 AM
Shop vac recommendations
by dlundblad. 12/13/18 05:06 AM
Internet Network Issues
by ZeeOSix. 12/13/18 04:13 AM
Looking for Fram Ultra XG30 and XG5 cut open
by rubberchicken. 12/12/18 10:27 PM
92 f150 332 code
by ram_man. 12/12/18 10:05 PM
Mixing brands of brake fluid / gear lube
by SureshR. 12/12/18 09:26 PM
45,000 miles in the Caprice.
by ls1mike. 12/12/18 09:21 PM
Quality oils?
by Horsehaulin. 12/12/18 09:16 PM
Exhaust fumes in cabin
by Skater4life27. 12/12/18 08:40 PM
Squeaky sunroof
by dishdude. 12/12/18 08:09 PM
Liqui Moly Top Tec 1800
by Chuckh. 12/12/18 07:56 PM
2006 Pathfinder Transmission Shudder
by Bluestream. 12/12/18 07:10 PM
Maybe E-10 is better? - PentaStar (Flex Fuel)
by StevieC. 12/12/18 06:52 PM
Shipping cost
by Fitter30. 12/12/18 06:45 PM
Horsehaulin, JLew, bmrk1100, Rrrracer, jefe_de_estado
66664 Registered Users
85 registered members (bfleeman, aquariuscsm, 4WD, aba4430, Bailes1992, 12 invisible), 1,749 guests, and 42 spiders.
Topics295,012
Posts4,925,993
Members66,664
Most Online2,553
Oct 27th, 2018
Metal Bandsaw Blade Tension #4598615
12/08/17 10:22 PM
12/08/17 10:22 PM
New Mexico USA
CCI Offline OP
CCI  Offline OP
New Mexico USA
Bought an old horizontal/vertical metal band saw of unknown make, likely pretty old, seems to run good now. It was a mess, but I took it mostly apart, cleaned and lubed, reassembled, adjusted as best as I could figure out, and it cuts real well, square to well inside of 1/32".
Only problem is on thin wall tube sometimes the blade will stop. It's a fairly fine tooth blade. I suppose it could have something to do with metal wheels on metal blade, maybe this is to be expected. On thicker material it cuts very smooth.
I tensioned the blade as much as seemed prudent with the hand wheel,it used to stop a lot, now it hangs up only on 1/16" material just as it enters the vertical component of the square tube. So now I'm wondering, how tight is tight enough and how tight is too much on that blade?
Re: Metal Bandsaw Blade Tension [Re: CCI] #4598637
12/08/17 10:59 PM
12/08/17 10:59 PM
Flaherty, KY
92saturnsl2 Offline
92saturnsl2  Offline
Flaherty, KY
Tight enough is when the blade won't stop while the saw is running under a normal load/feed. I usually don't need to turn them too tight unless something is wrong with the saw-- I do it by feel, about a good snug plus another half a turn.
All of the ones I worked on had a rubber insulator on the metal drive wheels to grip the blade better. Perhaps this is worn off? Metal on metal might be a rather poor friction combo... Is the tooth pitch/count appropriate for the material being cut-- do you know what it is?
1985 F-250HD 7.5L 4x4 135k- Castrol GTX 15w-40 HDEO
04 Odyssey EX 182k PUP 0w-40
96 Maxima GLE 250k QS Defy 5w-30
07 Chrysler Pacifica Limited 129k Chevron Supreme 5w-20
Re: Metal Bandsaw Blade Tension [Re: CCI] #4598801
12/09/17 08:39 AM
12/09/17 08:39 AM
Houston, Texas
motor_oil_madman Offline
Houston, Texas
There should be rubber on the wheels called tires.
2007.5 dodge cummins 6.7 liter. Chevron Delo400 15w40. 7000 mile or 250-300hr intervals.
Re: Metal Bandsaw Blade Tension [Re: CCI] #4598951
12/09/17 12:10 PM
12/09/17 12:10 PM
Greenville SC
George Bynum Offline
Greenville SC
My question is what "fairly fine tooth blade" means. I was always taught that there should be 2 teeth minimum in the material, so for 1/16 material, 32 tpi of finer. The way around that is with controlled feed where singe point tooling works.
