Here's an oldie "Riding a film of oil"
by dbias. 03/25/19 08:47 PM
'14 Mopar 62TE transmission service?'s
by sloinker. 03/25/19 08:25 PM
Dodge Transmissions (Humor)
by StevieC. 03/25/19 07:57 PM
How a differential works
by StevieC. 03/25/19 07:37 PM
My first!
by BigMoneyGrip. 03/25/19 07:20 PM
Sizing Rims for 17 inch Light Truck Tires
by Snagglefoot. 03/25/19 06:38 PM
Mobil 1 Cartridge Filters On Clearance at WM
by IndyFan. 03/25/19 06:19 PM
Ford Unibody Pickup
by SubLGT. 03/25/19 05:52 PM
Flow How: PourPoint warmer than CCV "0w" Temperature 0w20
by oil_film_movies. 03/25/19 05:31 PM
Oil filter material list?
by shibby6600. 03/25/19 04:49 PM
Insights on commission paying jobs?
by Pat in Speedway. 03/25/19 04:29 PM
Decode a vehicle VIN for production Month & Year?
by Ed_Flecko. 03/25/19 04:29 PM
Wix 51522 vs Fram XG9837
by RDY4WAR. 03/25/19 04:13 PM
Rural King: 20K Lumen LED Tripod Worklight $34.93
by skyactiv. 03/25/19 03:55 PM
How do I find out which Honda Engine?
by Gebo. 03/25/19 03:08 PM
Moltex increases their footprint, hiring
by OVERKILL. 03/25/19 02:53 PM
Rislone complete fuel system gas treatment
by Fitter30. 03/25/19 02:29 PM
DCDMan, silverbullet21, gentzel, ksu90, SMA2020
67622 Registered Users
124 registered members (77GrandPrix, agpatel, Aero540T, aquariuscsm, anndel, Andya, 12 invisible), 2,066 guests, and 65 spiders.
Topics286,425
Posts4,908,062
Members67,622
Most Online2,967
Mar 10th, 2019
2008 Mini Clubman S yearly oil change? #4598161
12/08/17 03:34 PM
12/08/17 03:34 PM
Denver CO
davedasc Offline OP
davedasc  Offline OP
Denver CO
I have a 2008 Mini Clubman S with very low miles that I only drive for pleasure. I only put about 2 to 3k miles on it a year. I change the oil on it yearly at the dealer with their Mini approved synthetic oil. I recently had a mechanic there tell me that I could go to an oil change every 2 years with that low of miles driven a year. Is that feasible or should I stick with the yearly oil change regardless?
Re: 2008 Mini Clubman S yearly oil change? [Re: davedasc] #4598176
12/08/17 03:49 PM
12/08/17 03:49 PM
Great Lakes
Quattro Pete Offline
Great Lakes
How do you drive it? If you don't short trip it much, I'd say 2 years may be doable.
'02 530i (Edge 0W-40)
'15 Q5 3.0T (Edge 5W-40)
'18 Charger SRT (PUP 0W-40 SRT)
Re: 2008 Mini Clubman S yearly oil change? [Re: davedasc] #4598189
12/08/17 03:56 PM
12/08/17 03:56 PM
Cleveland, OH
silveravant Offline
silveravant  Offline
Cleveland, OH
What does the owner's manual say?
Re: 2008 Mini Clubman S yearly oil change? [Re: davedasc] #4598215
12/08/17 04:23 PM
12/08/17 04:23 PM
Brittany / Canada
Popsy Offline
Popsy  Offline
Brittany / Canada
I have a car (96 Barchetta) that I don't drive a lot, not even 2000K a year...change the oil every two years, if you don't do a lot of short trips, or don't track it.
While I'm at it I change the gearbox oil, coolant and brake fluid too, every two years or so. And it's probably overkill...
96 Barchetta, 300V 5W40 | Forfour 95, SHU 0W40
Mazda 6 2.3, M1 AFE 0W20 | Colt Ralliart, 300V 0W40
Re: 2008 Mini Clubman S yearly oil change? [Re: davedasc] #4598367
12/08/17 06:58 PM
12/08/17 06:58 PM
Lyndhurst NJ
Audios Online content
Audios  Online Content
Lyndhurst NJ
BMW updated their oil interval to one year/10k, so theyd probably recommend once a year. If youre worried, try an analysis at the one year mark, and see what it comes up with before you change it or run it out.
2002 VW Golf TDI-Mobil 1 5/40 TDT
2007 Mercedes GL320 CDI- M1 0/30 ESP
2005 BMW M3 BMW Twin Power 10/60
2003 BMW M5-Fuchs 5/40
1998 BMW M3/4/5 Fuchs 5/40
Re: 2008 Mini Clubman S yearly oil change? [Re: davedasc] #4598379
12/08/17 07:14 PM
12/08/17 07:14 PM
NY
DdDd Offline
DdDd  Offline
NY
Meh 3k/yr I'd do two year oil changes and never look back. Those engines do like to burn oil and develop interesting leaks (ask me how I know how lol) so that's no excuse to not check up on your oil levels semi regular like.
