Mattress shopping .....
by dblshock. 12/18/18 04:57 AM
AmazonBasics Oil May Drive Prices Down
by knerml. 12/18/18 04:45 AM
Hemi MDS issues are how common?
by Gasbuggy. 12/18/18 03:21 AM
Why use Redline and Redline Clone oils...
by burla. 12/17/18 11:38 PM
Tire choice
by CincyReds. 12/17/18 11:14 PM
Transmission fluid leak
by dawgn86. 12/17/18 07:53 PM
QuickJack BL-5000SLX and my Optima...
by WhizkidTN. 12/17/18 07:23 PM
Champion Air Filter Opinions?
by JerryBob. 12/17/18 06:18 PM
Tundra transfer case plug torque (Borg Warner)
by Idlewild294. 12/17/18 06:03 PM
Winter tire question?
by Muskieteer. 12/17/18 05:31 PM
Who makes good ball joints these days?
by GSCJR. 12/17/18 04:51 PM
Bought a used Ford Fusion
by krismoriah72. 12/17/18 04:14 PM
Valvoline NextGen Tech Oil
by DirtyOilGuy. 12/17/18 04:08 PM
Witty comment regarding a lame car
by Number_35. 12/17/18 03:43 PM
'80s oil literature
by Number_35. 12/17/18 03:26 PM
Recommend on oil for 2017 Kia Sportage 2.4
by SlavaB. 12/17/18 02:57 PM
No more Delo at my Costco. T4 now
by BeerCan. 12/17/18 02:16 PM
Found this
by davedude. 12/17/18 02:15 PM
hopsofir, genera2800, oghl, hdlss, dsmdylan
66711 Registered Users
38 registered members (97K15004WD, CC1981, 69Torino, bbhero, Char Baby, 5 invisible), 943 guests, and 38 spiders.
Topics295,207
Posts4,929,904
Members66,711
Most Online2,553
Oct 27th, 2018
2014 Cruze 2.0 AMSOIL HDH 5w-30 7,500 miles #4597893
12/08/17 09:19 AM
12/08/17 09:19 AM
North Carolina
Rat407 Offline OP
Rat407  Offline OP
North Carolina
I went from the AEL to the HDH this time to see how the new Signature Series would work out. Not sure why my TAN is so high and the rest look good. This sample was taken right after getting home from a 9 hr trip back from PA. Air filter was changed at beginning of this oil run and the oil filter is the AC Delco. Diesel used was mainly from Sheetz which there isn't anything on the pump that states it has Biodiesel in it, just that it is 40 cetane. Averaging 45.7 mpg and it regens about once every 600 miles.
2002 Silverado 5.3 0w-20 AMSOIL®
Re: 2014 Cruze 2.0 AMSOIL HDH 5w-30 7,500 miles [Re: Rat407] #4598051
12/08/17 12:37 PM
12/08/17 12:37 PM
Indiana
Phishin Offline
Phishin  Offline
Indiana
What oil did you run that had 400ppm and 300ppm of Boron?
2018 Chevy Silverado 3500HD 6.0L Gas: RLI 10w30
2010 Accord-LX K24: MaxLife 5w30 + Torco MPZ
2014 CR-V LX K24: M1 0w30
Re: 2014 Cruze 2.0 AMSOIL HDH 5w-30 7,500 miles [Re: Phishin] #4598062
12/08/17 12:50 PM
12/08/17 12:50 PM
North Carolina
Rat407 Offline OP
Rat407  Offline OP
North Carolina
That was the AMSOIL AEL European 5w-30 oil.
Re: 2014 Cruze 2.0 AMSOIL HDH 5w-30 7,500 miles [Re: Rat407] #4598284
12/08/17 04:32 PM
12/08/17 04:32 PM
California
CleverUserName Offline
California
I remember seeing that thread. You were using RLI then switched to AEL and the tin appeared. Did you stop using the stanadyne additive ?
Re: 2014 Cruze 2.0 AMSOIL HDH 5w-30 7,500 miles [Re: CleverUserName] #4598336
12/08/17 05:27 PM
12/08/17 05:27 PM
North Carolina
Rat407 Offline OP
Rat407  Offline OP
North Carolina
Yes
Now trying a new fuel add. LE's Full Torque. Not bad at $17 a Qt and free shipping with a treat ratio of 1:400
LE's Full Torque
Re: 2014 Cruze 2.0 AMSOIL HDH 5w-30 7,500 miles [Re: Rat407] #4598682
12/09/17 02:32 AM
12/09/17 02:32 AM
California
California
Yes
LE's Full Torque
Yes I found that tread interesting because I also use stanadyne in my '09 TDI and new Canyon 2.8. I also took a hit on tin and other metals in one TDI UOA, however the TBN was almost depleted and I thought it was from that. I never considered it could have come from the stanadyne. I'm still using it cause I have a partial bottle left. I'm gonna run my first UOA on the canyon and we well see if there is any tin present.
I didn't know LE made a diesel additive. I was going to try this stuff, Amalgamated TDR-FL, They say 5-7 cetane point increase and it's even cheaper. $106 for 2.5 gallons: http://www.amalgamatedinc.com/tdr-fl.aspx
Re: 2014 Cruze 2.0 AMSOIL HDH 5w-30 7,500 miles [Re: Rat407] #4599983
12/10/17 03:24 PM
12/10/17 03:24 PM
A Highway Near You
PiperOne Offline
PiperOne  Offline
A Highway Near You
Does the Cruze have a separate injector for re-gens or does it do a post injection?
HDEO in Diesel Engines. No spark plugs here.
Re: 2014 Cruze 2.0 AMSOIL HDH 5w-30 7,500 miles [Re: PiperOne] #4602467
12/13/17 10:28 AM
12/13/17 10:28 AM
North Carolina
Rat407 Offline OP
Rat407  Offline OP
North Carolina
Not sure, I think post. I do know my EGT goes up to 1200 degrees F when it is in regen.
Re: 2014 Cruze 2.0 AMSOIL HDH 5w-30 7,500 miles [Re: Rat407] #4625257
01/05/18 06:06 PM
01/05/18 06:06 PM
Stewartstown PA
spiderbypass Offline
Stewartstown PA
I was really impressed by the Amsoil Ael 5W30 improved European formula as you ran it out the longest at 10 thousand miles or so and the wear metals looked good and it seemed to hold tbn as well if not better than the Amsoil DHD 5W30. They really did improve the formula with a relatively more stout additive package compared with the original Amsoil’ European formula which started with an under 6 tbn that you had after ten thousand mile run. Here is a link to a virgin oil analysis from the Russian oil club. Of note I bumped up link to Russian oil club under Virgin Oil Analysis that has comprehensive list of oil analysis using similar tables as this one.
http://www.oil-club.ru/forum/index.php?a...attach_id=39341
Insecurity with overcompensation are the root of evil deeds.