Re: Metal Bandsaw Blade Tension [Re: 92saturnsl2] #4599619
12/10/17 08:04 AM
12/10/17 08:04 AM
New Mexico USA
CCI Offline OP
CCI  Offline OP
New Mexico USA
I got it to the point where the blade wouldn't stop, after removing the blade and cleaning everything, it seems tighter than I would have expected but I don't know anything about this anyhow.
Snug plus a little bit. The blade stretched a little after a few uses, another maybe quarter turn did it.
This is part of the reason why I think it might be really old. The wheels in their present state don't look like they are missing any rubber, they look like it was never there. The depth of the flanges that retain the blade from sliding up off of the wheels are just a little more than the blade thickness. If there was ever any rubber there, the flanges would have been ineffective. This thing also has a little gearbox that requires gear oil. It leaks, needs a new gasket, which I will have to make.
I will get a count. It's pretty fine, probably OK for thinner stock. I don't know if it's fine enough for 1/16" wall square tube, but close.
I can see where this is going. Now I need to figure out where to buy blades. How are the sizes indicated? If it's by circumference, how does one actually measure that? Or center to center on the wheels?
I appreciate the help -- thank you!
Re: Metal Bandsaw Blade Tension [Re: George Bynum] #4599628
12/10/17 08:13 AM
12/10/17 08:13 AM
Reno, Nevada
Langanobob Offline
Langanobob  Offline
Reno, Nevada
Is there an adjustable hydraulic cylinder to control the feed rate? You might try slowing it down. Like George said you probably need a very fine tooth blade for 1/16Ē material. Coolant makes the wheels slippery and Iíve had some trouble with blades slipping when using coolant and I turn the coolant flow off when sawing difficult material. I mostly use a bandsaw for solid bar stock and it may be that a horizontal bandsaw is just not the right tool for cutting thin wall material, unless maybe that is all youíre cutting and you can keep a fine tooth blade on all the time. Otherwise itís a nuisance changing blades for the tubing.
About rubber tires, they are found on wood cutting bandsaws.
Re: Metal Bandsaw Blade Tension [Re: CCI] #4599665
12/10/17 08:56 AM
12/10/17 08:56 AM
Flaherty, KY
92saturnsl2 Offline
92saturnsl2  Offline
Flaherty, KY
Blade is measured in length, width and thickness. Something along the lines of 11' x 1" x 0.035. Most places sell common-size blades, and can create custom ones. Tooth per inch is the other variable-- this can be fixed (6 teeth per inch for example) or variable (e.g. 6-10 teeth per inch). The variable ones handle a greater range of material thicknesses with less performance loss.
I've used primarily Ellis metal-cutting saws that are only air cooled, and these have the rubber "tire" on the wheels to grip the blade. There is no flange to retain the blade-- the proper tension on the blade centers it just fine unless something is damaged on the saw (guides, bearings, etc.)
At shops I've worked in, we cut material of all sizes/thickness and do not change the blade between them, rather change the load/feed so as not to damage the blade when cutting a material size not appropriate for the tooth count.
I my own experience, a 4-6 or 6-10 TPI is acceptable cutting anything over 1/4" thickness. 8-10 and 10-14 can easily handle down to 14 gauge (~ 1/16) provided you have your feed rate set correctly. There is some tables you can look up online that suggest how many teeth should be making contact with the given material. This is not a hard and fast rule, however and you cannot get it perfect for all situations. For example angle has two legs, tube has two walls plus a flat side, so the number of teeth making contact will vary wildly depending on where the blade is in the cut.
If the tension is right and saw is configured/set up correctly, if the blade is mismatched you will either get poor cutting performance or sheared off/dull teeth-- the blade shouldn't actually stop. Too much tension and the blade can snap, and you will shorten the life of the bearings in the saw guides/wheels.
You can literally count the tooth per inch -- if it is not consistent (varies at different places of measurement) you have a variable TPI. Most blades intended for ferrous metal are raked meaning the teeth are slightly offset from center in each direction.