Timing chain will go even if the levels are on the low end of normal. Since its 08 I'd recommend checking if it has new style chain tensioner just in case. You can change it yourself with very mild swearing, easier than it sounds and fairly cheap part.
Re: 2008 Mini Clubman S yearly oil change? [Re: silveravant] #4598392
12/08/17 07:23 PM
12/08/17 07:23 PM
Denver CO
davedasc Offline OP
davedasc  Offline OP
Denver CO
Mini's recommendation was 1 year or 15000 miles . I've read that starting in 2012, Mini lowered that to 1 year 10000 miles. Since I will never drive either of those distances in one year, I guess my question is, should I follow the 1 year time recommendation or could I go longer or should I go shorter (like every 6 months)?
I drive the car only for pleasure and in only good weather on highways. I don't drive hard.
Re: 2008 Mini Clubman S yearly oil change? [Re: DdDd] #4598407
12/08/17 07:32 PM
12/08/17 07:32 PM
Denver CO
davedasc Offline OP
davedasc  Offline OP
Denver CO
I've never had a problem with oil consumption with this car so far.
Re: 2008 Mini Clubman S yearly oil change? [Re: davedasc] #4598462
12/08/17 08:15 PM
12/08/17 08:15 PM
War Eagle
toneydoc Offline
toneydoc  Offline
War Eagle
You can do 2 years with no problems. I bet you even keep her in a nice warm and safe garage.
1994 Jeep 162k Castrol Synblend 10w30
2014 Camry 38k Havoline 5w20
2018 Jeep Cherokee 5k FactFill
2014 HD Ultra 42k Mobil1 15w50
2012 Rav4 39k Mobil 1 0w20
Re: 2008 Mini Clubman S yearly oil change? [Re: davedasc] #4598612
12/08/17 11:15 PM
12/08/17 11:15 PM
Down Under
SR5 Offline
SR5  Offline
Down Under
At 3k miles per year on a BMW approved synthetic, with no short tripping. Yes I personally would be OK leaving it in two years, and I have done similar things myself before on Euro A3/B4 synthetics with vehicles driven much as you described.
Castrol GTX Ultraclean 15W40 A3/B3 + Wesfil-Cooper Z154
Re: 2008 Mini Clubman S yearly oil change? [Re: davedasc] #4598670
12/09/17 01:38 AM
12/09/17 01:38 AM
Tasmania, Australia
hpb Offline
hpb  Offline
Tasmania, Australia
2 years will cause no issues whatsoever.
MY16 Mitsubishi Outlander 2.2 diesel, 57,000km - Castrol 5w30
2006 Ford Falcon 4.0, 140,000km - Valvoline Engine Armour 15w40, Ryco filter
Re: 2008 Mini Clubman S yearly oil change? [Re: davedasc] #4598917
12/09/17 12:16 PM
12/09/17 12:16 PM
The Garden State
Whimsey Offline
Whimsey  Offline
The Garden State
While it's not your Mini, my BIL bought a 5 year old Porsche Boxster with 9,000 miles on the factory fill and filter. It was the original owner's nice weather relaxation/escape vehicle. No short trip driving to the store. My BIL had Terry Dyson do the UOA and it came back with nothing unusual with the wear metals and still had good TBN life left. With your style of driving with this car I'd suspect you can easily go 2 year oil change intervals. How much oil does your oil change take? The Boxster takes about 9 quarts. Enjoy the car.
Whimsey
Re: 2008 Mini Clubman S yearly oil change? [Re: davedasc] #4599004
12/09/17 02:15 PM
12/09/17 02:15 PM
Georgia
Charlie2015 Offline
Charlie2015  Offline
Georgia
If you are taking it to the dealer for the oil change, just keep doing it once per year. They will no doubt look over the whole vehicle for something to sale to you. Your car will probably stay in better shape that way.
1998 Honda Accord EX 2.3L Auto (Sold) 214k mi
2009 Scion tC Manual (Daily Driver) 165k mi
Re: 2008 Mini Clubman S yearly oil change? [Re: Quattro Pete] #4599024
12/09/17 02:43 PM
12/09/17 02:43 PM
Katy, Republic of Texas
blupupher Offline
blupupher  Offline
This.
If the oil gets up to temp (at least a 30 minute drive) and you are not trashing on it (full throttle right after startup), a 2 year interval should be fine.
Of course a UOA is a better way to help determine it, but not something I would worry about.
2018 Hyundai Santa Fe: Delo XLE 10w-30, OEM filter, 3k
2012 Scion xB: QSUD 0w-20, CQ Blue, 5k
2002 Ford F150: Magnatec 5w-20, Bosch D+, 1yr
1994 Honda VT1100: Peak 15w-40, PSL, 1yr
Re: 2008 Mini Clubman S yearly oil change? [Re: davedasc] #4599076
12/09/17 03:41 PM
12/09/17 03:41 PM
Kalifornia Kollective
BrocLuno Offline
BrocLuno  Offline
+1 more ... Do a UOA at the end of a year and we'll all know exactly what the oil is like. And you'll have evidence that you did it right, should you have to argue with the dealer/MFG on any issue (like a future recall ... ) smile
